Error al actualizar
Hola a todos. He tenido problemas recientemente al intentar actualizar mi sistema con la ultima version de noviembre 14 o 15 si no estoy mal.
El mensaje de error es el siguiente:
Ya he intentando con la consola y me aparece un error parecido si no es que igual a ese. Podrian ayudarme?
Información del sistema:
  Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Aspire A515-55 v: V1.13
    serial: <superuser required>
  Mobo: IL model: Doc_IL v: V1.13 serial: <superuser required> UEFI: Insyde
    v: 1.13 date: 10/15/2020
  ID-1: BAT1 charge: 39.7 Wh (80.7%) condition: 49.2/47.8 Wh (102.9%)
    volts: 12.0 min: 11.2 model: LGC AP18C8K type: Li-ion serial: <filter>
    status: discharging
  RAM: total: 11.47 GiB used: 3.41 GiB (29.8%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: dual core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
    smt: enabled arch: Ice Lake rev: 5 cache: L1: 160 KiB L2: 1024 KiB L3: 4 MiB
  Speed (MHz): avg: 1198 high: 1200 min/max: 400/3400 cores: 1: 1200 2: 1200
    3: 1200 4: 1193 bogomips: 9524
  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
    driver: i915 v: kernel arch: Gen-11 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:2
    chip-ID: 0408:a061 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 res: 1920x1080 hz: 60
    dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel UHD Graphics (ICL GT1)
    direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:34c8
    class-ID: 0403
  Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: speed: Unknown
    lanes: 63 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Local Storage: total: 119.24 GiB used: 64.49 GiB (54.1%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ128HBHQ-00000
    size: 119.24 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: FXV7000Q temp: 19.9 C scheme: GPT
  ID-1: / size: 116.52 GiB used: 64.49 GiB (55.3%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  System Temperatures: cpu: 48.0 C mobo: N/A
  Processes: 205 Uptime: 53m wakeups: 1 Init: systemd v: 251
  default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1371 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
  inxi: 3.3.23
Revisa /var/log/pacman.log a ver qué dice y si da algún error ponlo aquí para más información.
Me dice que el directorio no existe
Pues esto sí que no me lo esperaba… :thinking:
Por curiosidad, ¿existe /var? ¿Existe /var/log? ¿Si copias y pegas en un terminal el siguiente comando también te dice que no existe el directorio?
cat /var/log/pacman.log
A mi me sale el registro de todas las actualizaciones y se pueden ver los mensajes de error.
Otra opción es en el propio “Añadir/Quitar software” vas a los tres puntos de arriba a la derecha y eliges “Ver Historial” a ver si aparece algún error, aunque creo que es menos completo que el log.
En el caso de /var me aparece que no existe y de /var/log me si lo tengo
Este es el registro con el comando que diste:
[2022-10-06T16:42:49-0600] [ALPM] upgraded gwenview (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded harfbuzz-icu (5.1.0-1 -> 5.2.0-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded hdparm (9.64-1 -> 9.65-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded kaccounts-providers (22.08.0-2 -> 22.08.1-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded kactivities-stats (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded kamera (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded ktexteditor (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:49-0600] [ALPM] upgraded kate (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:50-0600] [ALPM] upgraded kcalc (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:50-0600] [ALPM] upgraded kdegraphics-mobipocket (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:50-0600] [ALPM] upgraded kdegraphics-thumbnailers (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:50-0600] [ALPM] upgraded kunitconversion (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:50-0600] [ALPM] upgraded kemoticons (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:50-0600] [ALPM] upgraded kdelibs4support (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:51-0600] [ALPM] upgraded samba (4.16.4-3 -> 4.17.0-1)
[2022-10-06T16:42:51-0600] [ALPM] upgraded kdenetwork-filesharing (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:51-0600] [ALPM] upgraded kdesu (5.97.0-1 -> 5.98.0-3)
[2022-10-06T16:42:51-0600] [ALPM] upgraded kdoctools (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:52-0600] [ALPM] upgraded keditbookmarks (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:52-0600] [ALPM] upgraded kfind (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:52-0600] [ALPM] upgraded kjs (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:52-0600] [ALPM] upgraded khtml (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded khelpcenter (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded kholidays (1:5.97.0-1 -> 1:5.98.0-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded kimageformats (5.97.0-1 -> 5.98.0-2)
[2022-10-06T16:42:53-0600] [ALPM] upgraded knotifyconfig (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded konsole (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded kpeople (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded kpmcore (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded kwayland (5.97.0-1 -> 5.98.0-3)
[2022-10-06T16:42:53-0600] [ALPM] upgraded plasma-framework (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded threadweaver (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:53-0600] [ALPM] upgraded krunner (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded ksanecore (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded ksystemlog (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded kwalletmanager (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded kwayland-integration (5.25.5-1 -> 5.25.5-2)
[2022-10-06T16:42:54-0600] [ALPM] upgraded layer-shell-qt (5.25.5-1 -> 5.25.5-2)
[2022-10-06T16:42:54-0600] [ALPM] upgraded kwin (5.25.5-1 -> 5.25.5-2)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-xz (5.2.5-2 -> 5.2.6-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-systemd (251.4-1.1 -> 251.5-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-dbus (1.14.0-1 -> 1.14.2-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-expat (2.4.8-1 -> 2.4.9-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-flac (1.3.4-3 -> 1.4.1-1)
