I am trying to install the kernel: " linux-zen-vfio 5.9.13.zen1-1 " from AUR. (http://aur.archlinux.org/packages/linux-zen-vfio)
However it fails me on prepare() with this error:
==> Starting prepare()...
Setting version...
Applying patch add-acs-overrides.patch...
can't find file to patch at input line 53
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|From 169ce1a1bf376ba90cd0ab51ec19f9e32ead9dcb Mon Sep 17 00:00:00 2001
|Date: Wed, 6 May 2020 15:40:50 -0400
|Subject: [PATCH] pci: Enable overrides for missing ACS capabilities (5.6.9+)
|This an updated version of Alex Williamson's patch from:
|https://lkml.org/lkml/2013/5/30/513
|Original commit message follows:
|PCIe ACS (Access Control Services) is the PCIe 2.0+ feature that
|allows us to control whether transactions are allowed to be redirected
|in various subnodes of a PCIe topology. For instance, if two
|endpoints are below a root port or downsteam switch port, the
|downstream port may optionally redirect transactions between the
|devices, bypassing upstream devices. The same can happen internally
|on multifunction devices. The transaction may never be visible to the
|upstream devices.
|One upstream device that we particularly care about is the IOMMU. If
|a redirection occurs in the topology below the IOMMU, then the IOMMU
|cannot provide isolation between devices. This is why the PCIe spec
|encourages topologies to include ACS support. Without it, we have to
|assume peer-to-peer DMA within a hierarchy can bypass IOMMU isolation.
|Unfortunately, far too many topologies do not support ACS to make this
|a steadfast requirement. Even the latest chipsets from Intel are only
|sporadically supporting ACS. We have trouble getting interconnect
|vendors to include the PCIe spec required PCIe capability, let alone
|suggested features.
|Therefore, we need to add some flexibility. The pcie_acs_override=
|boot option lets users opt-in specific devices or sets of devices to
|assume ACS support. The "downstream" option assumes full ACS support
|on root ports and downstream switch ports. The "multifunction"
|option assumes the subset of ACS features available on multifunction
|endpoints and upstream switch ports are supported. The "id:nnnn:nnnn"
|option enables ACS support on devices matching the provided vendor
|and device IDs, allowing more strategic ACS overrides. These options
|may be combined in any order. A maximum of 16 id specific overrides
|are available. It's suggested to use the most limited set of options
|necessary to avoid completely disabling ACS across the topology.
|Note to hardware vendors, we have facilities to permanently quirk
|specific devices which enforce isolation but not provide an ACS
|capability. Please contact me to have your devices added and save
|your customers the hassle of this boot option.
|diff --git a/Documentation/admin-guide/kernel-parameters.txt b/Documentation/admin-guide/kernel-parameters.txt
|index fb95fad81c79..0a1e5281809a 100644
|--- a/Documentation/admin-guide/kernel-parameters.txt
|+++ b/Documentation/admin-guide/kernel-parameters.txt
File to patch:
Skip this patch? [y]
Skipping patch.
1 out of 1 hunk ignored
can't find file to patch at input line 72
|diff --git a/drivers/pci/quirks.c b/drivers/pci/quirks.c
|index 2ea61abd5830..025974dfc10a 100644
|--- a/drivers/pci/quirks.c
|+++ b/drivers/pci/quirks.c
File to patch:
Skipping patch.
2 out of 2 hunks ignored
==> ERROR: A failure occurred in prepare().
Aborting...
I would like to fix it but don’t know how. Could somebody please help me
