Im switching to Linux because when I updated my Laptop from windows 10 to 11 it could not properly start as it would just end up in a black screen even though it gave startup sound.
I want to install gnome manjaro on my ssd but when installing it only find my hdd.
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_GNOME_2314 quiet systemd.show_status=1 splash
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Dell product: Vostro 5481 v: N/A
Mobo: Dell model: 0YT82K v: A00 serial: <superuser required> part-nu: 08A7
uuid: <superuser required> UEFI: Dell v: 2.1.0 date: 01/31/2019
ID-1: BAT0 charge: 27.7 Wh (98.9%) condition: 28.0/42.0 Wh (66.6%)
volts: 13.1 min: 11.4 model: Samsung SDI DELL CYMGM8B type: Li-ion
serial: <filter> status: charging
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 450 high: 800 min/max: 400/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 800 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 bogomips: 32012
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Dell driver: nvidia
v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:174d
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0c45:671f
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x0806 built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
device-ID: 8086:3ea0 memory: 7.27 GiB unified: yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
vendor: Dell RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 58.25 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Generic model: SD MMC MS PRO
size: 58.25 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1.00
scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 47.0 C pch: 45.0 C mobo: 46.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 8 GiB note: est. available: 7.45 GiB used: 4.61 GiB (61.9%)
Processes: 292 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 2.96 GiB services: gsd-power, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1279 libs: 325 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.33
this is what inxi -Fayz returns bc this was asked on a old related post.
I think i caused the problem. The disk had bitlock and since i dont have access to the recovery key, I used windows diskpart to nuke the entire disk and cleaned it. That means that there is currently no partition on the disk. People were saying that efi being enabled could be an issue but i assume that is a non issue on a cleaned disk.
Bc i found my hdd and not my ssd i disabled the hdd in bios to see if manjaro then finds my disk on a hail marry (if you are wondering why inxi didnt show it).
Edit:
Just realised that after wiping the ssd i no longer have access to the windows repair tool where i get cmd to use diskpart…
So my question is can i mount the cleaned drive even if there is no partition on it? Or is it a different issue. When i start my laptop it says no bootable devices found so efi is definitely not the issue
