Hi
Im new on Manjaro and others Archlinux based distributions.I want to adapt a kali-linux tool on Manjaro.
So i try to use berate-ap
from AUR :
https://aur.archlinux.org/packages/berate_ap-git
I can start it with :
berate_ap -h
I see a lot of settings but i can’t use them.For example when i try this command :
berate_ap --mana-loud -n --redirect-to-localhost --ieee80211n -g 192.168.1.1 wlp3s0 -c 11 Testing
I get this error :
which: no hostapd-mana in (/home/koala/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
ERROR: hostapd-mana not found please link to or add hostapd-mana to your path.
I installed hostapd-mana
from AUR :
https://aur.archlinux.org/packages/hostapd-mana-git
In the official berate-ap github they say :
This script requires hostapd-mana to be in the path.
This may be done by adding the binary to your path directly:
export PATH="$PATH:/path/to/hostapd-mana"
To make this permanent you may add to your shells .rc file
or you may link hostapd-mana into a directory that is within your path:
cd /usr/bin
sudo ln -s /path/to/hostapd-mana hostapd-mana
When i go to /usr/bin
there is no hostapd-mana-git
but with pacman -Qm
i can see the hostapd-mana-git package is installed on my system and his location is on :
/home/koala/hostapd-mana-git
ls
hostapd-mana pkg service
hostapd-mana-git-20230803.bd6114d-1-x86_64.pkg.tar.zst PKGBUILD src
How i can find and create the path to link berate-ap
to hostapd-mana-git
I hope this post is sufficiently clear to understand the issue.
Thanks
