Output of inxi -Fza:
12System:
12Kernel 6.6.8-2-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1 12clocksource tsc
12available acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2311 quiet systemd.show_status=1 splash driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Console N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Laptop 12System HP 12product HP Laptop 15-fd0xxx 12v N/A 12serial <filter> 12Chassis 12type 10
12serial <filter>
12Mobo HP 12model 8B36 12v 62.30 12serial <filter> 12UEFI AMI 12v F.06 12date 07/03/2023
12Battery:
12ID-1 BAT0 12charge 24.6 Wh (57.6%) 12condition 42.7/41.0 Wh (104.0%) 12power 5.9 W 12volts 11.1 12min 11.2
12model HP Primary 12type Li-ion 12serial <filter> 12status discharging 12cycles 3
12CPU:
12Info 12model Intel N200 12socket U3E1 12bits 64 12type MCP 12arch Alder Lake 12level v3 12note check
12built 2021+ 12process Intel 7 (10nm ESF) 12family 6 12model-id 0xBE (190) 12stepping 0 12microcode 0x12
12Topology 12cpus 1x 12cores 4 12smt <unsupported> 12cache 12L1 384 KiB 12desc d-4x32 KiB; i-4x64 KiB
12L2 2 MiB 12desc 1x2 MiB 12L3 6 MiB 12desc 1x6 MiB
12Speed (MHz) 12avg 858 12high 1033 12min/max 800/3700 12base/boost 3168/3700 12scaling 12driver intel_pstate
12governor powersave 12volts 1.1 V 12ext-clock 100 MHz 12cores 121 800 122 800 123 800 124 1033 12bogomips 7988
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
12Vulnerabilities
12Type gather_data_sampling 12status Not affected
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type retbleed 12status Not affected
12Type spec_rstack_overflow 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Enhanced / Automatic IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel Alder Lake-N [UHD Graphics] 12vendor Hewlett-Packard 12driver i915 12v kernel
12arch Gen-12.2 12process Intel 10nm 12built 2021-22+ 12ports 12active eDP-1 12empty HDMI-A-1 12bus-ID 00:02.0
12chip-ID 8086:46d0 12class-ID 0300
12Device-2 Quanta HP True Vision HD Camera 12driver uvcvideo 12type USB 12rev 2.0 12speed 480 Mb/s
12lanes 1 12mode 2.0 12bus-ID 1-3:2 12chip-ID 0408:5489 12class-ID fe01 12serial <filter>
12Display 12server X.org 12v 1.21.1.10 12compositor kwin_x11 12driver 12gpu i915 12tty 80x40
12Monitor-1 eDP-1 12model ChiMei InnoLux 0x1541 12built 2021 12res 1366x768 12dpi 101 12gamma 1.2
12size 344x193mm (13.54x7.6") 12diag 394mm (15.5") 12ratio 16:9 12modes 1366x768
12API EGL 12v 1.5 12hw 12drv intel iris 12platforms 12device 0 12drv iris 12device 1 12drv swrast 12surfaceless
12drv iris 12inactive gbm,wayland,x11
12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 23.1.9-manjaro1.1 12note console (EGL sourced)
12renderer Mesa Intel Graphics (ADL-N), llvmpipe (LLVM 16.0.6 256 bits)
12API Vulkan 12v 1.3.274 12layers N/A 12device 0 12type integrated-gpu 12name Intel Graphics (ADL-N)
12driver mesa intel 12v 23.1.9-manjaro1.1 12device-ID 8086:46d0 12surfaces N/A
12Audio:
12Device-1 Intel 12vendor Hewlett-Packard 12driver sof-audio-pci-intel-tgl
12alternate snd_hda_intel,snd_sof_pci_intel_tgl 12bus-ID 00:1f.3 12chip-ID 8086:54c8 12class-ID 0401
12API ALSA 12v k6.6.8-2-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
12Server-2 PipeWire 12v 1.0.0 12status n/a (root, process) 12with 121 pipewire-pulse 12status active
122 wireplumber 12status active 123 pipewire-alsa 12type plugin 12tools pactl,pw-cat,pw-cli,wpctl
12Network:
12Device-1 Realtek RTL8852BE PCIe 802.11ax Wireless Network [1T1R] 12vendor Hewlett-Packard
