Error when doing kernel update
I am getting these errors.
  1. Don’t know what I did to cause this.
  2. Don’t know how to fix it.
Error! nvidia/560.35.03: Missing the module source directory or the symbolic link pointing to it.
Manual intervention is required!
Error! vboxhost/7.0.18_OSE: Missing the module source directory or the symbolic link pointing to it.
Would Appreciate some guidance, thanks in advance.
Here is some system info to help:
[demo@Manjaro ~]$ inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.12.0-rc5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet
    udev.log_priority=3 libata.noacpi=1
  Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
    wm: kwin_x11 tools: xscreensaver,xscreensaver-systemd vt: 2 dm: SDDM
  Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 863F v: 54.24 serial: <superuser required>
    part-nu: 7UT64UA#ABA uuid: <superuser required> UEFI: AMI v: F.32
    date: 12/08/2023
  ID-1: BAT0 charge: 53.6 Wh (100.0%) condition: 53.6/53.6 Wh (100.0%)
    volts: 12.8 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: full cycles: 253
  System RAM: total: 16 GiB available: 15.26 GiB used: 5.08 GiB (33.3%)
  Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A1K43CB1-CTD
    serial: <filter>
  Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
    size: 8 GiB speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1K43CB1-CTD serial: <filter>
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xFC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 36812
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
    class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard driver: N/A
    alternate: nouveau non-free: 550.xx+ status: current (as of 2024-09;
    EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 3b:00.0
    chip-ID: 10de:1d13 class-ID: 0302
  Device-3: Chicony HP Wide Vision FHD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b67b
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.3
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 300 s-size: 325x182mm (12.80x7.17")
    s-diag: 372mm (14.66")
  Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
    hz: 60 dpi: 284 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green: x: 0.310
    y: 0.608 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 3840x2160
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 7.45 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 5 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2) driver: mesa intel v: 24.2.5-arch1.1
    device-ID: 8086:9b41 surfaces: xcb,xlib
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
  API: ALSA v: k6.12.0-rc5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 931.51 GiB used: 285.44 GiB (30.6%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
  ID-1: / raw-size: 163 GiB size: 160.13 GiB (98.24%) used: 59.08 GiB (36.9%)
    fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: Manjaro
    uuid: 45ca132d-4a37-4dc3-afa0-be2e80d6a4a2
  ID-2: /boot/efi raw-size: 499 MiB size: 498 MiB (99.80%)
    used: 72.1 MiB (14.5%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 385A-127E
  ID-3: /home raw-size: 382.57 GiB size: 375.5 GiB (98.15%)
    used: 226.29 GiB (60.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: Data for Manjaro uuid: 1f7a0eb8-f3e9-46ef-a88a-e3ae0ed0233d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p10 maj-min: 259:10 size: 2 GiB fs: ext4 label: N/A
    uuid: 7b881044-e7f4-4adb-8f7c-03a4bf158c1a
  ID-3: /dev/nvme0n1p11 maj-min: 259:11 size: 16 GiB fs: swap label: N/A
    uuid: 24f2c822-affd-40ce-a183-d76c98c31df5
  ID-4: /dev/nvme0n1p12 maj-min: 259:12 size: 3 MiB fs: ufs label: N/A
    uuid: 6354a81a1b0b8929
  ID-5: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
  ID-6: /dev/nvme0n1p4 maj-min: 259:4 size: 218.98 GiB fs: ntfs label: N/A
    uuid: EAEA681CEA67E375
  ID-7: /dev/nvme0n1p5 maj-min: 259:5 size: 961 MiB fs: ntfs label: N/A
    uuid: 863E127D3E126709
  ID-8: /dev/nvme0n1p6 maj-min: 259:6 size: 90 GiB fs: ext4 label: N/A
    uuid: d702f568-b918-4354-874a-f1d82eaf1f37
  ID-9: /dev/nvme0n1p9 maj-min: 259:9 size: 57 GiB fs: ext4 label: Arch Linux
    uuid: 91f4ccdf-2376-48ab-a390-91ea0bc4b02a
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: MosArt 2.4G Keyboard Mouse type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:5918 class-ID: 0301
