Hello everyone, I’m getting this error both at shutdown and boot and on top of that they are extremely slow (~20 seconds for boot and 10 for shutdown). As suggested in other posts and since I don’t need Hibernation I:
Disabled Hibernation by adding the /etc/systemd/sleep.conf.d/no-hibernate.conf and /etc/systemd/logind.conf.d/no-hibernate.conf files
Removed resume parameters at /etc/default/grub:GRUB_CMDLINE_LINUX_DEFAULT and /etc/mkinitcpio.conf:HOOKS
I only have swap, efi and root partitions and this is my etc/default/grub:
Enabling/disabling secure or fast boot doesn’t seem to make any difference.
Also I don’t have anything on the side to dual boot so I wouldn’t mind ditching grub completely and boot directly in the system but I don’t if that can be done. And why does this pop up at shutdown? What is it trying to do when shutting down that involves hibernation?
I’ll try that but everything else works fine. Also I forgot to mention, before the error message started appearing boot was even slower and the computer logo (msi) appeared and disappeared 3 times during boot and 2 times at shutdown
In the end I managed to get rid of the errors and get faster boot by removing all unnecessary hooks and modules from /etc/mkinitcpio.conf, keeping only:
MODULES="ahci sd_mod ext4 i2c_dev"
HOOKS="base udev"
and adding: COMPRESSION="cat"
In /etc/default/grub I also added noresume at GRUB_CMDLINE_LINUX_DEFAULT
sudo mkinitcpio -P and updated grub and the boot is cool now. I still have the problem with the slow shutdown (which is in fact caused by slow logout because the logout is as slow as the full shutdown) and oem logo flashing 2 times at logout (KDE)
