I am getting this error when trying to update (along with some other things):
[manjaro ~]# pacman -Syu
error: GPGME error: No data
core 169.4 KiB 184 KiB/s 00:01 [----------------------] 100%
extra 1882.8 KiB 2.72 MiB/s 00:01 [----------------------] 100%
community 6.6 MiB 3.99 MiB/s 00:02 [----------------------] 100%
multilib 176.5 KiB 1124 KiB/s 00:00 [----------------------] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
sudo pacman -Syy
core 169.4 KiB 179 KiB/s 00:01 [----------------------] 100%
extra 1882.8 KiB 1681 KiB/s 00:01 [----------------------] 100%
community 6.6 MiB 4.71 MiB/s 00:01 [----------------------] 100%
sudo pacman-mirrors -f 5
[sudo] password for yiannis:
::INFO => Mirror status: http://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
3.980 Brazil : https://manjaro.c3sl.ufpr.br/
1.016 Poland : https://repo.skni.umcs.pl/manjaro/
0.814 Poland : http://repo.skni.umcs.pl/manjaro/
0.697 Ukraine : http://mirrors.colocall.net/manjaro/
..... Ukraine : ftp://mirrors.colocall.net/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.')
2.259 United_States : https://repo.ialab.dsu.edu/manjaro/
1.656 United_States : http://repo.ialab.dsu.edu/manjaro/
1.290 Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/
0.890 Hungary : http://quantum-mirror.hu/mirrors/pub/manjaro/
::INFO Writing mirror list
::Poland : https://repo.skni.umcs.pl/manjaro/testing
::Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/testing
::United_States : https://repo.ialab.dsu.edu/manjaro/testing
::Brazil : https://manjaro.c3sl.ufpr.br/testing
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
sudo pacman -Syyu
core 169.4 KiB 115 KiB/s 00:01 [----------------------] 100%
extra 1882.8 KiB 445 KiB/s 00:04 [----------------------] 100%
community 6.6 MiB 637 KiB/s 00:11 [----------------------] 100%
multilib 176.5 KiB 494 KiB/s 00:00 [----------------------] 100%
It appears the file is a regular database - so the error is puzzling.
I have had these errors some time back - and my final solution was the above - but I only asked you to test the core.db - you can test all the db files using
file /var/lib/pacman/sync/*.db
You can remove the files from the sync folder then retry the update
/var/lib/pacman/sync/community.db: gzip compressed data, last modified: Thu Aug 19 14:12:46 2021, from Unix, original size modulo 2^32 41745408
/var/lib/pacman/sync/core.db: gzip compressed data, last modified: Thu Aug 19 14:11:38 2021, from Unix, original size modulo 2^32 1156096
/var/lib/pacman/sync/extra.db: gzip compressed data, last modified: Thu Aug 19 14:11:57 2021, from Unix, original size modulo 2^32 13974528
/var/lib/pacman/sync/multilib.db: gzip compressed data, last modified: Thu Aug 19 14:11:40 2021, from Unix, original size modulo 2^32 1229312
Still getting this error after /var/lib/pacman/sync/*.db
sudo pacman -Syu
core 169.4 KiB 144 KiB/s 00:01 [----------------------] 100%
extra 1882.8 KiB 371 KiB/s 00:05 [----------------------] 100%
community 6.6 MiB 274 KiB/s 00:25 [----------------------] 100%
multilib 176.5 KiB 230 KiB/s 00:01 [----------------------] 100%
