Hey there,
i’m using Manjaro quite a while now and am very happy with it.
One of my other hobbies is Astronomy. Therefore i use the Stellarium-package from the AUR. Installation worked fine and the general usage is ok too.
But when i try to delete one of the custom telescopes from the list the programm crashes and i get an coredump error.
journalctl shows the following line at the time of the crash:
kernel: stellarium[3676]: segfault at 7fcb86d66c58 ip 00007fcb6e378125 sp 00007fffd97017d0 error 4 in libQt5Widgets.so.5.15.5[7fcb6e1d1000+3c4000]
So i looked closer on the coredump-process:
coredumpctl info 3676 | less generates the following output (very long, although already shortened):
PID: 3676 (stellarium)
UID: 1000 (flo)
GID: 1000 (flo)
Signal: 11 (SEGV)
Timestamp: Sat 2022-09-10 14:22:15 CEST (18min ago)
Command Line: stellarium
Executable: /usr/bin/stellarium
Control Group: /user.slice/user-1000.slice/session-2.scope
Unit: session-2.scope
Slice: user-1000.slice
Session: 2
Owner UID: 1000 (flo)
Boot ID: d133935c3b8e488bad6fd6ed53fb0f00
Machine ID: 4f16143f847c4c1386feecc9ceccbd0d
Hostname: flo-mika-gulfi
Storage: /var/lib/systemd/coredump/core.stellarium.1000.d133935c3b8e488bad6fd6ed53fb0f00.3676.1662812535000000.zst (present)
Disk Size: 48.7M
Message: Process 3676 (stellarium) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 15c48e8c72ad1b981d55e5c548007224f45150b1
Module libqnmbearer.so with build-id b1cbd6f2376017b756fb782fc9a325314e4c35e6
Module libqgenericbearer.so with build-id 323ed9b1016288ff8521d212b1e5e0bd4ab9ced0
Module libqconnmanbearer.so with build-id ea8573fa44b30d7d473702b24f7b4eddfc3d86b7
Module libQt5Svg.so.5 with build-id 1638765a4fe9b14d115a5ca30e949fd90a9ac82c
Module libqsvg.so with build-id 1ea8dae592b5b30f762efe2794b79f44e735dce5
Module libQt5Pdf.so.5 with build-id d5f89f2a0606639128d32d9d194443e7649a9879
Module libqpdf.so with build-id 3f9760fc8f5a9001f7ed48587e4140077230b634
Module libqjpeg.so with build-id 9c4bed3debf5080c1483666c6d9d590d9007cd0d
Module libqico.so with build-id 09e8beae999de04e1e49ba9d51dea9323de94b6b
Module libqgif.so with build-id 51881447eb4f6e9a55bb6a1036b146048a7baa58
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libvulkan.so.1 with build-id dd97393da4f886994c9dfc153b35ea6d906f57ff
Module libdrm_nouveau.so.2 with build-id 78e99e753be2b598acf02a6f30bc6615a6a3067f
Module libdrm_amdgpu.so.1 with build-id e03ead624f04700b1fd00df43863fecfb1ff8b72
Module libelf.so.1 with build-id 5ba0792747dce7480d031794ed90c620da72dbff
Module libdrm_radeon.so.1 with build-id 5c9c31961c5f0dd9b40cb3e134b8d9189ee59fbb
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-14.so with build-id 16d23f3ab6fb7269b2f13a9932a2a7ec4b1d5104
Module iris_dri.so with build-id 247f930d52c9b9e6d6e140462136d983b0b617da
Module libxshmfence.so.1 with build-id d9b3ce4edb0b6a0818bcc57dda020d2da5e3c895
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libXxf86vm.so.1 with build-id b8b37b0c66be0a760a8491e3c86a00c4efdc825d
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libglapi.so.0 with build-id a5ca7bec18ce3ff85c63b88bd43a7884ea95a1f7
Module libGLX_mesa.so.0 with build-id 6721ac15576bf0a0a4d5a29429915cb88cdf5426
