Error gráfico con Steam Manjaro XFCE
Buenas noches.
Hace poco volví a usar Manjaro en un laptop Lenovo Ideapad S145.
Instalé Steam desde los repos oficiales y pues al entrar a jugar Counter~Strike 1.6, pasados unos minutos el juego se “cuelga” y debo hacer un kill desde htop para cerrar.
[ivan@ivan-81w8 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=cc771b1a-19c8-4337-8a06-983dbdc58e68 rw quiet splash
    udev.log_priority=3 i915.enable_psr=0
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 81W8 v: Lenovo IdeaPad S145-15IIL
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15IIL
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN
    part-nu: LENOVO_MT_81W8_BU_idea_FM_IdeaPad S145-15IIL
    uuid: <superuser required> UEFI: LENOVO v: DKCN55WW date: 05/24/2022
  ID-1: BAT0 charge: 22.2 Wh (100.0%) condition: 22.2/30.0 Wh (74.2%)
    volts: 8.5 min: 7.5 model: SMP L16M2PB1 type: Li-poly serial: <filter>
    status: full cycles: 198
  System RAM: total: 4 GiB available: 3.62 GiB used: 2.17 GiB (59.8%)
  Array-1: capacity: 12 GiB slots: 2 modules: 1 EC: None
    max-module-size: 6 GiB note: est.
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
    speed: 2667 MT/s volts: curr: 1 min: 2 max: 2 width (bits): data: 64
    total: 64 manufacturer: Micron part-no: 4ATF51264HZ-3G2J1 serial: N/A
  Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB
    desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 400 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 9524
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
    pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg
    sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:5a08
  Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e6 built: 2016 res:
    mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1366x768
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
    device-ID: 8086:8a56 memory: 1.77 GiB unified: yes
    x11: xprop,xrandr
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:c82f
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:c02f
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 238.47 GiB used: 18.33 GiB (7.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-E100 256G
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 052 scheme: GPT
  ID-1: / raw-size: 116.58 GiB size: 114.19 GiB (97.95%)
    used: 17.11 GiB (15.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: cc771b1a-19c8-4337-8a06-983dbdc58e68
    used: 91.6 MiB (95.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: E8FC-F6C3
  ID-1: swap-1 type: partition size: 6 GiB used: 1.13 GiB (18.8%)
    priority: -2 dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 63b3f005-eba9-48a8-80dd-91598c1a2f46
  ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 115.78 GiB fs: ntfs label: SYSTEM
    uuid: 107A032F7A0310E0
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Logitech M185 compact wireless mouse type: mouse
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 046d:c542 class-ID: 0301
  Device-2: 1-5:3 info: IMC Networks Integrated Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
  Device-3: 1-10:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:c02f class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 201 Power: uptime: 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 1.44 GiB services: upowerd,xfce4-power-manager
  Packages: pm: pacman pkgs: 1098 libs: 412 tools: pamac,yay Compilers:
    gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
[ivan@ivan-81w8 ~]$
¿Qué solución encuentro a mi problema?
También tengo la salida de la ejecución vía terminal de Steam, donde entré a jugar CS y se colgó.
No Replies - Bulk action.
