Is this something to worry about?
(24/28) Looking for Pacnew/Pacsave created.
sudo: unknown user reboot
sudo: error initializing audit plugin sudoers_audit
error: command failed to execute correctly
Yes, probably, but itâs impossible to know without context.
Quick tip:- ![]()
Always show the complete command output, including the command(s) that were used, and place the output in a pre-formatted scrollable text box (use the </> button, not a quote box).
Please provide your system information as described (below) to help others to help you.
Iâm sure someone will assist when they are able.
Your post has been moved to dedicated topic.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive â typically, nobody has a
at their disposal â and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes itâs better to ask your system directly; ![]()
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
inxi man pages |
(manual) |
--color=0 to the long-form command, orâŚinxi -zv8c0Which command failed to execute correctly?
(maybe it was just a typo on the command line?)
What was the command which lead to this error?
I find these errors strange in any case, but it will be hard to debug without some information for the history of the machine. For example, audit framework is installed by default but i do not think it is really activated. So how was it activated to check the sudoers? Why does it fail? What does the audit logs say? Etc.
The other one for the reboot seems even more strange. I do not even understand if a real reboot is meant, or a user called ârebootâ. Is there such user in the list of users? (cat /etc/passwd |grep reboot) What process created it and why?
It seems to have happened at the end of an update (during a hook). Is that correct?
Please check /etc/sudoers and each file in /etc/sudoers.d for errors.
I may be wrong, but I suspect thereâs a reference to a user called ârebootâ in one of them, however itâs probably just a typo (presumably that user doesnât exist).
Please read the link below before editing any files. If in doubt - ask.
I think the error is from audit network and not actually in the sudoers. The module/rules to check sudoers cannot start. Not installed, not configured - i do not know, i do not use audit since i only have a personal computer with 1 user and not a server.
Maybe youâre right, it seems to be possible.
But a quick search for âerror initializing audit plugin sudoers_auditâ brings up results about errors in sudoers, and passwd.
One about a deleted user with matching errors but for root.
Also:
$ sudo -u reboot echo hello
So looks to me like either:
However I think Iâll change my vote to a hook which runs a command as a non-existent user. Just seems like an odd username.
EDIT:
Last one, fixed the link and reworded.