[2022-10-06T16:42:54-0600] [ALPM] installed lib32-pcre2 (10.40-3)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-glib2 (2.72.3-1 -> 2.74.0-2)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-libpng (1.6.37-3 -> 1.6.38-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-harfbuzz (5.1.0-1 -> 5.2.0-1)
[2022-10-06T16:42:54-0600] [ALPM] upgraded lib32-libdrm (2.4.112-1 -> 2.4.113-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded lib32-libglvnd (1.4.0-3 -> 1.5.0-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded lib32-libsndfile (1.1.0-1 -> 1.1.0-2)
[2022-10-06T16:42:55-0600] [ALPM] upgraded lib32-pcre (8.45-1 -> 8.45-3)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libappimage (1.0.4.5-2 -> 1.0.4.5-3)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libcmis (0.5.2-11 -> 0.5.2-12)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libebml (1.4.2-2 -> 1.4.3-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libetonyek (0.1.10-1 -> 0.1.10-2)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libgee (0.20.5-2 -> 0.20.6-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libhandy (1.6.3-1 -> 1.8.0-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libixion (0.17.0-2 -> 0.17.0-3)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libksane (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libktorrent (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded libmatroska (1.6.3-2 -> 1.7.0-1)
[2022-10-06T16:42:55-0600] [ALPM] upgraded liborcus (0.17.2-2 -> 0.17.2-3)
[2022-10-06T16:43:00-0600] [ALPM] upgraded libreoffice-fresh (7.4.0-3 -> 7.4.1-3)
[2022-10-06T16:43:00-0600] [ALPM] upgraded libreoffice-fresh-es (7.4.0-1 -> 7.4.1-1)
[2022-10-06T16:43:00-0600] [ALPM] upgraded libspectre (0.2.10-1 -> 0.2.10-2)
[2022-10-06T16:43:00-0600] [ALPM] upgraded libwpe (1.12.3-1 -> 1.14.0-1)
[2022-10-06T16:43:00-0600] [ALPM] upgraded linux-firmware-whence (20220815.8413c63-1 -> 20220913.f09bebf-1)
[2022-10-06T16:43:03-0600] [ALPM] upgraded linux-firmware (20220815.8413c63-1 -> 20220913.f09bebf-1)
[2022-10-06T16:43:06-0600] [ALPM] upgraded linux515 (5.15.65-1 -> 5.15.71-1)
[2022-10-06T16:43:06-0600] [ALPM] upgraded lsof (4.95.0-1 -> 4.96.3-1)
[2022-10-06T16:43:06-0600] [ALPM] upgraded manjaro-alsa (20210928-1 -> 20221002-1)
[2022-10-06T16:43:07-0600] [ALPM] installed foomatic-db-ppds (3:20220328-1)
[2022-10-06T16:43:07-0600] [ALPM] installed foomatic-db-nonfree (3:20220328-1)
[2022-10-06T16:43:07-0600] [ALPM] installed foomatic-db-nonfree-ppds (3:20220328-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded manjaro-printer (20220314-1 -> 20220924-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded openpmix (4.2.0-1 -> 4.2.1-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded manjaro-pulse (20220217-2 -> 20221002-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded manjaro-release (22.0.0pre2-1 -> 22.0.0pre3-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded manjaro-settings-manager (0.5.7-9 -> 0.5.7-10)
[2022-10-06T16:43:07-0600] [ALPM] upgraded manjaro-settings-manager-kcm (0.5.7-9 -> 0.5.7-10)
[2022-10-06T16:43:07-0600] [ALPM] upgraded manjaro-settings-manager-knotifier (0.5.7-9 -> 0.5.7-10)
[2022-10-06T16:43:07-0600] [ALPM] upgraded mariadb-libs (10.9.2-1 -> 10.9.3-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded mhwd-nvidia (515.65.01-3 -> 515.76-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded ppp (2.4.9-1 -> 2.4.9-2)
[2022-10-06T16:43:07-0600] [ALPM] upgraded modemmanager (1.18.10-2 -> 1.18.12-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded modemmanager-qt (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded mpd (0.23.9-2 -> 0.23.9-3)
[2022-10-06T16:43:07-0600] [ALPM] upgraded networkmanager-qt (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:43:07-0600] [ALPM] upgraded noto-fonts-emoji (20211101-1 -> 20220920-1)
[2022-10-06T16:43:08-0600] [ALPM] upgraded okular (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:43:09-0600] [ALPM] upgraded oxygen-icons (1:5.97.0-1 -> 1:5.98.0-1)
[2022-10-06T16:43:09-0600] [ALPM] upgraded python-certifi (2022.06.15-1 -> 2022.09.24-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded python-idna (3.3-4 -> 3.4-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded pacman (6.0.1-12 -> 6.0.1-15)
[2022-10-06T16:43:10-0600] [ALPM] upgraded pamac-cli (10.4.2-1 -> 10.4.2-2)
[2022-10-06T16:43:10-0600] [ALPM] upgraded pamac-gtk (10.4.2-1 -> 10.4.2-2)
[2022-10-06T16:43:10-0600] [ALPM] upgraded partitionmanager (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded pcsclite (1.9.8-1 -> 1.9.9-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded perl-ffi-checklib (0.28-3 -> 0.31-2)
[2022-10-06T16:43:10-0600] [ALPM] upgraded perl-path-tiny (0.122-2 -> 0.124-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded perl-alien-build (2.53-1 -> 2.70-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded perl-alien-libxml2 (0.17-3 -> 0.19-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded plasma-integration (5.25.5-1 -> 5.25.5-2)
[2022-10-06T16:43:10-0600] [ALPM] upgraded prison (5.97.0-1 -> 5.98.0-1)
[2022-10-06T16:43:10-0600] [ALPM] upgraded qt5-tools (5.15.5+kde+r1-3 -> 5.15.6+kde+r1-1)
[2022-10-06T16:43:12-0600] [ALPM] upgraded plasma-workspace (5.25.5-1 -> 5.25.5-4)
[2022-10-06T16:43:12-0600] [ALPM] upgraded plasma-wayland-session (5.25.5-1 -> 5.25.5-4)
[2022-10-06T16:43:12-0600] [ALPM] upgraded powertop (2.14-1 -> 2.15-1)
[2022-10-06T16:43:12-0600] [ALPM] upgraded print-manager (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:43:12-0600] [ALPM] upgraded vulkan-headers (1:1.3.221-1 -> 1:1.3.227-1)
[2022-10-06T16:43:12-0600] [ALPM] upgraded qt6-translations (6.3.1-1 -> 6.4.0-1)
[2022-10-06T16:43:13-0600] [ALPM] upgraded qt6-base (6.3.1-1 -> 6.4.0-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded qt6-declarative (6.3.1-1 -> 6.4.0-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded shiboken6 (6.3.1-3 -> 6.3.2-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded pyside6 (6.3.1-3 -> 6.3.2-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-cryptography (37.0.4-1 -> 38.0.1-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-importlib-metadata (4.8.3-1 -> 4.9.0-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-jaraco.functools (3.5.1-1 -> 3.5.2-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-psutil (5.9.1-1 -> 5.9.2-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-pyopenssl (22.0.0-1 -> 22.1.0-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-pyqt5 (5.15.7-1 -> 5.15.7-2)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-trove-classifiers (2022.8.31-1 -> 2022.9.26-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-setuptools (1:62.3.4-1 -> 1:63.0.0-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-shiboken2 (5.15.5-3 -> 5.15.6-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded python-tenacity (8.0.1-3 -> 8.1.0-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded qt5-imageformats (5.15.5+kde+r4-1 -> 5.15.6+kde+r4-1)
