Hi,
I am using Manjaro from VirtualBox, my host system is Windows 10. I had problems upgrading the system using the GUI, then I tried with the terminal and I saw:
[angelc@manjaro ~]$ sudo pacman -Syu
[sudo] password for angelc:
error: GPGME error: No data
core 167.7 KiB 141 KiB/s 00:01 [################################################] 100%
extra 1899.9 KiB 2.03 MiB/s 00:01 [################################################] 100%
community 6.9 MiB 3.93 MiB/s 00:02 [################################################] 100%
multilib 174.3 KiB 1025 KiB/s 00:00 [################################################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
So I followed other post (don’t remember where I saw it) and did:
sudo rm -f /var/lib/pacman/sync/*
sudo pacman -Syyu
then, I could upgrade, but I saw:
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-5.15-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
error: command failed to execute correctly
(13/33) Updating Kernel initcpios for Nvidia-DRM...
this seems to be a similar problem to /t/black-screen-error-after-kernel-version-change/65989/6
the information provided in that post, in my case is:
[angelc@manjaro ~]$ inxi -Fza
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6c5e4343-9974-43d4-952b-8039846c56b9 rw quiet splash apparmor=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Virtualbox System: innotek product: VirtualBox v: 1.2
serial: <superuser required> Chassis: Oracle Corporation type: 1
Mobo: Oracle model: VirtualBox v: 1.2 serial: <superuser required>
BIOS: innotek v: VirtualBox date: 12/01/2006
ID-1: BAT0 charge: 48.5 Wh (97.0%) condition: 50.0/50.0 Wh (100.0%)
volts: 10.0 min: 10.0 model: innotek 1 type: Unknown serial: N/A
status: N/A
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0x6000626
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3294 min/max: N/A cores: 1: 3294 2: 3294 3: 3294
4: 3294 5: 3294 6: 3294 7: 3294 8: 3294 bogomips: 52720
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.19.0.0 bus-ID: 00:02.0
chip-ID: 15ad:0405 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: vmware unloaded: modesetting alternate: fbdev,vesa
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A port: N/A bus-ID: 00:07.0 chip-ID: 8086:7113
class-ID: 0680
Device-3: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel
port: d240 bus-ID: 00:08.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s8 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 512 GiB used: 278.95 GiB (54.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 512 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1.0 scheme: MBR
ID-1: / raw-size: 512 GiB size: 502.89 GiB (98.22%) used: 34.16 GiB (6.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
Message: No sensor data found. Is lm-sensors configured?
Processes: 305 Uptime: 4d 23h 12m wakeups: 62838 Memory: 24.46 GiB
used: 9.78 GiB (40.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1347 lib: 304 flatpak: 0
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
[angelc@manjaro ~]$
[angelc@manjaro ~]$
[angelc@manjaro ~]$ sudo mhwd-kernel -li
Currently running: 5.15.7-1-MANJARO (linux515)
* linux515
[angelc@manjaro ~]$ sudo ls /etc/mkinitcpio.d/*.preset
when I restart, after the upgrade, the machine takes me to a blue memtest
screen, it seems unable to find the kernel. Given that I am using a virtual machine, I can take a snapshot before restarting and get back to the point after the upgrade, BTW I also have a snapshot before the upgrade and another before the rm -f /var/lib/pacman/sync/*
line. I am not sure if what was done in the post above also would apply to me.
Cheers.
