Hello, I am trying install the application called Dialect through pamac (also Dialect-git) but I get the following error:
Summary
Preparing...
Cloning dialect build files...
Generating dialect information...
Checking dialect dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building dialect...
==> Making package: dialect 2.0.2-1 (Wed 21 Sep 2022 07:22:05 PM EEST)
==> Retrieving sources...
-> Updating dialect git repo...
-> Updating po git repo...
dialect ... Skipped
po ... Skipped
==> Extracting sources...
-> Creating working copy of dialect git repo...
Cloning into 'dialect'...
done.
Switched to a new branch 'makepkg'
-> Creating working copy of po git repo...
Cloning into 'po'...
done.
==> Starting prepare()...
Submodule 'po' (https://github.com/dialect-app/po) registered for path 'po'
Cloning into '/var/tmp/pamac-build-lee/dialect/src/dialect/po'...
done.
Submodule path 'po': checked out '1b83ba8265fb470491e64021dad5f2a25ae01a94'
==> Starting pkgver()...
==> Removing existing $pkgdir/ directory...
==> Starting build()...
+ exec meson setup --prefix /usr --libexecdir lib --sbindir bin --buildtype plain --auto-features enabled --wrap-mode nodownload -D b_lto=true -D b_pie=true dialect build
The Meson build system
Version: 0.63.2
Source dir: /var/tmp/pamac-build-lee/dialect/src/dialect
Build dir: /var/tmp/pamac-build-lee/dialect/src/build
Build type: native build
Project name: dialect
Project version: 2.0.2
Host machine cpu family: x86_64
Host machine cpu: x86_64
Program python3 found: YES (/usr/bin/python3)
Message: Looking for dependencies
Message: Found python3 binary
Found pkg-config: /usr/bin/pkg-config (1.8.0)
Run-time dependency glib-2.0 found: YES 2.72.3
Run-time dependency gobject-introspection-1.0 found: YES 1.72.0
Run-time dependency gstreamer-1.0 found: YES 1.20.3
Run-time dependency gtk4 found: YES 4.6.7
Run-time dependency libadwaita-1 found: YES 1.1.5
Run-time dependency libsoup-3.0 found: YES 3.0.8
Run-time dependency pygobject-3.0 found: YES 3.42.2
Program blueprint-compiler found: YES (/usr/bin/blueprint-compiler)
Program glib-compile-resources found: YES (/usr/bin/glib-compile-resources)
Configuring app.drey.Dialect.desktop.in using configuration
Program msgfmt found: YES (/usr/bin/msgfmt)
Program desktop-file-validate found: YES (/usr/bin/desktop-file-validate)
Configuring app.drey.Dialect.metainfo.xml.in using configuration
Program appstream-util found: YES (/usr/bin/appstream-util)
Configuring app.drey.Dialect.gschema.xml using configuration
Program glib-compile-schemas found: YES (/usr/bin/glib-compile-schemas)
Configuring dialect using configuration
Configuring define.py using configuration
Configuring app.drey.Dialect.SearchProvider.ini using configuration
Configuring app.drey.Dialect.SearchProvider.service using configuration
Configuring search_provider using configuration
Program msginit found: YES (/usr/bin/msginit)
Program msgmerge found: YES (/usr/bin/msgmerge)
Program xgettext found: YES (/usr/bin/xgettext)
Build-time dependency gio-2.0 found: YES 2.72.3
Program gtk4-update-icon-cache found: YES (/usr/bin/gtk4-update-icon-cache)
Program update-desktop-database found: YES (/usr/bin/update-desktop-database)
Build targets in project: 51
dialect 2.0.2
User defined options
auto_features: enabled
buildtype : plain
libexecdir : lib
prefix : /usr
sbindir : bin
wrap_mode : nodownload
b_lto : true
b_pie : true
Found ninja-1.10.2.git.kitware.jobserver-1 at /home/lee/.local/bin/ninja
ninja: Entering directory `/var/tmp/pamac-build-lee/dialect/src/build'
[1/47] Generating po/ca/LC_MESSAGES/dialect-ca.mo with a custom command
[2/47] Generating po/cs/LC_MESSAGES/dialect-cs.mo with a custom command
[3/47] Generating po/de/LC_MESSAGES/dialect-de.mo with a custom command
[4/47] Generating po/eu/LC_MESSAGES/dialect-eu.mo with a custom command
[5/47] Generating po/eo/LC_MESSAGES/dialect-eo.mo with a custom command
[6/47] Generating po/es/LC_MESSAGES/dialect-es.mo with a custom command
[7/47] Generating po/fa/LC_MESSAGES/dialect-fa.mo with a custom command
[8/47] Generating po/fi/LC_MESSAGES/dialect-fi.mo with a custom command
