buildiso -p gnome
/usr/lib/manjaro-tools/util-iso.sh: line 201: syntax error near unexpected token `<<<'
/usr/lib/manjaro-tools/util-iso.sh: line 201: `<<<<<<< HEAD'
/usr/sbin/buildiso: line 203: check_requirements: command not found
/usr/lib/manjaro-tools/util.sh: line 804: build: command not found
==> ERROR: An unknown error has occurred. Exiting...
User defined signal 1
I wonder if it is a bug with the manjaro-tools package.
Edit: Using manjaro-tools-iso 0.15.12-5 + manjaro-tools.base 0.15.12-1 + manjaro-tools-okg 0.15.12-1
Hi. I am not looking to build an ARM version but a desktop one as explained here Manjaro-tools - Manjaro - being doing that for the past 2+ years and all worked fine except now after I updated to the latest Manjaro Stable release. It worked before that.
