Error: could not open file rslsync: Error reading fd 7
What I’m trying to install is Resilio sync, but I’ve come across an error that I’ve found no answer for.
The salient commands run are:
git clone https://aur.archlinux.org/rslsync.git
makepkg
sudo pacman -U rslsync
The last of which failed, giving this message:
loading packages...
error: could not open file rslsync: Error reading fd 7
error: 'rslsync': cannot open package file
I’m assuming the former error caused the latter error.
Not quite.
cd rslsync
makepkg -srcif
See
Even if you built it successfully, that won’t work because that’s not the filename. It would be something like rslsync-2.7.2-1-x86_64.pkg.tar.zst. In my example above the makepkg -i flag installs it, so a separate step is not needed.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
