Error when trying to update
When trying to run the command sudo pacman -Syuu, this error message appears:
atenção: haskell-diff: chave desconhecida "%BUILDDATE601758274714" na base de dados de sincronização
atenção: haskell-diff: chave desconhecida "%DEPENDS%rs-compat" na base de dados de sincronização
erro: não foi possível ler a bd "extra" (Damaged tar archive (bad header checksum))
atenção: haskell-diff: chave desconhecida "haske-compat" na base de dados de sincronização
nada para fazer
Mod edit: Minor formatting corrections. :wink: No charge. :footprints:
Who has instructed you to use the downgrade option (the doubled uu)?
The output indicates problems with the metadata information for installed packages.
The most common cause is disk errors or an outright broken file system.
If this is the cause - there is no easy - one command to rule them all.
As a first step, it might be worth ensuring your mirrors are up to date, for instance by running
sudo pacman-mirrors -f
I didn’t enable the downgrade option, how can I check if my hard drives are faulty?
I use an SSD for the system and an HDD for my personal files.
Yes you did..
For normal operation it should be enough to use
sudo pacman -Syu
Or in case of changing mirrorlist - force metadata
sudo pacman -Syyu
man smartctl
For filesystem
man fsck
::**Erro** Connection: HTTPSConnectionPool(host='free.nchc.org.tw', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '\[SSL: CERTIFICATE_VERIFY_FAILED\] certificate verify failed: Missing Subject Key Identifier (\_ssl.c:1032)')))
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
I don’t know how to use these commands, what should I run in the terminal?
Rebuild your mirrorlist
sudo pacman-mirrors -c all
Okay, I’ll run the command.
The same error message is still appearing.
Your mirror list will be OK - the failing mirror has been filtered out.
What happens when you run a system sync as pointed to? (the doubled yy is force refresh metadata because the mirror was changed by the pacman-mirrors command)
sudo pacman -Syyu
It is very helpful if you copy the command and the output to your post so that everyone knows exactly what command is failing (and what options you tried). Did you run the pacman-mirrors command and then the pacman command again? Or is it the pacman-mirrors command failing? Although not normally needed, as mentioned previously it is worth using the double yy in the pacman command after a faiure and mirrir update: sudo pacman -Syyu.
These commands are for displaying the manual.
There is many things we cannot deduce form nothing.
Please provide some system info
inxi -Fxxxyc0
Which command do you want me to run and post the output? I ran pacman -Syu and got the same error message I posted at the beginning.
Mod Edit: Ok, I’m going to do the format and tuck it away. First time is free of charge…
inxi
  Host: eduardo-ax370gaming5 Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 15.2.1 clocksource: tsc
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: F50e date: 07/02/2020
  Info: 8-core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP smt: enabled
    arch: Zen rev: 1 cache: L1: 768 KiB L2: 4 MiB L3: 16 MiB
  Speed (MHz): avg: 2200 min/max: 2200/3400 boost: enabled cores: 1: 2200
    2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200
    11: 2200 12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 108625
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
  Device-1: Advanced Micro Devices \[AMD/ATI\] Ellesmere \[Radeon RX
    470/480/570/570X/580/580X/590\] vendor: Micro-Star MSI driver: amdgpu
    v: kernel arch: GCN-4 pcie: speed: 2.5 GT/s lanes: 16 ports: active: DP-2
    empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 07:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 56.0 C
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: DP-2 mapped: DisplayPort-1 model: P27FBB-RGGL
    serial: 5275800001852 res: N/A dpi: 82 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 ACO DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:67df
  API: Vulkan v: 1.4.321 layers: 9 surfaces: N/A device: 0 type: discrete-gpu
    hw: amd driver: mesa radv device-ID: 1002:67df
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices \[AMD/ATI\] Ellesmere HDMI Audio \[Radeon RX
    470/480 / 570/580/590\] vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  Device-2: Advanced Micro Devices \[AMD\] Family 17h HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
    chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.4.8 status: off with: pipewire-media-session
    status: active
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
    type: plugin
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 8086:1539
    class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 1c:1b:0d:9b:05:52
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
    driver: alx v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 05:00.0 chip-ID: 1969:e0b1 class-ID: 0200
  IF: enp5s0 state: down mac: 1c:1b:0d:9b:05:50
  Local Storage: total: 3.64 TiB used: 2.55 TiB (70.0%)
  ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
    speed: 6.0 Gb/s tech: SSD serial: 1927E21189C2 fw-rev: 023 scheme: GPT
  ID-2: /dev/sdb vendor: Western Digital model: WD30EZRX-00DC0B0
    size: 2.73 TiB speed: 6.0 Gb/s tech: N/A serial: WD-WCC1T1666935 fw-rev: 0A80
    scheme: GPT
  ID-1: / size: 95.92 GiB used: 30.8 GiB (32.1%) fs: ext4 dev: /dev/sda1
  ID-2: /boot/efi size: 500 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda3
  ID-3: /home size: 818.86 GiB used: 468.9 GiB (57.3%) fs: ext4
    dev: /dev/sda2
  System Temperatures: cpu: 42.4 C mobo: N/A gpu: amdgpu temp: 56.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 441
  Memory: total: 32 GiB available: 31.29 GiB used: 4.89 GiB (15.6%)
  Processes: 390 Power: uptime: 1h 11m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
  Packages: 1872 pm: pacman pkgs: 1845 pm: flatpak pkgs: 27 Compilers:
    clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.3
    running-in: konsole inxi: 3.3.39
:light_bulb: Legibility Tip
Summary
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Alternatively, select all pasted text, and click the </> button on the taskbar - which will indent the whole pasted section with one TAB, causing it to render the same way as described above.