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libqxcb-glx-integration.so with build-id e2c0419868b0bab893535ae4aaff94fc2e27d64a
Module libcomposeplatforminputcontextplugin.so with build-id 0be5cf4dd6f619507419c05cd608577e092c78fb
Module libqt5ct.so with build-id 9417235459a81cdac223a735568ecc7aef5a4d3f
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module stellarium with build-id 6e2d829f24526b7b071b592715f9849e483eb492
Stack trace of thread 3676:
#0 0x00007fcb6e378125 n/a (libQt5Widgets.so.5 + 0x30d125)
#1 0x00007fcb6e378eb1 _ZN16QDialogButtonBox11changeEventEP6QEvent (libQt5Widgets.so.5 + 0x30deb1)
#2 0x00007fcb6e219d9f _ZN7QWidget5eventEP6QEvent (libQt5Widgets.so.5 + 0x1aed9f)
#3 0x00007fcb6e1e3b3c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b3c)
#4 0x00007fcb6d209ad8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cad8)
#5 0x00007fcb6e2102a3 _ZN14QWidgetPrivate15setStyle_helperEP6QStyleb (libQt5Widgets.so.5 + 0x1a52a3)
#6 0x00007fcb6e21b425 _ZN7QWidget9setParentEPS_6QFlagsIN2Qt10WindowTypeEE (libQt5Widgets.so.5 + 0x1b0425)
#7 0x00007fcb6e1fd06e _ZN14QLayoutPrivate20reparentChildWidgetsEP7QWidget (libQt5Widgets.so.5 + 0x19206e)
#8 0x00007fcb6e215f18 _ZN7QWidget9setLayoutEP7QLayout (libQt5Widgets.so.5 + 0x1aaf18)
#9 0x00007fcb6e4198cb n/a (libQt5Widgets.so.5 + 0x3ae8cb)
#10 0x00007fcb6e41a1c2 n/a (libQt5Widgets.so.5 + 0x3af1c2)
#11 0x00007fcb6e41b009 _ZN11QMessageBoxC1ENS_4IconERK7QStringS3_6QFlagsINS_14StandardButtonEEP7QWidgetS4_IN2Qt10WindowTypeEE (libQt5Widgets.so.5 + 0x3b0009)
#12 0x00007fcb6e41b632 n/a (libQt5Widgets.so.5 + 0x3b0632)
#13 0x0000562ad58f658a n/a (stellarium + 0x31358a)
#14 0x0000562ad5e44e90 n/a (stellarium + 0x861e90)
#15 0x00007fcb6d23a378 n/a (libQt5Core.so.5 + 0x2bd378)
#16 0x00007fcb6e2c7517 _ZN15QAbstractButton7clickedEb (libQt5Widgets.so.5 + 0x25c517)
#17 0x00007fcb6e2c9d7a n/a (libQt5Widgets.so.5 + 0x25ed7a)
#18 0x00007fcb6e2cb2bd n/a (libQt5Widgets.so.5 + 0x2602bd)
#19 0x00007fcb6e2cb460 _ZN15QAbstractButton17mouseReleaseEventEP11QMouseEvent (libQt5Widgets.so.5 + 0x260460)
#20 0x00007fcb6e21a707 _ZN7QWidget5eventEP6QEvent (libQt5Widgets.so.5 + 0x1af707)
#21 0x00007fcb6e1e3b3c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b3c)
#22 0x00007fcb6e1e9359 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x17e359)
#23 0x00007fcb6d209ad8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cad8)
#24 0x00007fcb6e1e7357 _ZN19QApplicationPrivate14sendMouseEventEP7QWidgetP11QMouseEventS1_S1_PS1_R8QPointerIS0_Ebb (libQt5Widgets.so.5 + 0x17c357)
#25 0x00007fcb6e4f8fac n/a (libQt5Widgets.so.5 + 0x48dfac)
#26 0x00007fcb6e4e8a24 _ZN13QGraphicsItem10sceneEventEP6QEvent (libQt5Widgets.so.5 + 0x47da24)
#27 0x00007fcb6e50102a n/a (libQt5Widgets.so.5 + 0x49602a)
#28 0x00007fcb6e50bd2e _ZN14QGraphicsScene17mouseReleaseEventEP24QGraphicsSceneMouseEvent (libQt5Widgets.so.5 + 0x4a0d2e)
#29 0x00007fcb6e509e02 _ZN14QGraphicsScene5eventEP6QEvent (libQt5Widgets.so.5 + 0x49ee02)
#30 0x00007fcb6e1e3b3c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b3c)
#31 0x00007fcb6d209ad8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cad8)
#32 0x00007fcb6e5322fe _ZN13QGraphicsView17mouseReleaseEventEP11QMouseEvent (libQt5Widgets.so.5 + 0x4c72fe)
