I installed manajro KDE and was trying to install drives for my wifi adapter
i know my adapter drive is kelebek333/rtl8188fu
so I try to install from aur
but it end always end with error in configuration…
Error! The module/version combo: 8188fu-r97.e9b34e3 is not located in the DKMS tree.
Error while configuring 8188fu-kelebek333-dkms-git
Error: 8188fu-kelebek333-dkms-git: command failed to execute correctly
i installed linux-headers but error still exist…
if anyone know about it please reply with solution
Hi @jithinjames , and welcome!
What specifically have you tried?
I see rtl8188fu drivers are in the AUR.
$ pamac search 8188fu
8188fu-kelebek333-dkms-git r84.b01ebdf-1 AUR
Kernel driver module for Realtek RTL8188FU and RTL8188FTV Wireless 802.11n USB 2.0 adapters (device id 0bda:f179)
8188fu-dkms-git r8.1d12cae-3 AUR
So, in theory installing them should be as easy as running, from the terminal:
pamac build 8188fu-kelebek333-dkms-git
But it seems that is the one to have failed, so rather try the other option:
pamac build 8188fu-dkms-git
The dkms
part is important. That means it will last across kernel rebuilds, so I’m guessing you don’t have to reinstall is with every update.
Hope this helps!
I did it many time but this error keeps comming
“Error! The module/version combo: 8188fu-r97.e9b34e3 is not located in the DKMS tree.
Error: 8188fu-kelebek333-dkms-git: command failed to execute correctly”
I tried building both drivers but same error keeps poping up
What command failed to execute correctly? Please post the full build log.
Tip: When pasting terminal output on Discourse forums, one can either…
Use the Preformatted text </> toolbar button–NOT the Quote " button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
Preparing…
Cloning 8188fu-kelebek333-dkms-git build files…
Generating 8188fu-kelebek333-dkms-git information…
Checking 8188fu-kelebek333-dkms-git dependencies…
Warning: 8188fu-kelebek333-dkms-git-r97.e9b34e3-1 is up to date – reinstalling
Resolving dependencies…
Checking inter-conflicts…
Building 8188fu-kelebek333-dkms-git…
==> Making package: 8188fu-kelebek333-dkms-git r97.e9b34e3-1 (Monday 20 December 2021 11:49:11 AM)
==> Checking runtime dependencies…
==> Checking buildtime dependencies…
==> Retrieving sources…
→ Updating 8188fu git repo…
Fetching origin
From GitHub - kelebek333/rtl8188fu: RTL8188FU driver for Linux 4.15.x ~ 5.15.x
9a1f144…f16cfb1 refs/pull/15/head → refs/pull/15/head
25fec6d…c609c3d refs/pull/15/merge → refs/pull/15/merge (forced update)
→ Found blacklist-r8188fu.conf
→ Found dkms.conf
==> Validating source files with sha256sums…
8188fu … Skipped
blacklist-r8188fu.conf … Passed
dkms.conf … Passed
==> Removing existing $srcdir/ directory…
==> Extracting sources…
→ Creating working copy of 8188fu git repo…
Cloning into ‘8188fu’…
done.
==> Starting prepare()…
==> Starting pkgver()…
==> Entering fakeroot environment…
==> Starting package()…
==> Tidying install…
→ Removing libtool files…
→ Purging unwanted files…
→ Removing static library files…
→ Stripping unneeded symbols from binaries and libraries…
→ Compressing man and info pages…
==> Checking for packaging issues…
==> Creating package “8188fu-kelebek333-dkms-git”…
→ Generating .PKGINFO file…
→ Generating .BUILDINFO file…
→ Adding install file…
→ Generating .MTREE file…
→ Compressing package…
==> Leaving fakeroot environment.
==> Finished making: 8188fu-kelebek333-dkms-git r97.e9b34e3-1 (Monday 20 December 2021 11:49:18 AM)
==> Cleaning up…
Checking keyring…
Checking integrity…
Loading packages files…
Checking file conflicts…
Checking available disk space…
Running pre-transaction hooks…
Creating Timeshift snapshot before upgrade…
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules
Deprecated feature: REMAKE_INITRD
==> dkms remove --no-depmod 8188fu/r97.e9b34e3 -k 5.15.7-1-MANJARO
Configuring 8188fu-kelebek333-dkms-git…
Creating symlink /var/lib/dkms/8188fu/r97.e9b34e3/source → /usr/src/8188fu-r97.e9b34e3
Building module:
cleaning build area…
‘make’ all KVER=5.15.7-1-MANJARO…
rtl8188fu.ko.xz:
Running module version sanity check.
Original module
No original module exists within this kernel
Installation
Installing to /usr/lib/modules/5.15.7-1-MANJARO/updates/dkms/
depmod…
Running post-transaction hooks…
Arming ConditionNeedsUpdate…
Install DKMS modules
==> dkms install --no-depmod 8188fu/r97.e9b34e3 -k 5.15.7-1-MANJARO
==> depmod 5.15.7-1-MANJARO
Refreshing PackageKit…
This is the full build log…
Yochanan:
* Add three backticks ` above and below the text (Markdown):
* Use HTML:
<pre><code>
</pre></code>
All looks good to me,
When I try to install using pamac, it show failed to configure at the end…
In this log too… There are 3 error…
And the most important thing is it’s sill not working…
I tried same drive in zorin os and it worked…
But I like to switch to arch based distro