[9/47] Generating po/gl/LC_MESSAGES/dialect-gl.mo with a custom command
[10/47] Generating po/hi/LC_MESSAGES/dialect-hi.mo with a custom command
[11/47] Generating po/he/LC_MESSAGES/dialect-he.mo with a custom command
[12/47] Generating po/hu/LC_MESSAGES/dialect-hu.mo with a custom command
[13/47] Generating po/fr/LC_MESSAGES/dialect-fr.mo with a custom command
[14/47] Generating po/hr/LC_MESSAGES/dialect-hr.mo with a custom command
[15/47] Generating po/id/LC_MESSAGES/dialect-id.mo with a custom command
[16/47] Generating po/ka/LC_MESSAGES/dialect-ka.mo with a custom command
[17/47] Generating po/kmr/LC_MESSAGES/dialect-kmr.mo with a custom command
[18/47] Generating po/it/LC_MESSAGES/dialect-it.mo with a custom command
[19/47] Generating po/ko/LC_MESSAGES/dialect-ko.mo with a custom command
[20/47] Generating po/lt/LC_MESSAGES/dialect-lt.mo with a custom command
[21/47] Generating po/nb_NO/LC_MESSAGES/dialect-nb_NO.mo with a custom command
[22/47] Generating po/nl/LC_MESSAGES/dialect-nl.mo with a custom command
[23/47] Generating po/oc/LC_MESSAGES/dialect-oc.mo with a custom command
[24/47] Generating po/pl/LC_MESSAGES/dialect-pl.mo with a custom command
[25/47] Generating po/pt/LC_MESSAGES/dialect-pt.mo with a custom command
[26/47] Generating po/pt_BR/LC_MESSAGES/dialect-pt_BR.mo with a custom command
[27/47] Generating po/ru/LC_MESSAGES/dialect-ru.mo with a custom command
[28/47] Generating po/sv/LC_MESSAGES/dialect-sv.mo with a custom command
[29/47] Generating po/ar/LC_MESSAGES/dialect-ar.mo with a custom command
[30/47] Generating po/tr/LC_MESSAGES/dialect-tr.mo with a custom command
[31/47] Generating po/kn/LC_MESSAGES/dialect-kn.mo with a custom command
[32/47] Generating po/ja/LC_MESSAGES/dialect-ja.mo with a custom command
[33/47] Generating po/uk/LC_MESSAGES/dialect-uk.mo with a custom command
[34/47] Generating po/lv/LC_MESSAGES/dialect-lv.mo with a custom command
[35/47] Generating po/zh_CN/LC_MESSAGES/dialect-zh_CN.mo with a custom command
[36/47] Generating po/sk/LC_MESSAGES/dialect-sk.mo with a custom command
[37/47] Generating po/si/LC_MESSAGES/dialect-si.mo with a custom command
[38/47] Generating po/fy/LC_MESSAGES/dialect-fy.mo with a custom command
[39/47] Generating po/am/LC_MESSAGES/dialect-am.mo with a custom command
[40/47] Generating po/sr/LC_MESSAGES/dialect-sr.mo with a custom command
[41/47] Generating po/el/LC_MESSAGES/dialect-el.mo with a custom command
[42/47] Generating po/bn/LC_MESSAGES/dialect-bn.mo with a custom command
[43/47] Generating po/da/LC_MESSAGES/dialect-da.mo with a custom command
[44/47] Generating data/app.drey.Dialect.desktop with a custom command
[45/47] Generating data/app.drey.Dialect.metainfo.xml with a custom command
[46/47] Generating data/resources/blueprints with a custom command
FAILED: data/resources
/usr/bin/blueprint-compiler batch-compile data/resources/. ../dialect/data/resources ../dialect/data/resources/theme-switcher.blp ../dialect/data/resources/lang-selector.blp ../dialect/data/resources/window.blp ../dialect/data/resources/lang-row.blp ../dialect/data/resources/about.blp ../dialect/data/resources/shortcuts.blp
error: Expected `;`
at ../dialect/data/resources/window.blp line 499 column 58:
499 | sensitive: bind langs_button_box.sensitive no-sync-create;
error: Unexpected tokens
error: Expected `;`
at ../dialect/data/resources/window.blp line 503 column 56:
503 | sensitive: bind src_lang_btn.sensitive no-sync-create;
error: Expected `;`
at ../dialect/data/resources/window.blp line 508 column 52:
508 | label: bind src_lang_label.label no-sync-create;
error: Expected `;`
at ../dialect/data/resources/window.blp line 516 column 54:
516 | sensitive: bind switch_btn.sensitive no-sync-create;
error: Expected `;`
at ../dialect/data/resources/window.blp line 524 column 57:
524 | sensitive: bind dest_lang_btn.sensitive no-sync-create;
error: Expected `;`
at ../dialect/data/resources/window.blp line 529 column 53:
529 | label: bind dest_lang_label.label no-sync-create;
12 errors
ninja: build stopped: subcommand failed.
==> ERROR: A failure occurred in build().
Aborting...
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
