After updating I get this error in Chromium ( 100.0.4896.127 (Build oficial) Arch Linux (64 bits) ) when opening Youtube (and other pages like Spotify):
Error code: SIGSEGV
I have tried several things but without much success. I’m using Firefox while I’m trying to fix it.
Update
when checking dmesg I found this:
chromium[156451]: segfault at 18 ip 00007fb46e0e45e2 sp 00007ffc22a597b0 error 4 in libfreetype.so.6.18.2[7fb46e0be000+82000]
Solution
I installed the google-chrome package from AUR.
1 aur/google-chrome 100.0.4896.127-1 (+2129 24.08)
The popular and trusted web browser by Google (Stable Channel)
And it is working fine. I’ll keep an eye out for a chromium update to fix the problem.
@linuxmanr4
Maybe this?
Enable this:
chrome://flags/#force-major-version-to-minor
run chromium on command-line. you should be able to get more meaningful error/stack-trace that you can report
Well I tried, but even the test shows me the same error.
I tried starting chromium with this command:
chromium youtube.com --enable-logging --v=1
And here is the result
(chromium:70818): Gtk-WARNING **: 08:39:02.019: Theme parsing error: gtk.css:590:12: Invalid name of pseudo-class
(chromium:70818): Gtk-WARNING **: 08:39:02.019: Theme parsing error: gtk.css:590:12: Missing closing bracket for :not()
(chromium:70818): Gtk-WARNING **: 08:39:02.021: Theme parsing error: gtk.css:1277:16: '-gtk-icon-size' is not a valid property name
(chromium:70818): Gtk-WARNING **: 08:39:02.022: Theme parsing error: gtk.css:1906:19: '' is not a valid color name
(chromium:70818): Gtk-WARNING **: 08:39:02.028: Theme parsing error: gtk.css:4400:12: Expected semicolon
(chromium:70818): Gtk-WARNING **: 08:39:02.030: Theme parsing error: gtk.css:5709:11: Not using units is deprecated. Assuming 'px'.
(chromium:70818): Gtk-WARNING **: 08:39:02.030: Theme parsing error: gtk.css:5709:14: '0' is not a valid color name
(chromium:70818): Gtk-WARNING **: 08:39:02.031: Theme parsing error: gtk.css:5831:14: '202020' is not a valid color name
(chromium:70818): Gtk-WARNING **: 08:39:02.031: Theme parsing error: gtk.css:5857:20: Junk at end of value for border-width
[70851:70851:0419/083902.348175:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
[70851:70851:0419/083902.366323:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
But I think it is more likely a problem with libfreetype.so.6.18.2
I will continue to investigate a solution, I will let you know if I find it.
well don’t you see that error? Most likely that gpu acceleration is here the problem.
I found a temporary solution.
I installed google-chrome from AUR. It’s not chromium but works.
