Hi, im new to manjaro and i recently installed it on my mac mini late 2012
after a success installation and using refind, i ended up getting a boot error that is not letting me get into the OS, i have been researching about how to fix it but i didnt get a proper answer about how to fix it.
This is the error i get:
ERROR: device '' not found. Skipping fsck.
:: mounting '' on real root
mount: /new_root: no valid filesystem type specified.
:: running emergency hook [plymouth]
ERROR: Failed to mount '' on real root
You are now being dropped into an emergency shell
sh: can't access tty: job control turned off
i also tried using the
mkinitcpio -P
and during the process i get warnings about missing firmware, i have a doubt that some stuff is missing or something? but i am still unable to get into manjaro
I also tried updating the kernel (before linux66) to linux68 but also no effect.
Is there a way to fix it? or i have to do everything again?.
Edit: the only way im accessing to manjaro is through the USB live boot
ok so while i was navigating i found the /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=8e1a6598-50f6-4003-b5e1-b777139ddb28 / ext4 defaults,noatime 0 1
UUID=3092444e-60e2-424c-9e44-6b2a37633b65 /boot ext4 defaults,noatime 0 2
UUID=dd3cf909-7829-44a2-9547-147642eb95ed /home ext4 defaults,noatime 0 2
and i dont see any issues?, the only thing i dont understand is ‘‘noatime’’
