Error updating packages/softwares and etc
I can’t seem to update my system using sudo pacman -Syyu, it returns an error of ‘failed to synchronize all databases (invalid or corrupted database (PGP signature))’
This just happened today.
The exact error in the terminal is:
error: GPGME error: No data
core 140.5 KiB 207 KiB/s 00:01 [##############################] 100%
extra 7.9 MiB 6.19 MiB/s 00:01 [##############################] 100%
multilib 142.0 KiB 216 KiB/s 00:01 [##############################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
What I tried :
sudo pacman -Scc
sudo pacman -Syyu
–same result
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
sudo pacman -Syyu
–same result
Any other tips? I am also facing an error when I update it via Add/Remove Software
Note: The only workaround for me to update is to set the SigLevel to ‘Never’ in pacman.conf
I also followed this advise to no avail:
1st file
Refresh keyring when corrupt
sudo rm -rf /etc/pacman.d/gnupg
sudo rm -R /root/.gnupg/
Manjaro
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
2nd file
Remove packages from cache? No
sudo pacman -Sc
sudo pacman -Syyu
Did you try to open Pamac (GUI) and click TOP Right drop down menue> Refresh Data Base?
Doesn’t sudo pacman -Syyu downgrade packages?
sudo pacman -Syu is the update command?
No.
look at
man pacman
to see what -yy actually does
yes
Just reading the man now. what a rabbit hole for me. Thanks
yeah, it works - as long as the ‘Siglevel’ is set to Never. But if it’s in the Required DatabaseOptional - it wouldn’t work. I really don’t want to change it every time I upgrade, I can leave it to ‘never’ but I’ve read somewhere that it is not recommended to do so.
pacman -Syu > refreshes repo that needs to be refreshed, saving bandwidth from both sides.
pacman -Syyu> refreshes all repo, and is not reco to use, however, it’s fine if something screwy is going on. The functionality is there for a reason. Just don’t use it regularly, only when needed.
The error when I tried updating via GUI is 'invalid or corrupted database (PGP signature)
Failed to synchronize databases
This has been going on for a week now - I’m considering to have a fresh install instead :confused:
This can be remedied easily.
Look for it here in the forum.
Has been asked and discussed like a million times only.
Please see this guide below… :point_down:
I’ll try this out! Will give an update on this thread
Search results for ‘invalid or corrupted database (PGP signature)’ status:solved - Manjaro Linux Forum
it worked, thanks!
