Hi! I am trying to install Manjaro 21.02.1 GNOME on my computer, I had Windows on it but it was cancelled during one of the last installations and I was using this alongside Ubuntu. I have therefore a “/”, a /boot" and a “/home” partition for Linux. During the installation I get the message:
“Installation Failed
External command finished with errors.
Command useradd -m -U -s /bin/zsh -c Name Surname username finished with exit code 127.
Output:
useradd: error while loading shared libraries: libselinux.so.1: cannot open shared object file: No such file or directory”
I am a little bit stuck here, this should be a fresh installation, is the ISO damaged? How can I fix it?
Thank you in advance for your help!
