Hello community:)
Today morning I run update on my manjaro system.
Everything runs good and then some kind of bus error occurred and after that system went down.
As you know many things could go wrong during that kind of crash …
So at the moment I cant get system up because of
error while loading shared libraries named libip4tc.so.2
then Im being drop to rootfs and I cant even type anything because keyboard freezes,
also when Im in my manjaro installation from live cd I cant perform
comand “nmcli” because of error while loading shared libraries
libsmime3.so
I am kind of stuck in here and cant go any further.
Please help.
&mkinitcpio -p linux419
==>ERROR: binary depency libip4tc.so.2 not found for
/usr/lib/systemd/systemd-udevd
/usr/bin/udevadm
/usr/bin/systemd-tmpfiles
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
-> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.155-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
-> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
&pacman -S linux419
resolving dependencies...
Packages (1) linux419-4.19.155-1
Total Installed Size: 121.10 MiB
Net Upgrade Size: 0.00 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
reinstalling linux419...
ldconfig: File /usr/lib/libnssutil3.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmptrapd.so.40 is empty, not checked.
ldconfig: File /usr/lib/libpipewire-0.3.so.0 is empty, not checked.
ldconfig: File /usr/lib/libxtables.so.12.3.0 is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmphelpers.so.40 is empty, not checked.
ldconfig: File /usr/lib/libenchant-2.so is empty, not checked.
ldconfig: File /usr/lib/libflatpak.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcolordprivate.so.2 is empty, not checked.
ldconfig: File /usr/lib/libldap_r-2.4.so.2 is empty, not checked.
ldconfig: File /usr/lib/libssl3.so is empty, not checked.
ldconfig: File /usr/lib/libxtables.so is empty, not checked.
ldconfig: File /usr/lib/libsnmp.so.40 is empty, not checked.
ldconfig: File /usr/lib/libxtables.so.12 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmp.so.40.0.0 is empty, not checked.
ldconfig: File /usr/lib/libipq.so is empty, not checked.
ldconfig: File /usr/lib/libfwupdplugin.so.1 is empty, not checked.
ldconfig: File /usr/lib/libldap-2.4.so.2.11.2 is empty, not checked.
ldconfig: File /usr/lib/libxml2.so.2.9.10 is empty, not checked.
ldconfig: File /usr/lib/libcolord.so is empty, not checked.
ldconfig: File /usr/lib/libnss3.so is empty, not checked.
ldconfig: File /usr/lib/libip6tc.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpmibs.so.40.0.0 is empty, not checked.
ldconfig: File /usr/lib/liblber.so.2 is empty, not checked.
ldconfig: File /usr/lib/libflatpak.so.0.10802.0 is empty, not checked.
ldconfig: File /usr/lib/libnsssysinit.so is empty, not checked.
ldconfig: File /usr/lib/libldap.so.2 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpagent.so.40 is empty, not checked.
ldconfig: File /usr/lib/libxml2.so.2 is empty, not checked.
ldconfig: File /usr/lib/libsane.so is empty, not checked.
ldconfig: File /usr/lib/libcolorhug.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmphelpers.so is empty, not checked.
ldconfig: File /usr/lib/liblber-2.4.so.2 is empty, not checked.
ldconfig: File /usr/lib/libldap.so is empty, not checked.
ldconfig: File /usr/lib/libfreebl3.so is empty, not checked.
ldconfig: File /usr/lib/libcolord.so.2 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmp.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpmibs.so.40 is empty, not checked.
ldconfig: File /usr/lib/libip6tc.so.2 is empty, not checked.
ldconfig: File /usr/lib/libcolordprivate.so is empty, not checked.
ldconfig: File /usr/lib/libpipewire-0.3.so.0.315.0 is empty, not checked.
ldconfig: File /usr/lib/libip4tc.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libldap_r.so is empty, not checked.
ldconfig: File /usr/lib/libcolordcompat.so is empty, not checked.
ldconfig: File /usr/lib/libvulkan.so.1 is empty, not checked.
ldconfig: File /usr/lib/libpipewire-0.3.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpmibs.so is empty, not checked.
ldconfig: File /usr/lib/libflatpak.so is empty, not checked.
ldconfig: File /usr/lib/liblber.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmptrapd.so is empty, not checked.
ldconfig: File /usr/lib/libipq.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsnmp.so.40.0.0 is empty, not checked.
ldconfig: File /usr/lib/libvulkan.so.1.2.159 is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so.2 is empty, not checked.
ldconfig: File /usr/lib/liblber-2.4.so.2.11.2 is empty, not checked.
ldconfig: File /usr/lib/libsoftokn3.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpagent.so.40.0.0 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpagent.so is empty, not checked.
ldconfig: File /usr/lib/libsane.so.1.0.31 is empty, not checked.
ldconfig: File /usr/lib/libfwupdplugin.so is empty, not checked.
ldconfig: File /usr/lib/libcolordprivate.so.2.0.5 is empty, not checked.
ldconfig: File /usr/lib/libsnmp.so is empty, not checked.
ldconfig: File /usr/lib/libldap_r-2.4.so.2.11.2 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmphelpers.so.40.0.0 is empty, not checked.
ldconfig: File /usr/lib/libip6tc.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libfreeblpriv3.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmptrapd.so.40.0.0 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmp.so.40 is empty, not checked.
ldconfig: File /usr/lib/libcolord.so.2.0.5 is empty, not checked.
ldconfig: File /usr/lib/libip4tc.so is empty, not checked.
ldconfig: File /usr/lib/libcolorhug.so.2 is empty, not checked.
ldconfig: File /usr/lib/libenchant-2.so.2 is empty, not checked.
ldconfig: File /usr/lib/libipq.so.0 is empty, not checked.
ldconfig: File /usr/lib/libvulkan.so is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so is empty, not checked.
ldconfig: File /usr/lib/libldap-2.4.so.2 is empty, not checked.
ldconfig: File /usr/lib/libenchant-2.so.2.2.11 is empty, not checked.
ldconfig: File /usr/lib/libcolorhug.so.2.0.5 is empty, not checked.
ldconfig: File /usr/lib/libfwupdplugin.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsane.so.1 is empty, not checked.
ldconfig: File /usr/lib/libxml2.so is empty, not checked.
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating linux initcpios...
==> ERROR: binary dependency `libip4tc.so.2' not found for `/usr/lib/systemd/systemd-udevd'
==> ERROR: binary dependency `libip4tc.so.2' not found for `/usr/bin/udevadm'
==> ERROR: binary dependency `libip4tc.so.2' not found for `/usr/bin/systemd-tmpfiles'
==> WARNING: errors were encountered during the build. The image may not be complete.
(4/4) Updating Grub-Bootmenu
udevadm: error while loading shared libraries: libip4tc.so.2: cannot open shared object file: No such file or directory
Found background: /usr/share/grub/background.png
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
done
& ls -l /usr/lib/systemd/ | grep -i "udev"
lrwxrwxrwx 1 root root 17 Sep 21 10:10 systemd-udevd -> ../../bin/udevadm
& ls -l /usr/bin/ |grep -i "udevadm"
-rwxr-xr-x-x 1 root root 477048 Sep 21 10:10 udevadm
pacman -Qo /usr/lib/systemd/systemd-udevd
/usr/lib/systemd/systemd-udevd is owned by system 246.6-1
pacman -Qo /usr/bin/udevdadm
/usr/usr/bin/udevdadm is owned by system 246.6-1
pacman -Qo /usr/bin/systemd-tmpfiles
/usr/bin/systemd-tmpfiles is owned by system 246.6-1
