Error Installing Zulucrypt
I’m trying to install zulucrypt 6.2.0-1 AUR, on a fresh install computer, and I’m getting the following error:
CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
    Aborting...
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: KDE Plasma v: 5.27.4 Distro: Manjaro Linux base: Arch Linux
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Have you made sure you have the prerequisites for using the AUR installed?
See:
I’m installing it via the system add/remove software. I have installed it on many computers. This is the screenshot of the installed version on my own computer.
zulucrypt
That doesnt answer the question though.
Do you have the 2 packages listed in the very first section of the first link?
@Yochanan & cscs,
I was able to install if after installing the “base-devel”. What’s confusing is that I don’t have “base-devel” installed on any of my computers, and I’ve had no problem installing the zulucrypt without it before! In any case that solved the problem.
Thank you guys,
Previously base-devel was a package group, now it’s a meta package. See Arch Linux - News: Switch to the base-devel meta package requires manual intervention
Got it, thanks.
