Hello folks, I’m trying to run gephy
, an app based on Java. I installed it using sudo pacman -Syyu gephi
and when I try to run it, it gives me this
[asdru@asdru ~]$ gephi
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.netbeans.ProxyURLStreamHandlerFactory (file:/usr/share/java/gephi/platform/lib/boot.jar) to field java.net.URL.handler
WARNING: Please consider reporting this to the maintainers of org.netbeans.ProxyURLStreamHandlerFactory
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Inconsistency detected by ld.so: dl-lookup.c: 106: check_match: Assertion `version->filename == NULL || ! _dl_name_match_p (version->filename, map)' failed!
Here’s the output of my inxi -Faxi
if needed
Host: asdru Kernel: 5.16.11-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=b7ccff9c-3ed2-4871-9171-b63a484b3dc9 rw quiet splash apparmor=1
security=apparmor resume=UUID=796ccbcb-530d-434a-8efd-c4a8a7338c8b
udev.log_priority=3
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 81UH v: Lenovo Legion Y740-15IRHg
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion Y740-15IRHg
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: BVCN11WW(V1.07)
date: 07/04/2019
ID-1: BAT1 charge: 49.6 Wh (100.0%) condition: 49.6/52.4 Wh (94.8%)
volts: 13.0 min: 11.6 model: Celxpert L17L3PG1 type: Li-ion serial: 190
status: Full
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1052 high: 1700 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 1071 3: 1033
4: 858 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 1670 12: 1700
bogomips: 62431
Type: l1tf
Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f51 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-7:4 chip-ID: 04f2:b604 class-ID: 0e02
serial: 0001
Display: x11 server: X.org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: nvidia gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-4 res: 1920x1080 hz: 144 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi
vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: up mac: 24:ee:9a:ee:76:b8
IP v4: 192.168.1.42/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: fe80::5692:85f1:6561:5747/64 type: noprefixroute scope: link
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3f:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp63s0 state: down mac: 7c:8a:e1:20:86:b4
IF-ID-1: br-1bf583a11769 state: down mac: 02:42:5a:0f:cf:59
IP v4: 172.20.0.1/16 scope: global broadcast: 172.20.255.255
IF-ID-2: br-3a91208e20c8 state: down mac: 02:42:1a:5a:a2:0e
IP v4: 172.19.0.1/16 scope: global broadcast: 172.19.255.255
IF-ID-3: br-c504c002828b state: down mac: 02:42:4f:fc:12:d6
IP v4: 172.18.0.1/16 scope: global broadcast: 172.18.255.255
IF-ID-4: docker0 state: down mac: 02:42:7b:d2:db:66
IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
WAN IP: 190.205.44.170
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 3 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: 24:EE:9A:EE:76:BC
Local Storage: total: 953.87 GiB used: 164.58 GiB (17.3%)
model: MZVLB1T0HALR-000L2 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: S3RSNX0M903911
rev: 5L1QEXA7 temp: 36.9 C scheme: MBR
ID-1: / raw-size: 919.45 GiB size: 903.95 GiB (98.31%)
used: 164.58 GiB (18.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 57.0 C pch: 60.0 C mobo: N/A gpu: nvidia
temp: 57 C
Processes: 366 Uptime: 1d 2h 18m wakeups: 71 Memory: 31.27 GiB
used: 7.26 GiB (23.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1470 pacman: 1456 lib: 365 flatpak: 0
snap: 14 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.13
Thanks in advance for any help.
