Error: multilib.db: GPGME error: No data
Hello guys,
When I want to update/install packages via pacman I receive the following error:
Failed to synchronize databases
I (probably) have tried numerous times updating the keys, removing cached files and refetching the mirrors.
Yes, I am indeed quite new to manjaro. I also did loads of research and reading through forums but none of the suggested solutions that obviously helped others did help me.
If you need any config files or such don’t blame me for not having posted it right away :smiley:
Thanks a lot!
Do you have the same issues with pamac upgrade in the terminal or using pamac gui.
What is the command you typed that gives the error?
only one : pacman.conf :wink:
Alright, thanks a lot for your fast response.
The command I run was:
# pamac update
Warning: Building packages as root
Warning: Setting build directory to /var/cache/pamac
Preparing...
Refreshing core.db...
Nothing to do.
The error occurred also in console.
pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
#ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
I’ll try the posted solution in a sec.
Thanks so far!
comment or remove this line SigLevel !
is not in original
Alright, thanks a lot guys, that did help. Tbh I’m a bit ashamed that I didn’t came across that rather simple solution…
Is there any logical explanation, that out of the middle of nowhere multilib didn’t wanted to function anymore? And is there any disadvantage in having the DataBase SigLevel on DatabaseNever than DatabaseOptional?
Not for the time being.
All packages are signed and this is a requirement as per global settings in pacman.conf thus making database signing unnecessary.
You should read the comment thread for the above root tip as this will provide insight in some of the why’s which undoubtedly arises when encountering such issue…
Please use the codefence button when pasting content of configs/logs as comment char in configs are formatting chars in markdown - generating insane listings.
Select the text pasted and click the </> button in the comment toolbar - not the quote button.