[2022-10-06T16:43:14-0600] [ALPM] upgraded qt5-script (5.15.10-2 -> 5.15.10-3)
[2022-10-06T16:43:14-0600] [ALPM] upgraded qt5-sensors (5.15.5+kde+r0-1 -> 5.15.6+kde+r0-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded qt5-virtualkeyboard (5.15.5+kde+r3-1 -> 5.15.6+kde+r1-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded qt5-webkit (5.212.0alpha4-15 -> 5.212.0alpha4-16)
[2022-10-06T16:43:15-0600] [ALPM] upgraded qt5-xmlpatterns (5.15.5+kde+r0-1 -> 5.15.6+kde+r0-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded rsync (3.2.5-2 -> 3.2.6-2)
[2022-10-06T16:43:15-0600] [ALPM] upgraded rubygems (3.3.19-1 -> 3.3.21-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded ruby-bundler (2.3.19-1 -> 2.3.22-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded sdl12-compat (1.2.52-2 -> 1.2.56-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded skanlite (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded spectacle (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded systemd-sysvcompat (251.4-1 -> 251.5-1)
[2022-10-06T16:43:15-0600] [ALPM] upgraded thermald (2.5-1 -> 2.5.1-1)
[2022-10-06T16:43:16-0600] [ALPM] upgraded thunderbird (102.3.1-0.1 -> 102.3.1-1)
[2022-10-06T16:43:16-0600] [ALPM] upgraded xapp (2.2.14-1 -> 2.2.15-1)
[2022-10-06T16:43:16-0600] [ALPM] upgraded timeshift (22.06.5-1 -> 22.06.5-2)
[2022-10-06T16:43:17-0600] [ALPM] upgraded vlc (3.0.17.4-7 -> 3.0.17.4-8)
[2022-10-06T16:43:17-0600] [ALPM] upgraded vulkan-tools (1.3.217-1 -> 1.3.226-1)
[2022-10-06T16:43:17-0600] [ALPM] upgraded wayland-utils (1.0.0-2 -> 1.1.0-1)
[2022-10-06T16:43:17-0600] [ALPM] upgraded wpebackend-fdo (1.12.1-1 -> 1.14.0-1)
[2022-10-06T16:43:17-0600] [ALPM] upgraded webkit2gtk (2.36.7-1 -> 2.38.0-2)
[2022-10-06T16:43:18-0600] [ALPM] upgraded webkit2gtk-4.1 (2.36.7-1 -> 2.38.0-2)
[2022-10-06T16:43:18-0600] [ALPM] upgraded yakuake (22.08.0-1 -> 22.08.1-1)
[2022-10-06T16:43:18-0600] [ALPM] transaction completed
[2022-10-06T16:43:24-0600] [ALPM] running '20-systemd-sysusers.hook'...
[2022-10-06T16:43:24-0600] [ALPM] running '30-systemd-catalog.hook'...
[2022-10-06T16:43:24-0600] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-10-06T16:43:24-0600] [ALPM] running '30-systemd-hwdb.hook'...
[2022-10-06T16:43:25-0600] [ALPM] running '30-systemd-sysctl.hook'...
[2022-10-06T16:43:25-0600] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-10-06T16:43:25-0600] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-10-06T16:43:25-0600] [ALPM] running '30-systemd-update.hook'...
[2022-10-06T16:43:25-0600] [ALPM] running '30-update-mime-database.hook'...
[2022-10-06T16:43:26-0600] [ALPM] running '40-update-ca-trust.hook'...
[2022-10-06T16:43:27-0600] [ALPM] running '60-depmod.hook'...
[2022-10-06T16:43:41-0600] [ALPM] running '60-glibc-locales.hook'...
[2022-10-06T16:43:42-0600] [ALPM] running '80-cronie.hook'...
[2022-10-06T16:43:42-0600] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-10-06T16:43:42-0600] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2022-10-06T16:43:42-0600] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2022-10-06T16:43:43-0600] [ALPM-SCRIPTLET] ==> Starting build: 5.15.71-1-MANJARO
[2022-10-06T16:43:43-0600] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-10-06T16:43:43-0600] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-10-06T16:43:43-0600] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2022-10-06T16:43:43-0600] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-10-06T16:43:43-0600] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-10-06T16:43:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-10-06T16:43:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2022-10-06T16:43:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-10-06T16:43:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-10-06T16:43:44-0600] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-10-06T16:43:45-0600] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET] ==> Starting build: 5.15.71-1-MANJARO
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-10-06T16:43:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-10-06T16:43:48-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-10-06T16:43:49-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-10-06T16:43:49-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-10-06T16:43:49-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-10-06T16:43:51-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-10-06T16:43:52-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2022-10-06T16:43:53-0600] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-10-06T16:43:54-0600] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-10-06T16:43:57-0600] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-10-06T16:43:58-0600] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-10-06T16:44:07-0600] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-10-06T16:44:07-0600] [ALPM] running '99-grub.hook'...
[2022-10-06T16:44:07-0600] [ALPM-SCRIPTLET] Generando un fichero de configuración de grub...
[2022-10-06T16:44:07-0600] [ALPM-SCRIPTLET] Encontrado tema: /usr/share/grub/themes/manjaro/theme.txt
[2022-10-06T16:44:07-0600] [ALPM-SCRIPTLET] Encontrada imagen de linux: /boot/vmlinuz-5.15-x86_64
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] Encontrada imagen de memoria inicial: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] fgrep: warning: fgrep is obsolescent; using grep -F
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] Aviso: os-prober will be executed to detect other bootable partitions.
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] /usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido.
[2022-10-06T16:44:08-0600] [ALPM-SCRIPTLET] hecho
[2022-10-06T16:44:08-0600] [ALPM] running 'dbus-reload.hook'...
