Hi, i am trying to pass my RTX 3080, unsurprisingly its not working i am getting this error when creating the VM.
Unable to complete install: 'internal error: qemu unexpectedly closed the monitor: 2020-10-02T00:01:15.125028Z qemu-system-x86_64: warning: host doesn't support requested feature: MSR(490H).vmx-entry-load-perf-global-ctrl [bit 13]
2020-10-02T00:01:15.127699Z qemu-system-x86_64: warning: host doesn't support requested feature: MSR(48FH).vmx-exit-load-perf-global-ctrl [bit 12]
2020-10-02T00:01:15.127739Z qemu-system-x86_64: warning: host doesn't support requested feature: MSR(490H).vmx-entry-load-perf-global-ctrl [bit 13]
2020-10-02T00:01:15.130352Z qemu-system-x86_64: warning: host doesn't support requested feature: MSR(48FH).vmx-exit-load-perf-global-ctrl [bit 12]
2020-10-02T00:01:15.130391Z qemu-system-x86_64: warning: host doesn't support requested feature: MSR(490H).vmx-entry-load-perf-global-ctrl [bit 13]
2020-10-02T00:01:15.202958Z qemu-system-x86_64: -device vfio-pci,host=0000:01:00.0,id=hostdev0,bus=pci.4,addr=0x0: vfio 0000:01:00.0: group 1 is not viable
Please ensure all devices within the iommu_group are bound to their vfio bus driver.'
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 75, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/createvm.py", line 2089, in _do_async_install
guest.installer_instance.start_install(guest, meter=meter)
File "/usr/share/virt-manager/virtinst/install/installer.py", line 542, in start_install
domain = self._create_guest(
File "/usr/share/virt-manager/virtinst/install/installer.py", line 491, in _create_guest
domain = self.conn.createXML(install_xml or final_xml, 0)
File "/usr/lib/python3.8/site-packages/libvirt.py", line 4035, in createXML
if ret is None:raise libvirtError('virDomainCreateXML() failed', conn=self)
libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2020-10-02T00:01:15.125028Z qemu-system-x86_64: warning: host doesn't support requested feature: MSR(490H).vmx-entry-load-perf-global-ctrl [bit 13]
Some more info
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:2206] (rev a1) <- this is my rtx 3080 vga
Subsystem: eVga.com. Corp. Device [3842:3885]
Kernel driver in use: vfio-pci
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:1aef] (rev a1) <- this is my rtx 3080 audio
Kernel modules: snd_hda_intel
Here is the list of devices in my IOMMU group 1
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07)
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) [8086:1905] (rev 07)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:2206] (rev a1) <- vfio
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:1aef] (rev a1) <- vfio
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU106 [GeForce RTX 2070] [10de:1f02] (rev a1)
02:00.1 Audio device [0403]: NVIDIA Corporation TU106 High Definition Audio Controller [10de:10f9] (rev a1)
02:00.2 USB controller [0c03]: NVIDIA Corporation TU106 USB 3.1 Host Controller [10de:1ada] (rev a1)
02:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller [10de:1adb] (rev a1)
Here is information about the PC
5.4.67-1-MANJARO
Motherboard: Z390 AORUS ULTRA (VT-d is set to enabled in the bios, i am also on the latest firmware version which is F10b)
CPU: Intel core i7 8700
GPUS: (Both plugged straight in the motherboard)
rtx 3080 (pcie x16 top slot)
rtx 2070 (pcie x8 2nd slot)
Memory: 16gb dual channel
i also tried to pass my RTX 2070 with all its USB controllers and i got the same error.
