Error installing deepin operation could not be performed
Hello to everyone
I am using the kde desktop environment I want to switch to deepin, but when I try to download packages I get the following error
error: operation could not be performed (conflicting files)
deepin-kwin: existing in /etc/xdg/kdeglobals filesystem (owned by manjaro-kde-settings)
deepin-kwin: existing in /etc/xdg/kwinrc filesystem (owned by manjaro-kde-settings)
An error has occurred, no packages have been updated.
Hello again
I solved the problem
I deleted the following 2 files (I made their backups) and fixed the problem
/etc/xdg/kdeglobals
/etc/xdg/kwinrc
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
:innocent:
P.S. In the future, please mark a solution like this:
Solution