[2022-10-06T16:44:08-0600] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-10-06T16:44:08-0600] [ALPM] running 'firefox-post.hook'...
[2022-10-06T16:44:09-0600] [ALPM] running 'fontconfig.hook'...
[2022-10-06T16:44:09-0600] [ALPM] running 'gio-querymodules.hook'...
[2022-10-06T16:44:09-0600] [ALPM] running 'glib-compile-schemas.hook'...
[2022-10-06T16:44:09-0600] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2022-10-06T16:44:09-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-10-06T16:44:09-0600] [ALPM] running 'kernel-alive-post.hook'...
[2022-10-06T16:44:10-0600] [ALPM-SCRIPTLET]
[2022-10-06T16:44:10-0600] [ALPM-SCRIPTLET] ==> Warning:
[2022-10-06T16:44:10-0600] [ALPM-SCRIPTLET]      -> Kernel has been updated. Modules of the current kernel
[2022-10-06T16:44:10-0600] [ALPM-SCRIPTLET]      -> have been backed up so you can continue to use your
[2022-10-06T16:44:10-0600] [ALPM-SCRIPTLET]      -> computer. However, the new kernel will only work
[2022-10-06T16:44:10-0600] [ALPM-SCRIPTLET]      -> at next boot.
[2022-10-06T16:44:10-0600] [ALPM] running 'locale-gen.hook'...
[2022-10-06T16:44:10-0600] [ALPM] running 'texinfo-install.hook'...
[2022-10-06T16:44:13-0600] [ALPM] running 'thunderbird-post.hook'...
[2022-10-06T16:44:13-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-10-06T16:44:13-0600] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2022-10-06T16:44:13-0600] [ALPM] running 'xorg-mkfontscale.hook'...
[2022-10-10T17:00:22-0600] [PAMAC] synchronizing package lists
[2022-10-10T17:05:04-0600] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-10-10T17:05:04-0600] [ALPM] running 'firefox-pre.hook'...
[2022-10-10T17:05:04-0600] [ALPM] running 'kernel-alive-pre.hook'...
[2022-10-10T17:05:05-0600] [ALPM] running 'thunderbird-pre.hook'...
[2022-10-10T17:05:05-0600] [ALPM] transaction started
[2022-10-10T17:05:06-0600] [ALPM] upgraded glibc (2.36-4.0 -> 2.36-5)
[2022-10-10T17:05:06-0600] [ALPM-SCRIPTLET] Generating locales...
[2022-10-10T17:05:07-0600] [ALPM-SCRIPTLET]   es_HN.UTF-8... done
[2022-10-10T17:05:07-0600] [ALPM-SCRIPTLET] Generation complete.
[2022-10-10T17:05:07-0600] [ALPM] upgraded xz (5.2.6-1 -> 5.2.7-1)
[2022-10-10T17:05:07-0600] [ALPM] upgraded lib32-glibc (2.36-4.0 -> 2.36-5)
[2022-10-10T17:05:07-0600] [ALPM] upgraded libbpf (0.8.1-1 -> 1.0.1-1)
[2022-10-10T17:05:07-0600] [ALPM] upgraded iproute2 (5.19.0-1 -> 6.0.0-1)
[2022-10-10T17:05:07-0600] [ALPM] upgraded dhclient (4.4.3-3 -> 4.4.3.P1-1)
[2022-10-10T17:05:07-0600] [ALPM] upgraded f2fs-tools (1.15.0-1 -> 1.15.0-2)
[2022-10-10T17:05:07-0600] [ALPM] upgraded hwdata (0.362-2 -> 0.363-1)
[2022-10-10T17:05:07-0600] [ALPM] upgraded pango (1:1.50.10-1 -> 1:1.50.11-1)
[2022-10-10T17:05:07-0600] [ALPM] upgraded xkeyboard-config (2.36+89+g382c5feb-1 -> 2.37-1)
[2022-10-10T17:05:08-0600] [ALPM] upgraded firefox (105.0.2-1 -> 105.0.3-1)
[2022-10-10T17:05:08-0600] [ALPM] upgraded firefox-i18n-en-us (105.0.2-1 -> 105.0.3-1)
[2022-10-10T17:05:08-0600] [ALPM] upgraded foomatic-db (3:20220328-1 -> 3:20221004-1)
[2022-10-10T17:05:08-0600] [ALPM] upgraded foomatic-db-nonfree (3:20220328-1 -> 3:20221004-1)
[2022-10-10T17:05:08-0600] [ALPM] upgraded foomatic-db-nonfree-ppds (3:20220328-1 -> 3:20221004-1)
[2022-10-10T17:05:08-0600] [ALPM] upgraded foomatic-db-ppds (3:20220328-1 -> 3:20221004-1)
[2022-10-10T17:05:09-0600] [ALPM] upgraded git (2.37.3-1 -> 2.38.0-1)
[2022-10-10T17:05:13-0600] [ALPM] upgraded go (2:1.19.1-1 -> 2:1.19.2-1)
[2022-10-10T17:05:13-0600] [ALPM] upgraded inxi (3.3.21.1-1 -> 3.3.22.1-1)
[2022-10-10T17:05:13-0600] [ALPM] upgraded lib32-xz (5.2.6-1 -> 5.2.7-1)
[2022-10-10T17:05:13-0600] [ALPM] upgraded libcdio (2.1.0-2 -> 2.1.0-3)
[2022-10-10T17:05:13-0600] [ALPM] upgraded libimagequant (4.0.1-1 -> 4.0.4-1)
[2022-10-10T17:05:13-0600] [ALPM] upgraded libupnp (1.14.13-1 -> 1.14.14-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded linux515 (5.15.71-1 -> 5.15.72-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded mhwd-nvidia-390xx (390.154-1 -> 390.154-2)
[2022-10-10T17:05:14-0600] [ALPM] upgraded mhwd-nvidia-470xx (470.141.03-1 -> 470.141.03-2)
[2022-10-10T17:05:14-0600] [ALPM] upgraded pacman (6.0.1-15 -> 6.0.2-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded perl-alien-build (2.70-1 -> 2.71-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded perl-xml-libxml (2.0207-3 -> 2.0208-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded python-rich (12.5.1-1 -> 12.6.0-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded python-setuptools (1:63.0.0-1 -> 1:63.2.0-1)
[2022-10-10T17:05:14-0600] [ALPM] upgraded rubygems (3.3.21-1 -> 3.3.21-2)
[2022-10-10T17:05:14-0600] [ALPM] upgraded ruby-abbrev (0.1.0-1 -> 0.1.0-3)
[2022-10-10T17:05:14-0600] [ALPM] upgraded ruby-base64 (0.1.1-1 -> 0.1.1-3)
[2022-10-10T17:05:14-0600] [ALPM] upgraded ruby-benchmark (0.2.0-1 -> 0.2.0-3)
[2022-10-10T17:05:14-0600] [ALPM] upgraded ruby-bigdecimal (3.1.2-1 -> 3.1.2-3)
[2022-10-10T17:05:14-0600] [ALPM] upgraded ruby-bundler (2.3.22-1 -> 2.3.22-2)
