[Error] snapd: A failure ocurred in build()
I was trying to install neovim from snapd. following this tutorial:
snapcraft.io/install/nvim/arch
commands used:
$ git clone https://aur.archlinux.org/snapd.git
$ cd snapd
$ makepkg -si
==> Starting build()...
*** Setting version to '2.50-1' from user.
# pkg-config --cflags  -- libseccomp libseccomp
pkg-config: exec: "pkg-config": executable file not found in $PATH
==> ERROR: A failure occurred in build().
    Aborting...
There weren’t any errors in the previous steps. The last part is the error message I get. how could it be solved? Thanks in advance.
neovim is in the regular Community repository. :arrow_down:
sudo pacman -S neovim
Did you install what is neede dto build AUR packages?
sudo pacman -Syu base-devel --needed
As @Aragorn mentioned, neovim is in the repositories, so the easiest way would be installing it from there.
If you definitely want to install it as a snap package then you’ll have to deal with this issue
probably caused because you don’t have the package pkgconf (part of the base-devel group) installed.
You can eather install it separately
sudo pacman -Syu pkgconf
or install all packages from the base-devel group that are needed in your system (including pkgconf)
and then retry to install neovim as a snap package.
For more information about AUR and the base-devel group, see here:
https://wiki.archlinux.org/title/Arch_User_Repository#Prerequisites
Am I missing something? Why are you building SnapD? Can’t you install Snaps from Pamac?
//EDIT: Just in case…
  • install pamac-snap-plugin
  • enable Snap support in Pamac Preferences
  • search neovim in Pamac
  • install neovim from Pamac as a Snap
Or…
  • install neovim from Manjaro Repository
