While updating on one of my Manjaro machines I keep receiving this error (I translated it into English, it may not be 100% accurate)
> sudo pacman -Syu
[sudo] password for user ***:
error: Eror GPGME: No data
:: Synchronising databases with packages…
core 169,2 KiB 627 KiB/s 00:00 [######################] 100%
extra 1892,1 KiB 2,56 MiB/s 00:01 [######################] 100%
community 6,7 MiB 2,22 MiB/s 00:03 [######################] 100%
multilib 175,2 KiB 1200 KiB/s 00:00 [######################] 100%
error: failed to synchronize all databases (Incorrect or broken databse (PGP signature))
The message indicates the data returned from the mirror is html returned as a response to an error.
E.g when nginx is is configured to serve a custom 404 html is sends a 200 OK and serves the HTML which makes curl think the data has been fetched successfully.
I cannot tell you what to do other than switching a mirror you can verify e.g. https://mirror.moson.org/manjaro
and that gave a very unusual result: lots of warnings about me having local packages newer than remote ones, eg. (just a few from the list):
:: Starting full system upgrade…
warning: alsa-card-profiles: local (1:0.3.35-1) is newer than extra (1:0.3.34-1)
warning: archlinux-keyring: local (20210902-1) jest nowsze niż core (20210820-1)
warning: autoconf-archive: local (1:2021.02.19-1) jest nowsze niż community (1:2019.01.06-4)
warning: babl: local (0.1.88-2) jest nowsze niż extra (0.1.88-1)
many more like these
If I now run sudo pamac update -a, the problem reappears, but only for multilib:
Refreshing multilib.db...
Error: multilib.db: Error GPGME: No data
When i now do sudo pacman -Syyu I’m returning to the beginning, all errors reappear as they were. For sudo pamac update -a I can see problems only with multilib:
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Incorrect or broken database (PGP signature)
I’ve just tried to update the system, everything works fine, which suggests that my problem was solved in the last Manjaro update. The thread can be closed.