[2022-10-10T17:05:14-0600] [ALPM] upgraded ruby-cgi (0.3.2-1 -> 0.3.2-9)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-csv (3.2.5-1 -> 3.2.5-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-date (3.2.2-1 -> 3.2.2-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-delegate (0.2.0-1 -> 0.2.0-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-did_you_mean (1.6.1-1 -> 1.6.1-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-digest (3.1.0-1 -> 3.1.0-5)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-drb (2.1.0-1 -> 2.1.0-4)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-english (0.7.1-1 -> 0.7.1-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-erb (2.2.3-2 -> 2.2.3-4)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-etc (1.3.0-2 -> 1.3.0-5)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-fcntl (1.0.1-1 -> 1.0.1-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-fiddle (1.1.0-1 -> 1.1.0-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-fileutils (1.6.0-1 -> 1.6.0-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-find (0.1.1-1 -> 0.1.1-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-forwardable (1.3.2-1 -> 1.3.2-5)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-getoptlong (0.1.1-1 -> 0.1.1-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-io-console (0.5.11-1 -> 0.5.11-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-io-nonblock (0.1.0-1 -> 0.1.0-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-io-wait (0.2.3-1 -> 0.2.3-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-ipaddr (1.2.4-1 -> 1.2.4-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-reline (0.3.1-1 -> 0.3.1-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-irb (1.4.1-1 -> 1.4.1-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-json (2.6.2-1 -> 2.6.2-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-logger (1.5.1-1 -> 1.5.1-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-mutex_m (0.1.1-1 -> 0.1.1-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-uri (0.11.0-2 -> 0.11.0-5)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-net-http (0.2.2-1 -> 0.2.2-2)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-stringio (3.0.2-1 -> 3.0.2-4)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-time (0.2.0-2 -> 0.2.0-4)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-open-uri (0.2.0-2 -> 0.2.0-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-psych (4.0.4-2 -> 4.0.4-4)
[2022-10-10T17:05:15-0600] [ALPM] installed ruby-racc (1.6.0-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-rdoc (6.4.0-2 -> 6.4.0-4)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-tmpdir (0.1.2-1 -> 0.1.2-3)
[2022-10-10T17:05:15-0600] [ALPM] upgraded ruby-stdlib (3.0.4-9 -> 3.0.4-18)
[2022-10-10T17:05:16-0600] [ALPM] upgraded ruby-test-unit (3.5.3-1 -> 3.5.4-1)
[2022-10-10T17:05:16-0600] [ALPM] upgraded ruby-bundledgems (3.0.4-9 -> 3.0.4-18)
[2022-10-10T17:05:16-0600] [ALPM] upgraded ruby (3.0.4-9 -> 3.0.4-18)
[2022-10-10T17:05:16-0600] [ALPM] upgraded thunderbird (102.3.1-1 -> 102.3.2-1)
[2022-10-10T17:05:17-0600] [ALPM] upgraded vlc (3.0.17.4-8 -> 3.0.17.4-9)
[2022-10-10T17:05:17-0600] [ALPM] installed debugedit (5.0-4)
[2022-10-10T17:05:18-0600] [ALPM] transaction completed
[2022-10-10T17:05:19-0600] [ALPM] running '20-systemd-sysusers.hook'...
[2022-10-10T17:05:20-0600] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-10-10T17:05:20-0600] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-10-10T17:05:20-0600] [ALPM] running '30-systemd-update.hook'...
[2022-10-10T17:05:20-0600] [ALPM] running '60-depmod.hook'...
[2022-10-10T17:05:28-0600] [ALPM] running '60-glibc-locales.hook'...
[2022-10-10T17:05:40-0600] [ALPM] running '80-cronie.hook'...
[2022-10-10T17:05:40-0600] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-10-10T17:05:40-0600] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2022-10-10T17:05:40-0600] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2022-10-10T17:05:40-0600] [ALPM-SCRIPTLET] ==> Starting build: 5.15.72-1-MANJARO
[2022-10-10T17:05:41-0600] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-10-10T17:05:41-0600] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-10-10T17:05:41-0600] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2022-10-10T17:05:41-0600] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-10-10T17:05:41-0600] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-10-10T17:05:42-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-10-10T17:05:42-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2022-10-10T17:05:42-0600] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-10-10T17:05:42-0600] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-10-10T17:05:42-0600] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-10-10T17:05:42-0600] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
[2022-10-10T17:05:43-0600] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-10-10T17:05:43-0600] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2022-10-10T17:05:43-0600] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2022-10-10T17:05:43-0600] [ALPM-SCRIPTLET] ==> Starting build: 5.15.72-1-MANJARO
[2022-10-10T17:05:43-0600] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-10-10T17:05:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-10-10T17:05:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-10-10T17:05:44-0600] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-10-10T17:05:45-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-10-10T17:05:45-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-10-10T17:05:45-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-10-10T17:05:45-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-10-10T17:05:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-10-10T17:05:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2022-10-10T17:05:47-0600] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-10-10T17:05:48-0600] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-10-10T17:05:50-0600] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-10-10T17:05:50-0600] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-10-10T17:05:55-0600] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-10-10T17:05:55-0600] [ALPM] running '99-grub.hook'...
[2022-10-10T17:05:56-0600] [ALPM-SCRIPTLET] Generando un fichero de configuración de grub...
