Hi, curious about plasma 6.5, I tried to switch branch, from stable to testing. After running
- sudo pacman-mirrors --api --set-branch testing
- sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syu
I get
core is up to date
extra is up to date
multilib 147,5 KiB 335 KiB/s 00:00 [#################################] 100%
warning: ksystemstats: local (6.4.0-1) is newer than extra (6.3.6-1)
resolving dependencies...
warning: cannot resolve "expat=2.7.3", a dependency of "lib32-expat"
warning: cannot resolve "pcre2=10.47", a dependency of "lib32-pcre2"
:: The following packages cannot be upgraded due to unresolvable dependencies:
lib32-expat lib32-pcre2
Here my inxi -zv8
inxi -zv8
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
root=UUID=f9b1e170-4180-422d-9fde-3ed1dc55e2b1 rw quiet
cryptdevice=UUID=a621da8d-7e97-4684-a588-eeb873d7b749:luks-a621da8d-7e97-4684-a588-eeb873d7b749
root=/dev/mapper/luks-a621da8d-7e97-4684-a588-eeb873d7b749 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Convertible System: LENOVO product: 20NQS0W600 v: ThinkPad X390 Yoga
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: LENOVO model: 20NQS0W600 v: SDK0J40697 WIN serial: <filter>
part-nu: LENOVO_MT_20NQ_BU_Think_FM_ThinkPad X390 Yoga
uuid: ded7dbcc-2c48-11b2-a85c-9a6db42bbb2a UEFI: LENOVO
v: N2LET74W (1.74 ) date: 03/24/2020
ID-1: BAT0 charge: 36.3 Wh (70.5%) condition: 51.5/50.5 Wh (101.9%)
power: 6.5 W volts: 11.45 min: 11.55 model: LGC 5B10W13927 type: Li-poly
serial: <filter> charging: status: discharging control: start: 0%
end: 100% cycles: 433
System RAM: total: 8 GiB available: 7.42 GiB used: 5.28 GiB (71.1%)
igpu: 32 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 4 GiB speed:
spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: Micron part-no: 4ATF51264HZ-2G6E1 serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB speed:
Slot: N/A type: N/A status: available length: other bus-ID: 00ff:ff:1f.7
Info: model: Intel Core i5-8365U socket: BGA1528 (U3E1) note: check bits: 64
type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 8 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0x100
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/4100 base/boost: 1600/1900 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 30409
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
invpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
Type: itlb_multihit status: KVM: VMX unsupported
Type: retbleed mitigation: Enhanced IBRS
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b67c
Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
compositor: kwin_wayland driver: X: loaded: intel dri: i965 gpu: i915
display-ID: :1 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1387 built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2 chroma: red:
x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
GT2) device-ID: 8086:3ea0 memory: 7.24 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 25.2.3-arch1.2
device-ID: 8086:3ea0 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.8 status: n/a (root, process) with:
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Device-1: luks-a621da8d-7e97-4684-a588-eeb873d7b749 maj-min: 254:0
type: LUKS dm: dm-0 size: 62.5 GiB
Components:
p-1: nvme0n1p7 maj-min: 259:7 size: 62.5 GiB
Local Storage: total: 295.76 GiB used: 39.72 GiB (13.4%)
model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 4M2QEXH7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra Fit
size: 57.28 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 62.5 GiB size: 61.22 GiB (97.95%) used: 15.38 GiB (25.1%)
fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a621da8d-7e97-4684-a588-eeb873d7b749 label: linux root
uuid: f9b1e170-4180-422d-9fde-3ed1dc55e2b1
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 199.3 MiB (20.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: linux boot
uuid: 3396fedb-3bda-431a-a439-80438fb6d4bb
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 320 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: efi system uuid: 0164-1470
ID-4: /run/media/rednose/39EF-9EA8 raw-size: 57.28 GiB
size: 57.27 GiB (99.98%) used: 24.15 GiB (42.2%) fs: vfat block-size: 512 B
dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 39EF-9EA8
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: ESP
uuid: B618-C398
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.95 GiB fs: ntfs
label: Recovery uuid: 7638193C3818FD35
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 31.25 GiB fs: ntfs label: SYSTEM
uuid: 6EEA1B5BEA1B1F41
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 056a:51b2 class-ID: 0300
Device-2: 1-8:3 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b67c class-ID: 0e02
serial: <filter>
Device-3: 1-9:61 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 2-4:2 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 44.0 C pch: 44.0 C mobo: 33.0 C
Fan Speeds (rpm): cpu: 1927
Packages: 1211 pm: pacman pkgs: 1203 libs: 327 tools: pamac pm: flatpak
pkgs: 8
1: https://manjaro.mirrors.lavatech.top/testing/$repo/$arch
2: https://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
3: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
4: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 278
1: cpu: 22.1% command: ./mullvadbrowser.real pid: 154269
mem: 490.4 MiB (6.4%)
2: cpu: 14.2% command: mullvadbrowser.real pid: 154482
mem: 264.1 MiB (3.4%)
3: cpu: 5.6% command: mullvadbrowser.real pid: 154954
mem: 252.5 MiB (3.3%)
4: cpu: 3.0% command: mullvadbrowser.real pid: 154414
mem: 167.3 MiB (2.2%)
5: cpu: 2.7% command: mullvadbrowser.real pid: 154473
mem: 198.6 MiB (2.6%)
Memory top: 5 of 278
1: mem: 1272.1 MiB (16.7%) command: audiotube pid: 110445 cpu: 1.0%
2: mem: 501.2 MiB (6.5%) command: plasmashell pid: 1151 cpu: 0.4%
3: mem: 490.4 MiB (6.4%) command: ./mullvadbrowser.real pid: 154269
cpu: 22.1%
4: mem: 264.1 MiB (3.4%) command: mullvadbrowser.real pid: 154482
cpu: 14.2%
5: mem: 252.5 MiB (3.3%) command: mullvadbrowser.real pid: 154954
cpu: 5.6%
Processes: 278 Power: uptime: 5d 23h 55m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 40 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 2.95 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Bash (su) v: 5.3.3 running-in: konsole
inxi: 3.3.39
