Hi all,
after the medium-size upgrade yesterday, RouteConverter (from AUR) cannot be installed anymore.
Console output is:
Exception in thread "AWT-EventQueue-0" java.lang.Error: Application class slash.navigation.converter.gui.RouteConverterOpenSource failed to launch
at slash.navigation.gui.Application$1.run(Application.java:162)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:316)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:391)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make field protected java.util.ResourceBundle java.util.ResourceBundle.parent accessible: module java.base does not "opens java.util" to unnamed module @6a64c1a2
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:357)
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297)
at java.base/java.lang.reflect.Field.checkCanSetAccessible(Field.java:177)
at java.base/java.lang.reflect.Field.setAccessible(Field.java:171)
at slash.navigation.gui.Application.setParentBundle(Application.java:115)
at slash.navigation.gui.Application.initializeBundles(Application.java:106)
at slash.navigation.gui.Application.access$100(Application.java:51)
at slash.navigation.gui.Application$1.run(Application.java:152)
... 13 more
The reason might be incompatible Java versions.
Any help will be welcome.
