hello,
i have 2 USB HDDs, both same Model (WD USB3 MyPassport-series 4tb), both formated with NTFS and both have the exact same files and directories on it. I used them on my windows machine and now for over a year with XFCE manjaro (stable branch, i check updates every day). i had never any problems with these drives, i accessed both 2 days ago to copy some files on them without problem.
today i wanted to access them with thuna like i did hundreds of times before and both HDDs cant be mounted anymore, errormessage for both is:
āError mounting /dev /sdc1 (sdd1 the other HDD) at /run/media/USERNAME/WD3 (WD5 the other HDD): wrong fs type, bad option, bad superblock on /dev/sdc1 (sdd1 the other HDD), missing codepage or helper program, or other errorā
so the HDDs are physicaly detected and their names (WD3 and WD5) are also read out correctly.
they are also shown in the gparted software as ntfs partitioned. gparted also shows an info symbol. if i open the info i get the following warning:
"$MFTMirr does not match $MFT (record 3).
Failed to mount ā/dev/sdc1ā: Eingabe-/Ausgabefehler
NTFS is inconsistent. Run chkdsk /f on Windows then reboot it TWICE!
The usage of the /f parameter is very IMPORTANT! No modification was
made to NTFS by this software.
Failed to open ā/dev/sdc1ā.
Failed to mount ā/dev/sdc1ā: Input/output error
Der Inhalt des Dateisystems konnte nicht gelesen werden!
Aufgrund dessen könnten einige Operationen nicht zur Verfügung stehen.
Die Ursache kƶnnte ein fehlendes Softwarepaket sein.
Die folgende Liste zeigt die Softwarepakete, die zur Unterstützung des ntfs-Dateisystems erforderlich sind: ntfs-3g / ntfsprogs."
the data on these HDDs is extremly important for me, so i cant allow myself to ātest around and hope for the bestā, thats why i, before doing things worse in any way, open this thread. does anyone know what to do without risking complete dataloose? is this maybe a known problem, maybe some missing packages in pacman or somehing like this? hope someone can help me