[2022-10-10T17:05:56-0600] [ALPM-SCRIPTLET] Encontrado tema: /usr/share/grub/themes/manjaro/theme.txt
[2022-10-10T17:05:57-0600] [ALPM-SCRIPTLET] Encontrada imagen de linux: /boot/vmlinuz-5.15-x86_64
[2022-10-10T17:05:57-0600] [ALPM-SCRIPTLET] Encontrada imagen de memoria inicial: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-10-10T17:05:57-0600] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-10-10T17:05:57-0600] [ALPM-SCRIPTLET] fgrep: warning: fgrep is obsolescent; using grep -F
[2022-10-10T17:05:57-0600] [ALPM-SCRIPTLET] Aviso: os-prober will be executed to detect other bootable partitions.
[2022-10-10T17:05:57-0600] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2022-10-10T17:05:58-0600] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2022-10-10T17:05:58-0600] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-10-10T17:05:58-0600] [ALPM-SCRIPTLET] /usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido.
[2022-10-10T17:05:58-0600] [ALPM-SCRIPTLET] hecho
[2022-10-10T17:05:58-0600] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-10-10T17:05:58-0600] [ALPM] running 'firefox-post.hook'...
[2022-10-10T17:05:58-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-10-10T17:05:59-0600] [ALPM] running 'kernel-alive-post.hook'...
[2022-10-10T17:06:02-0600] [ALPM-SCRIPTLET]
[2022-10-10T17:06:02-0600] [ALPM-SCRIPTLET] ==> Warning:
[2022-10-10T17:06:02-0600] [ALPM-SCRIPTLET]      -> Kernel has been updated. Modules of the current kernel
[2022-10-10T17:06:02-0600] [ALPM-SCRIPTLET]      -> have been backed up so you can continue to use your
[2022-10-10T17:06:02-0600] [ALPM-SCRIPTLET]      -> computer. However, the new kernel will only work
[2022-10-10T17:06:02-0600] [ALPM-SCRIPTLET]      -> at next boot.
[2022-10-10T17:06:02-0600] [ALPM] running 'locale-gen.hook'...
[2022-10-10T17:06:02-0600] [ALPM] running 'texinfo-install.hook'...
[2022-10-10T17:06:03-0600] [ALPM] running 'thunderbird-post.hook'...
[2022-10-10T17:06:03-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-10-10T17:06:03-0600] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2022-10-10T17:07:29-0600] [ALPM] transaction started
[2022-10-10T17:07:30-0600] [ALPM] upgraded zoom (5.12.0-1 -> 5.12.2-1)
[2022-10-10T17:07:31-0600] [ALPM] transaction completed
[2022-10-10T17:07:31-0600] [ALPM] running '30-systemd-update.hook'...
[2022-10-10T17:07:31-0600] [ALPM] running '30-update-mime-database.hook'...
[2022-10-10T17:07:32-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-10-11T16:26:49-0600] [PAMAC] synchronizing package lists
[2022-10-11T16:27:02-0600] [ALPM] transaction started
[2022-10-11T16:27:03-0600] [ALPM] upgraded lib32-glibc (2.36-5 -> 2.36-5.1)
[2022-10-11T16:27:03-0600] [ALPM] upgraded mhwd-nvidia-470xx (470.141.03-2 -> 470.141.03-3)
[2022-10-11T16:27:03-0600] [ALPM] transaction completed
[2022-10-11T16:27:03-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-02T13:48:06-0600] [PAMAC] synchronizing package lists
[2022-11-02T13:48:54-0600] [PAMAC] synchronizing package lists
[2022-11-02T13:50:06-0600] [ALPM] transaction started
[2022-11-02T13:50:06-0600] [ALPM-SCRIPTLET] ==> Delete expired Build-Server Key
[2022-11-02T13:50:06-0600] [ALPM-SCRIPTLET] ==> Actualizando la base de datos de claves de confianza...
[2022-11-02T13:50:06-0600] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2022-11-02T13:50:06-0600] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2022-11-02T13:50:07-0600] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: pgp
[2022-11-02T13:50:07-0600] [ALPM-SCRIPTLET] gpg: nivel: 0  validez:   1  firmada:  24  confianza: 0-, 0q, 0n, 0m, 0f, 1u
[2022-11-02T13:50:07-0600] [ALPM-SCRIPTLET] gpg: nivel: 1  validez:  24  firmada:  97  confianza: 0-, 0q, 0n, 24m, 0f, 0u
[2022-11-02T13:50:07-0600] [ALPM-SCRIPTLET] gpg: nivel: 2  validez:  74  firmada:  28  confianza: 74-, 0q, 0n, 0m, 0f, 0u
[2022-11-02T13:50:07-0600] [ALPM-SCRIPTLET] gpg: siguiente comprobación de base de datos de confianza el: 2022-11-16
[2022-11-02T13:50:07-0600] [ALPM] upgraded manjaro-keyring (20220514-2 -> 20221028-4)
[2022-11-02T13:50:07-0600] [ALPM-SCRIPTLET] ==> Añadiendo las claves de manjaro.gpg...
[2022-11-02T13:50:10-0600] [ALPM-SCRIPTLET] ==> Firmando localmente las claves de confianza en el depósito...
[2022-11-02T13:50:11-0600] [ALPM-SCRIPTLET]   -> Se han firmado localmente 3 claves.
[2022-11-02T13:50:11-0600] [ALPM-SCRIPTLET] ==> Importando los valores de confianza del propietario...
[2022-11-02T13:50:11-0600] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2022-11-02T13:50:11-0600] [ALPM-SCRIPTLET] ==> Actualizando la base de datos de claves de confianza...
[2022-11-02T13:50:11-0600] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2022-11-02T13:50:11-0600] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2022-11-02T13:50:12-0600] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: pgp
[2022-11-02T13:50:12-0600] [ALPM-SCRIPTLET] gpg: nivel: 0  validez:   1  firmada:  26  confianza: 0-, 0q, 0n, 0m, 0f, 1u
[2022-11-02T13:50:13-0600] [ALPM-SCRIPTLET] gpg: nivel: 1  validez:  26  firmada:  97  confianza: 0-, 0q, 0n, 26m, 0f, 0u
[2022-11-02T13:50:13-0600] [ALPM-SCRIPTLET] gpg: nivel: 2  validez:  74  firmada:  28  confianza: 74-, 0q, 0n, 0m, 0f, 0u
[2022-11-02T13:50:13-0600] [ALPM-SCRIPTLET] gpg: siguiente comprobación de base de datos de confianza el: 2022-11-16
[2022-11-02T13:50:13-0600] [ALPM] transaction completed
[2022-11-02T13:50:13-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-02T14:06:48-0600] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-11-02T14:06:48-0600] [ALPM] running 'firefox-pre.hook'...