  Device-2: 1-5:3 info: Chicony HP Wide Vision FHD Camera type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
  Device-3: 1-9:4 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:00bb class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 55.0 C pch: 53.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1786 libs: 348 tools: pamac,yay
    1: https://volico.mm.fcix.net/manjaro/unstable/$repo/$arch
    2: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
    3: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
    5: https://ridgewireless.mm.fcix.net/manjaro/unstable/$repo/$arch
    6: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
    7: http://mirror.fcix.net/manjaro/unstable/$repo/$arch
    8: https://ohioix.mm.fcix.net/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 259
  1: cpu: 17.9% command: vivaldi-bin pid: 1815 mem: 264.2 MiB (1.6%)
  2: cpu: 13.2% command: vivaldi-bin pid: 1771 mem: 142.5 MiB (0.9%)
  3: cpu: 8.4% command: clamd pid: 746 mem: 1351.2 MiB (8.6%)
  4: cpu: 7.0% command: kwin_x11 pid: 1127 mem: 225.5 MiB (1.4%)
  5: cpu: 6.7% command: vivaldi-bin pid: 1571 mem: 476.1 MiB (3.0%)
  Memory top: 5 of 259
  1: mem: 1351.2 MiB (8.6%) command: clamd pid: 746 cpu: 8.4%
  2: mem: 476.1 MiB (3.0%) command: vivaldi-bin pid: 1571 cpu: 6.7%
  3: mem: 437.3 MiB (2.7%) command: plasmashell pid: 1170 cpu: 3.9%
  4: mem: 356.5 MiB (2.2%) command: vivaldi-bin pid: 1776 cpu: 2.5%
  5: mem: 264.2 MiB (1.6%) command: vivaldi-bin pid: 1815 cpu: 17.9%
  Processes: 259 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
    image: 6.08 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 256
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: alacritty inxi: 3.3.36
Is this with testing or unstable branch?
When I install kernel 6.12 on stable branch, I get:
linux612-6.12.0rc2-2
sudo mhwd-kernel -i linux612
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
Packages (2) linux612-6.12.0rc2-2  linux612-headers-6.12.0rc2-2
Total Download Size:   174.33 MiB
Total Installed Size:  746.87 MiB
:: Proceed with installation? [Y/n] n
You have 6.12.0-rc5-1
Do you have the headers installed - or the correct Nvidia and vbox modules matching your kernel version?
I am on unstable.
Yes headers are installed.
[demo@Manjaro ~]$ sudo pacman -S linux612 linux612-headers
[sudo] password for demo:
warning: linux612-6.12.0rc5-1 is up to date -- reinstalling
warning: linux612-headers-6.12.0rc5-1 is up to date -- reinstalling
Packages (2) linux612-6.12.0rc5-1  linux612-headers-6.12.0rc5-1
I will check if the correct modules are installed.
stable 6.12.0rc2-2
testing 6.12.0rc4-1
unstable 6.12.0rc5-1
@MAYBL8
I recall a recent mention that VirtualBox in Testing solves a few issues; perhaps it’s time to switch.
I think I am current on my installed packages.
[demo@Manjaro ~]$ pacman -Q virtualbox
virtualbox 7.1.4-1
[demo@Manjaro ~]$
[demo@Manjaro ~]$ pacman -Q nvidia
linux611-nvidia 560.35.03-19
I think I need to get rid of the old modules?
Can I get some help with doing that?
Seems like I have had this issue before.
I’ve got to document where these things are.
Thanks
Will this help:
[demo@Manjaro ~]$ dkms status
nvidia/555.58.02: broken
Error! nvidia/555.58.02: Missing the module source directory or the symbolic link pointing to it.
nvidia/560.35.03: broken
vboxhost/7.0.18_OSE: broken
vboxhost/7.0.20_OSE: broken
Error! vboxhost/7.0.20_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.1.2_OSE: broken
Error! vboxhost/7.1.2_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.1.4_OSE, 6.10.14-1-MANJARO, x86_64: built
vboxhost/7.1.4_OSE, 6.11.5-1-MANJARO, x86_64: installed
vboxhost/7.1.4_OSE, 6.12.0-rc5-1-MANJARO, x86_64: installed
Do I just need to remove old files from here:
[demo@Manjaro lib]$ cd dkms
[demo@Manjaro dkms]$ ls
mok.key  mok.pub  nvidia  vboxhost
[demo@Manjaro dkms]$ cd nvidia
[demo@Manjaro nvidia]$ ls
550.54.14  555.58.02  560.35.03  kernel-6.11.1-1-MANJARO-x86_64  original_module
[demo@Manjaro nvidia]$ cd ..
[demo@Manjaro dkms]$ cd vboxhost
[demo@Manjaro vboxhost]$ ls
7.0.18_OSE  7.1.2_OSE  kernel-6.11.5-1-MANJARO-x86_64      kernel-6.6.10-1-MANJARO-x86_64  original_module
7.0.20_OSE  7.1.4_OSE  kernel-6.12.0-rc5-1-MANJARO-x86_64  kernel-6.6.11-1-MANJARO-x86_64