12driver rtw89_8852be 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port 3000 12bus-ID 01:00.0
12chip-ID 10ec:b85b 12class-ID 0280
12IF wlo1 12state up 12mac <filter>
12Bluetooth:
12Device-1 Realtek Bluetooth Radio 12driver btusb 12v 0.8 12type USB 12rev 1.0 12speed 12 Mb/s 12lanes 1
12mode 1.1 12bus-ID 1-8:3 12chip-ID 0bda:b85d 12class-ID e001 12serial <filter>
12Report rfkill 12ID hci0 12rfk-id 0 12state up 12address see --recommends
12Drives:
12Local Storage 12total 176.99 GiB 12used 7.51 GiB (4.2%)
12ID-1 /dev/sda 12maj-min 8:0 12vendor Kingston 12model DataTraveler 3.0 12size 57.8 GiB 12block-size
12physical 512 B 12logical 512 B 12type USB 12rev 3.2 12spd 5 Gb/s 12lanes 1 12mode 3.2 gen-1x1 12tech N/A
12serial <filter> 12fw-rev PMAP
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12ID-2 /dev/sdb 12maj-min 8:16 12model KLUDG4UHGC-B0E1 12size 119.2 GiB 12block-size 12physical 4096 B
12logical 4096 B 12tech SSD 12serial N/A 12fw-rev 1001
12SMART no
12Partition:
12ID-1 / 12raw-size 118.84 GiB 12size 116.42 GiB (97.96%) 12used 7.51 GiB (6.4%) 12fs ext4
12block-size 4096 B 12dev /dev/sdb2 12maj-min 8:18
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.3 MiB (99.76%) 12used 296 KiB (0.1%) 12fs vfat
12block-size 4096 B 12dev /dev/sdb1 12maj-min 8:17
12Swap:
12Alert No swap data was found.
12Sensors:
12System Temperatures 12cpu 55.0 C 12mobo N/A
12Fan Speeds (rpm) 12cpu 2998 12fan-2 0
12Info:
12Processes 193 12Uptime 0m 12wakeups 0 12Memory 12total 4 GiB 12note est. 12available 3.49 GiB
12used 1.48 GiB (42.2%) 12igpu 60 MiB 12Init systemd 12v 254 12default graphical 12tool systemctl 12Compilers
12gcc 13.2.1 12clang 16.0.6 12Packages 12pm pacman 12pkgs 1119 12libs 319 12tools pamac 12pm flatpak 12pkgs 0
12Client Unknown Client: systemd 12inxi 3.3.31
Output of fdisk:
Disk /dev/sda: 57.8 GiB, 62058921984 bytes, 121208832 sectors
Disk model: DataTraveler 3.0
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 7635643 7635580 3.6G 0 Empty
/dev/sda2 7635644 7643835 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 80.61 MiB, 84529152 bytes, 165096 sectors
Disk /dev/loop1: 1.05 GiB, 1125187584 bytes, 2197632 sectors
Disk /dev/loop2: 1.69 GiB, 1809408000 bytes, 3534000 sectors
Disk /dev/loop3: 764.58 MiB, 801718272 bytes, 1565856 sectors
Disk /dev/sdb: 119.2 GiB, 127984992256 bytes, 31246336 sectors
Disk model: KLUDG4UHGC-B0E1
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 524288 bytes / 524288 bytes
Disklabel type: gpt
Disk identifier: 20E642A3-9347-40FF-9CEA-152E41499D3F
Device Start End Sectors Size Type
/dev/sdb1 512 77311 76800 300M EFI System
/dev/sdb2 77312 31230359 31153048 118.8G Linux filesystem
Output of efibootmgr:
BootCurrent: 0004
Timeout: 0 seconds
BootOrder: 0000,0002,0001,0005,0004
Boot0000* Manjaro HD(1,GPT,b24e8f64-8b4c-457e-a4b7-36e1256dc898,0x200,0x12c00)/File(\EFI\Manjaro\grubx64.efi)
Boot0001* Windows Boot Manager HD(1,GPT,700520bc-52b0-4a42-85fd-60268427f641,0x100,0x12c00)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000064000100000010000000040000007fff0400
Boot0002* ubuntu HD(1,GPT,eb3abdda-2aaa-4fb3-b55b-3e330aabd27e,0x100,0x20000)/File(\EFI\ubuntu\shimx64.efi)
Boot0004* USB Drive (UEFI) - KingstonDataTraveler 3.0PMAP PciRoot(0x0)/Pci(0x14,0x0)/USB(13,0)/CDROM(1,0x7482bc,0x8000)0000424f
Boot0005* Internal Hard Disk PciRoot(0x0)/Pci(0x12,0x7)/UFS(0,0x00)/HD(1,GPT,b24e8f64-8b4c-457e-a4b7-36e1256dc898,0x200,0x12c00)0000424f