[2022-11-02T14:06:48-0600] [ALPM] running 'kernel-alive-pre.hook'...
[2022-11-02T14:06:49-0600] [ALPM] running 'thunderbird-pre.hook'...
[2022-11-02T14:06:49-0600] [ALPM] transaction started
[2022-11-02T14:06:49-0600] [ALPM] upgraded alsa-card-profiles (1:0.3.58-1 -> 1:0.3.59-2)
[2022-11-02T14:06:49-0600] [ALPM] upgraded alsa-ucm-conf (1.2.7.2-1 -> 1.2.8-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded iana-etc (20220915-1 -> 20221025-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded filesystem (2022.06.08-3 -> 2022.10.18-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded tzdata (2022d-1 -> 2022f-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded alsa-lib (1.2.7.2-1 -> 1.2.8-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded zlib (1:1.2.12-2 -> 1:1.2.13-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded readline (8.1.002-1 -> 8.2.0-1)
[2022-11-02T14:06:49-0600] [ALPM] upgraded alsa-utils (1.2.7-1 -> 1.2.8-1)
[2022-11-02T14:06:50-0600] [ALPM] upgraded archlinux-appstream-data (20220830-1 -> 20221014-1)
[2022-11-02T14:06:50-0600] [ALPM] upgraded xcb-util-keysyms (0.4.0-4 -> 0.4.1-4)
[2022-11-02T14:06:50-0600] [ALPM] upgraded xcb-util-renderutil (0.3.9-4 -> 0.3.10-1)
[2022-11-02T14:06:50-0600] [ALPM] upgraded expat (2.4.9-1 -> 2.5.0-1)
[2022-11-02T14:06:50-0600] [ALPM] upgraded libffi (3.4.3-1 -> 3.4.4-1)
[2022-11-02T14:06:50-0600] [ALPM] upgraded glib2 (2.74.0-2 -> 2.74.1-1)
[2022-11-02T14:06:50-0600] [ALPM] upgraded harfbuzz (5.2.0-1 -> 5.3.1-3)
[2022-11-02T14:06:50-0600] [ALPM] upgraded fontconfig (2:2.14.0-1 -> 2:2.14.1-2)
[2022-11-02T14:06:50-0600] [ALPM-SCRIPTLET] Rebuilding fontconfig cache...
[2022-11-02T14:06:53-0600] [ALPM] upgraded xcb-util-wm (0.4.1-4 -> 0.4.2-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded libxrender (0.9.10-5 -> 0.9.11-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded xcb-util-image (0.4.0-4 -> 0.4.1-2)
[2022-11-02T14:06:53-0600] [ALPM] upgraded libxshmfence (1.3-3 -> 1.3.1-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded libxext (1.3.4-4 -> 1.3.5-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded lib32-glibc (2.36-5.1 -> 2.36-6)
[2022-11-02T14:06:53-0600] [ALPM] upgraded libpciaccess (0.16-4 -> 0.17-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded libgpg-error (1.45-2 -> 1.46-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded pambase (20211210-1 -> 20221020-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded systemd-libs (251.5-1 -> 251.7-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded ca-certificates-mozilla (3.83-1 -> 3.84-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded curl (7.85.0-2 -> 7.86.0-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded icu (71.1-1 -> 72.1-1)
[2022-11-02T14:06:53-0600] [ALPM] upgraded libxml2 (2.10.2-2 -> 2.10.3-2)
[2022-11-02T14:06:54-0600] [ALPM] upgraded mesa (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:06:54-0600] [ALPM] upgraded dbus (1.14.2-1 -> 1.14.4-1)
[2022-11-02T14:06:54-0600] [ALPM] upgraded shadow (4.11.1-1 -> 4.11.1-3)
[2022-11-02T14:06:55-0600] [ALPM] upgraded systemd (251.5-1 -> 251.7-1)
[2022-11-02T14:06:55-0600] [ALPM] upgraded libwacom (2.4.0-1 -> 2.5.0-1)
[2022-11-02T14:06:55-0600] [ALPM] upgraded libxmu (1.1.3-3 -> 1.1.4-1)
[2022-11-02T14:06:56-0600] [ALPM] upgraded qt5-base (5.15.6+kde+r177-1 -> 5.15.6+kde+r181-1)
[2022-11-02T14:06:56-0600] [ALPM] upgraded polkit (121-1 -> 122-1)
[2022-11-02T14:06:56-0600] [ALPM] upgraded btrfs-progs (5.19.1-1 -> 6.0-1)
[2022-11-02T14:06:56-0600] [ALPM] upgraded dmraid (1.0.0.rc16.3-13 -> 1.0.0.rc16.3-14)
[2022-11-02T14:06:56-0600] [ALPM] upgraded xfsprogs (5.19.0-1 -> 5.19.0-2)
[2022-11-02T14:06:56-0600] [ALPM] upgraded nss (3.83-1 -> 3.84-1)
[2022-11-02T14:06:56-0600] [ALPM] upgraded libksba (1.6.0-1 -> 1.6.2-1)
[2022-11-02T14:06:56-0600] [ALPM] upgraded gnupg (2.2.39-1 -> 2.2.40-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded solid (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kcoreaddons (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kwidgetsaddons (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kjobwidgets (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kdbusaddons (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kconfig (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kwindowsystem (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kcrash (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kglobalaccel (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kauth (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kcodecs (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kguiaddons (5.98.0-1 -> 5.99.0-2)
[2022-11-02T14:06:57-0600] [ALPM] upgraded ki18n (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded kconfigwidgets (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:57-0600] [ALPM] upgraded karchive (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kiconthemes (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kitemviews (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kxmlgui (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kbookmarks (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded flac (1.4.1-1 -> 1.4.2-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded gstreamer (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded orc (0.4.32-1 -> 0.4.32-2)