#33 0x00007fcb6e21a707 _ZN7QWidget5eventEP6QEvent (libQt5Widgets.so.5 + 0x1af707)
#34 0x00007fcb6e2c8813 _ZN6QFrame5eventEP6QEvent (libQt5Widgets.so.5 + 0x25d813)
#35 0x00007fcb6d209742 _ZN23QCoreApplicationPrivate29sendThroughObjectEventFiltersEP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c742)
#36 0x00007fcb6e1e3b2c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b2c)
#37 0x00007fcb6e1e9359 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x17e359)
#38 0x00007fcb6d209ad8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cad8)
#39 0x00007fcb6e1e7357 _ZN19QApplicationPrivate14sendMouseEventEP7QWidgetP11QMouseEventS1_S1_PS1_R8QPointerIS0_Ebb (libQt5Widgets.so.5 + 0x17c357)
#40 0x00007fcb6e2383d5 n/a (libQt5Widgets.so.5 + 0x1cd3d5)
#41 0x00007fcb6e23a17e n/a (libQt5Widgets.so.5 + 0x1cf17e)
#42 0x00007fcb6e1e3b3c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b3c)
#43 0x00007fcb6d209ad8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cad8)
#44 0x00007fcb6da4002c _ZN22QGuiApplicationPrivate17processMouseEventEPN29QWindowSystemInterfacePrivate10MouseEventE (libQt5Gui.so.5 + 0x13f02c)
#45 0x00007fcb6da29935 _ZN22QWindowSystemInterface22sendWindowSystemEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Gui.so.5 + 0x128935)
#46 0x00007fcb51d7ea30 n/a (libQt5XcbQpa.so.5 + 0x63a30)
#47 0x00007fcb6369fc6b g_main_context_dispatch (libglib-2.0.so.0 + 0x54c6b)
#48 0x00007fcb636f6001 n/a (libglib-2.0.so.0 + 0xab001)
#49 0x00007fcb6369d392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#50 0x00007fcb6d25432c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d732c)
#51 0x00007fcb6d20227c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28527c)
#52 0x00007fcb6d20cda9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fda9)
Stack trace of thread 3684:
#0 0x00007fcb6cab3346 n/a (libc.so.6 + 0x83346)
#1 0x00007fcb6cab5b60 pthread_cond_wait (libc.so.6 + 0x85b60)
#2 0x00007fcb4a6bbc7c n/a (iris_dri.so + 0xb2c7c)
#3 0x00007fcb4a6b537c n/a (iris_dri.so + 0xac37c)
#4 0x00007fcb6cab678d n/a (libc.so.6 + 0x8678d)
#5 0x00007fcb6cb378e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 3682:
Stack trace of thread 3678:
Stack trace of thread 3689:
#0 0x00007fcb6cb2ae9f __poll (libc.so.6 + 0xfae9f)
#1 0x00007fcb636f5f68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2 0x00007fcb6369d392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3 0x00007fcb6d25432c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d732c)
#4 0x00007fcb6d20227c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28527c)
#5 0x00007fcb6d06449f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#6 0x00007fcb6d0612ca n/a (libQt5Core.so.5 + 0xe42ca)
#7 0x00007fcb6cab678d n/a (libc.so.6 + 0x8678d)
#8 0x00007fcb6cb378e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 3679:
Stack trace of thread 3685:
Stack trace of thread 3690:
#1 0x00007fcb6cab5e64 pthread_cond_timedwait (libc.so.6 + 0x85e64)
#2 0x00007fcb6d0686d4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb6d4)
Seems to be a problem with Qt5. I don’t have much experience with it. Does anybody has an idea for a solution?
Best,
Florian
