Error building nvhda dkms module
It reports a command was not executed properly:
erro: comando não executado corretamente
:: Executando hooks pós-transação...
( 1/31) Creating system user accounts...
( 2/31) Updating journal message catalog...
( 3/31) Reloading system manager configuration...
( 4/31) Reloading user manager configuration...
( 5/31) Updating udev hardware database...
( 6/31) Applying kernel sysctl settings...
( 7/31) Creating temporary files...
( 8/31) Reloading device manager configuration...
( 9/31) Arming ConditionNeedsUpdate...
(10/31) Updating the MIME type database...
(11/31) Updating module dependencies...
(12/31) Install DKMS modules
==> dkms install --no-depmod nvhda/r13.9a11664 -k 6.1.71-1-MANJARO
Error! Bad return status for module build on kernel: 6.1.71-1-MANJARO (x86_64)
Consult /var/lib/dkms/nvhda/r13.9a11664/build/make.log for more information.
==> WARNING: `dkms install --no-depmod nvhda/r13.9a11664 -k 6.1.71-1-MANJARO' exited 10
==> dkms install --no-depmod nvhda/r13.9a11664 -k 5.4.266-1-MANJARO
==> dkms install --no-depmod nvhda/r13.9a11664 -k 6.6.10-1-MANJARO
Error! Bad return status for module build on kernel: 6.6.10-1-MANJARO (x86_64)
==> WARNING: `dkms install --no-depmod nvhda/r13.9a11664 -k 6.6.10-1-MANJARO' exited 10
==> depmod 5.4.266-1-MANJARO
(13/31) Updating TeXLive filename database...
(14/31) Updating TeXLive format files...
(15/31) Updating TeXLive font maps...
(16/31) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: '5.4.266-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.4-x86_64.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
  -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.4-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.71-1-MANJARO'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
  -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.6.10-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
(17/31) Updating Kernel initcpios for Nvidia-DRM...
(18/31) Updating Grub-Bootmenu
Gerando o arquivo de configuração do grub...
Imagem Linux encontrada: /boot/vmlinuz-6.6-x86_64
Imagem initrd encontrada: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Imagem Linux encontrada: /boot/vmlinuz-6.1-x86_64
Imagem initrd encontrada: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Imagem Linux encontrada: /boot/vmlinuz-5.4-x86_64
Imagem initrd encontrada: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Aviso: os-prober será executado para detectar outras partições de arranque.
A sua saída será usada para detectar binários de arranque nessas partições e criar novas entradas.
Encontrado Windows Boot Manager em /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
A adicionar entrada de menu para UEFI Firmware Settings ...
/usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconhecido.
concluído
(19/31) Reloading system bus configuration...
(20/31) Warn about old perl modules
(21/31) Copy Firefox Distribution Settings
(22/31) Updating fontconfig cache...
(23/31) Updating 32-bit fontconfig cache...
(24/31) Registering Haskell modules...
(25/31) Updating GIO module cache...
(26/31) Compiling GSettings XML schema files...
(27/31) Updating icon theme caches...
(28/31) Reloading GVFS config...
(29/31) Updating the info directory file...
(30/31) Copy Thunderbird Distribution Settings
(31/31) Updating the desktop file MIME type cache...
Info about the machine:
inxi -Fia
  Host: mordor Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 13.2.1 clocksource: tsc available: hpet,acpi_pm
    root=UUID=24ac56d2-c1dc-4919-b6a4-5e39433604ca rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
  Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
  Mobo: Dell model: 0P84C9 v: A01 serial: <superuser required> UEFI: Dell
    v: 1.15.0 date: 08/30/2021
  ID-1: BAT0 charge: 58.4 Wh (90.3%) condition: 64.7/74.4 Wh (86.9%)
    volts: 12.2 min: 11.1 model: Samsung SDI DELL 0GFJ6F4 type: Li-ion
    serial: 562 status: not charging
  Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF4
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1100 high: 1101 min/max: 800/3800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1100
    4: 1100 5: 1101 6: 1101 7: 1100 8: 1101 bogomips: 44817
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
    driver: nvidia v: 545.29.06 non-free: 545.xx+ status: current (as of
    2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
    empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
  Device-3: Sunplus Innovation Integrated Webcam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:3
    chip-ID: 1bcf:2c01 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.67x14.41")
    s-diag: 748mm (29.44")
  Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x63ed built: 2017
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1050 Ti driver: nvidia v: 545.29.06 device-ID: 10de:1c8c
    surfaces: xcb,xlib
  Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
    vendor: Dell driver: r8168 v: 8.052.01-NAPI pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: down mac: 50:9a:4c:b5:af:eb
  Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 56.0 C
  IF: wlp3s0 state: up mac: e8:9e:b4:66:e3:ef
  IP v4: 192.168.15.3/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.15.255
  IP v6: 2804:7f4:c980:eaf2:14c9:8873:1aec:d16/64
  IP v6: fe80::f00c:2ae0:162f:4c0b/64 type: noprefixroute scope: link
  IF-ID-1: docker0 state: down mac: 02:42:89:30:23:e9
  IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
  IF-ID-2: ovpntun0 state: down mac: N/A
  WAN IP: 177.60.107.34
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0cf3:e007
    class-ID: e001
  Local Storage: total: 1.36 TiB used: 182.37 GiB (13.1%)
    model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: 211806A001B1
    fw-rev: 111130WD temp: 37.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10JPVX-75JC3T0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: WXG1EB6FKP4J
    fw-rev: 1A03 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Garmin model: FR935 size: 54.3 MiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 12 Mb/s
    lanes: 1 mode: 1.1 tech: N/A serial: Flash fw-rev: 1.00
  ID-1: / raw-size: 248 GiB size: 108.98 GiB (43.94%) used: 97.29 GiB (89.3%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
    used: 66.6 MiB (13.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /var raw-size: 52.97 GiB size: 51.84 GiB (97.86%)
    used: 36.85 GiB (71.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-1: swap-1 type: partition size: 1000 MiB used: 507.9 MiB (50.8%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 57.0 C pch: 50.0 C mobo: 44.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 2291
  Processes: 297 Uptime: 1d 1h 9m wakeups: 1 Memory: total: 16 GiB
  available: 15.49 GiB used: 4.17 GiB (26.9%) Init: systemd v: 255
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11/12
  clang: 16.0.6 Packages: pm: pacman pkgs: 2301 libs: 445 tools: pamac,yay
  pm: flatpak pkgs: 0 Shell: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
The functionality should already be present. nvhda-dkms-git was deleted from the AUR last year.
should be obsolete for kernels >=5.4 as the HDA device is enabled per pci quirk.
– GitHub - hhfeuer/nvhda: Linux kernel module to toggle Nvidia HDMI audio device on/off on notebooks
Thanks for the explanation. I removed the module and now i have no sound. Trying to install it again.
Yup I have no audio anymore.
Maybe try to switch pipewire on?
Also, I would try to get rid of does error:
It did work thank you!