Certainly if you use Konsole, it’s trivial to use your mouse to copy… then paste.
Just do ALL the commands and the output…
Then you can select what you paste and click the </> to mark it as ‘code’ and then + and select ‘Hide Details’.
Although the second yis not normally needed, it can be worth forcing the database refresh after a failure:
sudo pacman -Syyu
From the man page:
Passing two --refresh or -y flags will force a refresh of all package databases, even if they appear to be up-to-date.
We have now confirmed the metadata stored in /var/lib/pacman/local is corrupt.
To be able to fix file system errors you will your rescue stick - that is the stick, where you have either prepared for the situation or the stick from which you installed Manjaro.
Your forum account goes back 5 years but in any case see
When have boot your system using the rescue stick - you can proceed to check the file system on your root partition
From your inxi
Open a terminal and enter
sudo su
Then run a check on the partition (the -y argument will attempt repair errors on the fly)
fsck.ext4 /dev/sda1 -y
What will I have to do? From what I read in the thread you sent, will I have to reinstall the system?
[eduardo-ax370gaming5 eduardo]# fsck.ext4 /dev/sda1 -y
e2fsck 1.47.3 (8-Jul-2025)
/dev/sda1 está montado.
e2fsck: Impossível continuar, a abortar.
If you are not booted into a recovery environment then you cannot do a file system check as the root partition will be mounted.
For the file system check to succeed you need the root partition to be unmounted.
If you are in a recovery environment - do not mount the root partition - if mounted then unmount the partition
umount /dev/sda1
If you have mounted other partitions unmount them as well
I think I understand what needs to be done, but I’ve never been in a recovery environment before. What should I do?
It has been suggested you boot from a USB and run commands from that environment. So the first question is, do you have a bootable USB with the OS on it?
Also, did you actually run sudo pacman -Syyu (note the deliberately repeated y) and post the output?
From the link in the Arch Linux Wiki to their forum A package detection script to help rebuild the local database. / Community Contributions / Arch Linux Forums
I have modified the script to use the latest Manjaro database as provided by the first mirror in the system’s mirror list.
cat /etc/pacman.d/mirrorlist | grep -e 'Server =' | head -n 1 | cut -d'=' -f2
Copy the script and save it in your home folder - whatever name you like - I used a filename of recreate-pkg-list.sh
:warning: Please read the in-script documentation provided by the original author(s) to learn of the shortcomings of the scripts.
#!/bin/bash
set -eu
# Source https://bbs.archlinux.org/viewtopic.php?pid=670876 and contributors
#                                Configuration                                 #
# Default values for command-line arguments.
# Default repos to check. The matching file databases must be present in the
# local sync database or fetched from the first mirror in the mirror list
# /etc/pacman.d/mirrorlist
REPOS=(core extra)
