Sorry about that. My current install is using encryption. I also setup a swap with hibernate support.
Below is the output of the commands:
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0003,0006,0000,0001,0002
Boot0000* UEFI KXG60ZNV1T02 NVMe KIOXIA 1024GB Y09F306PFPF1 1 PciRoot(0x0)/Pci(0x6,0x0)/Pci(0x0,0x0)/NVMe(0x1,8C-E3-8E-05-00-4C-A7-79)/HD(1,GPT,587867a0-b972-6742-8d59-7927b7c45069,0x1000,0x96000)/File(\EFI\Boot\BootX64.efi)N.....YM....R,Y.
Boot0001* USB NIC (IPV4) PciRoot(0x0)/Pci(0xd,0x0)/USB(3,0)/MAC(00e04c0b1dc5,0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.
Boot0002* USB NIC (IPV6) PciRoot(0x0)/Pci(0xd,0x0)/USB(3,0)/MAC(00e04c0b1dc5,0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.
Boot0003* Manjaro HD(1,GPT,587867a0-b972-6742-8d59-7927b7c45069,0x1000,0x96000)/File(\EFI\Manjaro\grubx64.efi)
Boot0006* ubuntu HD(1,GPT,d0695cec-2767-4c32-8fc4-60d30944d9d1,0x800,0x18b000)/File(\EFI\ubuntu\shimx64.efi)
Model: TE USB (scsi)
Disk /dev/sdd: 1050MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 1050MB 1049MB primary fat32 boot
Model: KXG60ZNV1T02 NVMe KIOXIA 1024GB (nvme)
Disk /dev/nvme0n1: 1024GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 1006GB 1006GB
3 1006GB 1024GB 18.2GB
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=CC1A-DD62 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-dd2e8376-4dca-4180-b7bb-f608beac2df3 / ext4 defaults,noatime 0 1
/dev/mapper/luks-3c6c22e4-95e6-466f-93d9-0039ad26ccd2 swap swap defaults,noatime 0 0
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet cryptdevice=UUID=dd2e8376-4dca-4180-b7bb-f608beac2df3:luks-dd2e8376-4dca-4180-b7bb-f608beac2df3 root=/dev/mapper/luks-dd2e8376-4dca-4180-b7bb-f608beac2df3 apparmor=1 security=apparmor resume=/dev/mapper/luks-3c6c22e4-95e6-466f-93d9-0039ad26ccd2 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically
GRUB_ROOT_FS_RO=true
@Wollie - based upon this output, would you recommend I get rid of swap partition and/or encryption?
