As said above, bluetooth fails to connect to a pair of Sony WF-C700N headphones that work just fine in my phone and windows partition. So far I’ve tried restarting the service, reinstalling bluez, connecting through bluetoothctl, etc.
Error message:
bluetoothctl
Agent registered
[bluetooth]# connect 30:53:C1:D7:B1:60
Attempting to connect to 30:53:C1:D7:B1:60
[CHG] Device 30:53:C1:D7:B1:60 Connected: yes
Failed to connect: org.bluez.Error.Failed br-connection-aborted-by-local
[CHG] Device 30:53:C1:D7:B1:60 Connected: no
Some system info:
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=40b2af31-0ad2-45f1-9d2b-15a0aff15ebc rw quiet splash apparmor=1
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706QM v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FA706QM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: FA706QM.314 date: 01/07/2023
ID-1: BAT1 charge: 67.0 Wh (100.0%) condition: 67.0/90.2 Wh (74.2%)
volts: 16.8 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 7 5800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1450 high: 3200 min/max: 1200/4462 boost: enabled
base/boost: 3200/4450 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3200 2: 1200 3: 1200 4: 1200
5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 3200 11: 1200 12: 1200 13: 1200
14: 1200 15: 1200 16: 1200 bogomips: 102244
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 53.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x8294 built: 2020
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.49 6.1.55-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
unified: no
Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.81 status: n/a (root, process) with:
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 13d3:3563
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 953.87 GiB used: 145.39 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 601.56 GiB size: 591.05 GiB (98.25%)
used: 145.36 GiB (24.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 25.4 MiB (26.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 61.1 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): cpu: 0
Processes: 372 Uptime: 16m wakeups: 7 Memory: total: 16 GiB note: est.
available: 15.03 GiB used: 4.97 GiB (33.1%) Init: systemd v: 254
Packages: 1607 pm: pacman pkgs: 1596 libs: 465
tools: gnome-software,pamac,yay pm: flatpak pkgs: 11 Shell: Sudo (sudo)
v: 1.9.14p3 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.30
I really can’t find any info online about this error. Might it just be that the headphones are refusing to work with Linux? They’ve worked intermittently in the past (sorry I can’t specify more as to when or how). Any help would be much appreciated
