ı am getting this error when ı want to update how ı can fix it
ı was looking that but unfortaatly my english is not good to understand very well could you explain me what ı gotta do?
You have to update the system first. ![]()
sudo pacman -Syyu
I don’t understand that language, but archlinuxfr is not a Manjaro mirror, and I suspect that this is the one causing you trouble. Remove it from the mirror list, update your mirrors and try again. ![]()
sudo pacman-mirrors --continent && sudo pacman -Syyu
sorry to dont explain you ıts says Siglevel is not avaible for this part and again ıts says error GPGHME error: no data
ı did what you said to me ı got same things too
and ı only want to take my a few files from my computer and then ı wıll ınstall agaın how ı can take thıs fıle ı only see my terminal screen and ı cannot and more ı have tımeshıt too can ı use tımeshift from terminal to take pass
Yes, you can. It has a man page. ![]()
man timeshift
okey thanks ı wıll search how ı can use timeshift now ı did man timeshift but ı didnt understand very well thanks for your information
okey ı saw with sudo timeshift --restore and ı choose number ı things its happening again thank you soo much
