(I need help please
This problem appears to me and I can’t solve it).
mount:/run/miso/sfs/livefs: wrong fs type, bad superblock on /dev/loop0, missing codepage or helper programs, or other error.
dmesg(1) may have information after failed mount system call.
ERROR; Failed to mount ’ /dev/loop0’
Falling back to interactive prompt
You can try to fix the problem manually, log out when you are finished
sh: can’t access tty; job control turned off
[rootfs ~] #