# Set the system root.
ROOT=/
# The pacman sync db directory to check for existing file databases.
SYNC_DB_DIR=/var/lib/pacman/sync/
# Set match percentage threshold (matching files / total files) for a package to
# be considered a match and printed.
MATCH_THRESHOLD=50
# If true, only print matching package names.
QUIET=false
#                                  Functions                                   #
function check_files_db()
  local files_db=$1
  local entry
  local pkg
  local pkgname
  bsdtar -tf "$files_db" | while read entry
  do
    if [[ $entry =~ /files$ ]]
    then
      pkg=${entry%/*}
      pkgname=${pkg%-*-*}
      # Invoke bsdtar in a subshell so that we can update a path counter outside
      # of the loop.
      local match=0
      local number=0
      local path
      local pct
      while read path
      do
        # Skip directories.
        if [[ $path =~ /$ ]]
        then
          continue
        fi
        ((number+=1))
        if [[ -e ${ROOT%/}/$path ]]
        then
          ((match+=1))
        fi
      done < <(bsdtar -Oxf "$files_db" "$entry")
      if [[ $match -gt 0 ]]
      then
        pct=$(bc -l <<< "scale=0; 100 * $match / $number")
        if [[ $pct -gt $MATCH_THRESHOLD ]]
        then
          if $QUIET
          then
            echo "$pkgname"
          else
            echo "$pkg ${pct}%"
          fi
        fi
      fi
    fi
  done
# Usage: get_files_db <repo>
function get_files_db()
  #https://mirror.easyname.at/manjaro/unstable/$repo/$arch
  local mirror, repo, arch
  repo=$1
  mirror=$(cat /etc/pacman.d/mirrorlist | grep -e '^Server' | head -n 1 | cut -d'=' -f2 | sed -e 's/\/\$repo\/\$arch\s*$*//g')
  arch=$(uname -m)
  wget -N "$mirror/$repo/$arch/$repo.files"
function display_help()
  cat <<HELP
ABOUT
This is a tool to help recover the local pacman database. It will check
installed files against paths in the pacman file databases to estimate which
package are probably installed on the system. The matches are based entirely on
matching file paths.
For each package, the percent of matching files is calculated. If it meets the
threshold, the package is printed to stdout.
The list of matching packages is only a starting point for
recovering the local database. Some packages include the same paths so the user
will have to determine which of the matches, if any, are likely to be installed
on the system. Also note that no information about the install reaspon can be
determined by matching paths. It is up to the user to figure out which packages
were installed explicitly and which were installed as dependencies.
Also note that if the installed version of a package does not match the version
in the file database, then all paths that contain the version number
(e.g. /usr/lib/foo-xx.xx/...) will fail to match. It is therefore important to
determine which file database matches the installed files.
Local file databases in the sync directory (/var/lib/pacman/sync by default)
will be consulted first if they exist as they are likely to correspond to the
installed version if everything was synchronized together (pacman -Syu; pacman
-Fy). This can be disabled by passing an empty path to the "-s" option.
If the local file databases do not exist, or the check is disabled, an attempt
will be made to download the file database from the first mirror in your mirrorlist.
USAGE
  ${0} [options] [repo repo ...]
If no repos are given, the following will be checked: ${REPOS[@]}
OPTIONS
  -r /path/to/root
    The system root in which to match packages.
    Default: "/".
  -s /path/to/sync_db/dir
    The path to the pacman sync database directory to query local file
    databases. These are normally downloaded with "pacman -Fy". See the notes
    above about matching database package versions to installed versions. To
    disable local checks, set this to an empty string.
    Default: /var/lib/pacman/sync
  -t <percent>
    The percent of files per package that must exist on the local system for the
    package to match.
    Default: 50
  -q
    Only print package names. This can be used to create an install list that
    can be piped to pacman. E.g.
    ${0} -q | pacman -S -
HELP
  exit "$1"
#                                     Main                                     #
while getopts 'hr:s:t:q' flag
do
  case "$flag" in
    r) ROOT=$OPTARG ;;
    s) SYNC_DB_DIR=$OPTARG ;;
    t) MATCH_THRESHOLD=$OPTARG ;;
    q) QUIET=true ;;
    h) display_help 0 ;;
    *) display_help 1 ;;
  esac
done
shift $((OPTIND - 1))
if [[ $# -gt 0 ]]
then
  REPOS=("$@")
fi
for repo in "${REPOS[@]}"
do
  files_db=
  if [[ ! -z $SYNC_DB_DIR ]]
  then
    # Check for local file databases first.
    files_db=${SYNC_DB_DIR%/}/${repo}.files
  fi
  if [[ -z $files_db || ! -e $files_db ]]
  then
    get_files_db "$repo"
    files_db=${repo}.files
  fi
  if $QUIET
  then
    check_files_db "$files_db"
  else
    date -r "$files_db"  +"$files_db %F %R %Z"
    echo '--------------------'
    echo ''
  fi
done
Assuming you saved it as recreate-pkg-list.sh in your home folder
bash recreate-pkg-list.sh -q | tee pkg-list.txt
It will take a long time but in the end - the result should be a list of packages possibly installed on the system. :notebook: Custom packages will not be listed.
Only you can correctly determine if a given package suggested by the script should be installed.
First make a backup of the metadata folder
mkdir ~/pacman-meta
cp -r /var/lib/pacman/local ~/pacman-meta
When you are satisfied with the result you can feed the list to
sudo pacman -S $(cat pkg-list.txt)
