Hey, I just installed manjaro i3 (community version), and I restart and everything works fine.
I restart again and choose windows boot manager and it works.
Then I restart and when I boot I get
“error: unknown filesystem
Entering rescue mode…
grub rescue>” (grub for some reason goes into rescue mode after booting into windows boot manager once)
I have tried reinstalling manjaro and manually partitioning too instead of using the auto side by side install on calamares but I have the same issue.
what should I do?
tl;dr - booting into windows causes grub to stop working, tried reinstalling and manual partitioning
Also, if I run ls (like recommended on other similar posts) I get:
(hd0) (hd0,gpt5) (hd0,gpt4) (hd0,gpt3) (hd0,gpt2) (hd0,gpt1)
But then if I try to ls any of these partitions I get “error:unknown filesystem”, so it isn’t even recognising my Manjaro install partition? I had the same issue with the last install (where it was auto partition using calamares)
