Error. Socket doesn't exit. Is daemon running?
Hi
Im new to the forum so sorry if wrong category
I tried downloading this (cant post links)
razer-laptop-control-git
razer-laptop-control-dkms-git
the download went perfecty fine. but when i try to execute the command i get the error : Error. Socket doesn’t exit. Is daemon running? and i honestly dont know how to fix this
the command i used was ‘‘razer-cli help’’ wich is a command. this should display the other commands i can use to change RGB/fan/power control. the controls for the RGB/fan/power control give the same error
Kind regards.
MagicGnome
That should give you a clue that it requires a background service to run.
pacman -Ql razer-laptop-control-git | grep service
You’ll see there is one. You can enable it to start on boot and start it now with one command:
systemctl enable --now razerdaemon
executed both commands and it still gives the same error
kind regards
MagicGnome
What’s the output of:
systemctl status razerdaemon
This is the output of the command
sorry for the late reply
● razerdaemon.service - Razer laptop control daemon
Loaded: loaded (/etc/systemd/system/razerdaemon.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-04-11 18:34:06 CEST; 28s ago
Main PID: 455 (daemon)
Tasks: 1 (limit: 19026)
Memory: 932.0K
CGroup: /system.slice/razerdaemon.service
└─455 /usr/share/razercontrol/daemon
apr 11 18:34:25 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:26 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:27 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:28 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:29 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:30 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:31 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:32 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:33 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
apr 11 18:34:34 casperbruning-blade15basemodelearly2021rz090369 daemon[455]: Waiting for sysfs to be ready
Kind regards
MagicGnome
There’s an open issue about it:
Thank you! i will look into it
Kind regards
MagicGnome
