Hi !
Dude, i’m son mad, i realy need help…
I use manjaro (on KDE) since 2 month. He IS install on a external HDD and i’m booting on Évry day. This morning After some trouble i decide to reinstall manjaro. The problem is : when thé install finish i’ve “the bootloader could not be installed”…
I search on the web but nothing work… I logo if all IS good in the bios, and it’s… i don’t know what to do next…
I tried to install Manjaro 21.1.6 (iso burned on DVD) on my Thinkpad – no go. It grinds away for a long, long time (20 minutes??) with no feedback, no video and finally issues a multitude of failure notices and dies.
I’m looking at a PinePhone to have real linux and real Java in my pocket. What a dream come true. With only 4GB of memory (and a small battery) I thought I would test how much could be done with a PinePhone but, alas, that will not happen at this point.
Ok, but that’s not realy helpfull ^^"
Just letting you know you are not alone!! Hopefully someone who knows what to do about install failures will come to our rescue…
Thx ^^
Hello @solidracoon and welcome
Please start with some basic information…
Open a terminal and copy&paste each command there plus press enter.
inxi --full --admin --filter --width 80
sudo parted -l
test -d /sys/firmware/efi && echo efi || echo bios
efibootmgr -v
And post it here as code.
Thanks
Single-/Multiboot ?
UEFI is read only ?
So. I’v a SSD in the Pc. Win10 on it. I use a external HDD for manjaro.
the result of the command is :
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=fr_FR keytable=fr tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2116 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP ProBook x360 11 G1 EE v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 82EE v: 54.20 serial: <filter> UEFI: Insyde v: 01.09
date: 04/10/2017
ID-1: BAT0 charge: 25.9 Wh (68.0%) condition: 38.1/38.1 Wh (100.0%)
volts: 11.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Discharging
Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP arch: Goldmont
family: 6 model-id: 5C (92) stepping: 9 microcode: 44 cache: L2: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 8756
Speed: 1622 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 1622 2: 1106
3: 2098 4: 1794
Type: spec_store_bypass status: Not affected
Device-1: Intel HD Graphics 500 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5a85 class-ID: 0300
Device-2: Sunplus Innovation HP Wide Vision HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 1bcf:2c83 class-ID: 0e02
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 136 size: 256x144mm (10.1x5.7")
diag: 294mm (11.6")
OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:5a98 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 1000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:095a class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 421.08 GiB used: 8.19 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0006 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: JMicron Tech model: N/A
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0407 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Micro
size: 3.75 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.01 scheme: MBR
System Temperatures: cpu: 31.0 C mobo: 26.8 C
Processes: 199 Uptime: 12m wakeups: 2 Memory: 3.65 GiB
used: 1.42 GiB (39.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1234 lib: 333 flatpak: 0 Shell: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.07
sudo parted -l
Modèle : ATA SanDisk SD8SN8U- (scsi)
Disque /dev/sda : 128GB
Taille des secteurs (logiques/physiques) : 512B/4096B
Table de partitions : gpt
Drapeaux de disque :
Numéro Début Fin Taille Système de fichiers Nom Drapeaux
1 1049kB 106MB 105MB fat32 EFI system partition démarrage, esp
2 106MB 123MB 16,8MB Microsoft reserved partition msftres
3 123MB 127GB 127GB ntfs Basic data partition msftdata
4 127GB 128GB 548MB ntfs caché, diag
Modèle : JMicron Tech (scsi)
Disque /dev/sdb : 320GB
1 2097kB 317MB 315MB fat32 démarrage, esp
2 317MB 320GB 320GB ext4 root
Modèle : SanDisk Cruzer Micro (scsi)
Disque /dev/sdc : 4026MB
Taille des secteurs (logiques/physiques) : 512B/512B
Table de partitions : msdos
Numéro Début Fin Taille Type Système de fichiers Drapeaux
2 3475MB 3479MB 4194kB primary esp
efi
efibootmgr -v
Skipping unreadable variable "Boot0000": Interrupted system call
Skipping unreadable variable "Boot0001": Interrupted system call
Skipping unreadable variable "Boot0002": Interrupted system call
Skipping unreadable variable "Boot0003": Interrupted system call
Skipping unreadable variable "Boot0004": Interrupted system call
Skipping unreadable variable "Boot2001": Interrupted system call
Skipping unreadable variable "Boot2002": Interrupted system call
Skipping unreadable variable "Boot2003": Interrupted system call
show_order(): Interrupted system call
Thx for your help !
I’ve enter the comand on the live usb, i don’t no if it’s what u whant ^^"
Since the issue comes from the UEFI, please update the UEFI Firmware first.
On the website:
date: Jul 16, 2021
version: 01.36 Rev.A
HP ProBook x360 11 G1 EE Notebook PC Software and Driver Downloads | HP® Customer Support
It seem’s there IS no drivers on the link u give me :0 and it’s strange bcs it works Yesterday, si why the uefi driver bug now ?
Look under BIOS.
Another thing could that the NVRAM is full or there was an update of efivarfs…
Ok indon’t see thé drivers bcs i’m with m’y phone ^^ it’s dangourous to change the bios driver ? I never do this, IS it simple ?
It is simple…
On Windows just download the exe file, run it and update. Always: Don’t abort the process and keep sure there is no possible power loss while updating, since that can brick your system.
Ok let’s go, thx Bro’ i try this
Ok, maj bios done ! I retry manjaro instal’
Nope… that not work :’( same message error
I try some stuff today but nothing works. It seems thé problem is recurent with HP.
When i manuali try to install thé GRUB i Always have some error…
Try to reset the UEFI and remove some unnecessary entries.
Most likely a UEFI issue but
You are trying to install grub to the efi partition on sda, your actual Win drive, right?