[2022-11-02T14:06:58-0600] [ALPM] upgraded gst-plugins-base-libs (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded pixman (0.40.0-2 -> 0.42.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded gst-plugins-base (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded knotifications (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kservice (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded qca-qt5 (2.3.4-3 -> 2.3.5-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kwallet (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kcompletion (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded sonnet (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded ktextwidgets (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:58-0600] [ALPM] upgraded kded (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded kio (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded kparts (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded kpty (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded kitemmodels (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded ark (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded attica (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded poppler (22.09.0-1 -> 22.10.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded poppler-qt5 (22.09.0-1 -> 22.10.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded taglib (1.12-2 -> 1.13-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded gettext (0.21-2 -> 0.21.1-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded gdk-pixbuf2 (2.42.9-1 -> 2.42.10-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded librsvg (2:2.54.5-1 -> 2:2.55.1-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded sdl2 (2.24.0-2 -> 2.24.1-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded svt-av1 (1.2.1-1 -> 1.3.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded kfilemetadata (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded kidletime (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded baloo (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded baloo-widgets (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:06:59-0600] [ALPM] upgraded libical (3.0.14-3 -> 3.0.16-2)
[2022-11-02T14:07:00-0600] [ALPM] upgraded bluez-qt (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded kpackage (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded kdeclarative (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded bluedevil (1:5.25.5-1 -> 1:5.26.2-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded boost-libs (1.80.0-2 -> 1.80.0-3)
[2022-11-02T14:07:00-0600] [ALPM] upgraded syndication (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded knewstuff (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded frameworkintegration (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:00-0600] [ALPM] upgraded kdecoration (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:02-0600] [ALPM] upgraded breeze-icons (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:02-0600] [ALPM] upgraded kwayland (5.98.0-3 -> 5.99.0-1)
[2022-11-02T14:07:02-0600] [ALPM] upgraded kirigami2 (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:02-0600] [ALPM] upgraded breeze (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:02-0600] [ALPM] upgraded cantata (2.5.0-1 -> 2.5.0-2)
[2022-11-02T14:07:02-0600] [ALPM] upgraded cpupower (5.19-1 -> 6.0-1)
[2022-11-02T14:07:03-0600] [ALPM] upgraded kdnssd (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:03-0600] [ALPM] upgraded python (3.10.7-1 -> 3.10.8-2)
[2022-11-02T14:07:03-0600] [ALPM] upgraded libbsd (0.11.6-2 -> 0.11.7-1)
[2022-11-02T14:07:03-0600] [ALPM] upgraded smbclient (4.17.0-1 -> 4.17.2-1)
[2022-11-02T14:07:03-0600] [ALPM] upgraded libkexiv2 (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded syntax-highlighting (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded kio-extras (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded kcmutils (5.98.0-1 -> 5.99.0-2)
[2022-11-02T14:07:04-0600] [ALPM] upgraded kactivities (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded dolphin (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded dolphin-plugins (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded enchant (2.3.3-1 -> 2.3.3-2)
[2022-11-02T14:07:04-0600] [ALPM] upgraded faad2 (2.10.0-1 -> 2.10.1-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded ffmpegthumbs (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded qqc2-desktop-style (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded kquickcharts (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded filelight (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded gtk-update-icon-cache (1:4.8.1-1 -> 1:4.8.2-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded libxinerama (1.1.4-4 -> 1.1.5-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded libsoup3 (3.2.0-1 -> 3.2.1-1)
[2022-11-02T14:07:04-0600] [ALPM] upgraded tracker3 (3.4.0-1 -> 3.4.1-1)
[2022-11-02T14:07:05-0600] [ALPM] upgraded firefox (105.0.3-1 -> 106.0.2-1)
[2022-11-02T14:07:05-0600] [ALPM] upgraded firefox-i18n-en-us (105.0.3-1 -> 106.0.2-1)
[2022-11-02T14:07:05-0600] [ALPM] upgraded freeglut (3.2.2-2 -> 3.4.0-1)
[2022-11-02T14:07:05-0600] [ALPM] upgraded libgusb (0.4.0-1 -> 0.4.2-1)
[2022-11-02T14:07:05-0600] [ALPM] upgraded libmm-glib (1.18.12-1 -> 1.20.0-1)
[2022-11-02T14:07:05-0600] [ALPM] upgraded libmbim (1.26.4-1 -> 1.28.0-1)
[2022-11-02T14:07:06-0600] [ALPM] upgraded libqmi (1.30.8-1 -> 1.32.0-1)
[2022-11-02T14:07:06-0600] [ALPM] upgraded fwupd (1.8.5-1 -> 1.8.6-1)
[2022-11-02T14:07:06-0600] [ALPM] upgraded libsoup (2.74.2-2 -> 2.74.3-1)
[2022-11-02T14:07:06-0600] [ALPM] upgraded geoclue (2.6.0-2 -> 2.6.0-3)
[2022-11-02T14:07:07-0600] [ALPM] upgraded git (2.38.0-1 -> 2.38.1-1)
[2022-11-02T14:07:07-0600] [ALPM] upgraded gnustep-base (1.28.0-4 -> 1.28.0-5)
[2022-11-02T14:07:08-0600] [ALPM] upgraded grub (2.06.r261.g2f4430cc0-2 -> 2.06.r261.g2f4430cc0-3)
[2022-11-02T14:07:08-0600] [ALPM-SCRIPTLET] :: GRUB no longer supports side-loading modules when secure boot is
[2022-11-02T14:07:08-0600] [ALPM-SCRIPTLET]    enabled. Thus booting will fail unless you have a 'grubx64.efi'
[2022-11-02T14:07:08-0600] [ALPM-SCRIPTLET]    executable with bundled modules.
[2022-11-02T14:07:08-0600] [ALPM] upgraded gst-libav (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:07:08-0600] [ALPM] upgraded gst-plugins-bad-libs (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:07:08-0600] [ALPM] upgraded libde265 (1.0.8-2 -> 1.0.9-1)
[2022-11-02T14:07:08-0600] [ALPM] upgraded pipewire (1:0.3.58-1 -> 1:0.3.59-2)
[2022-11-02T14:07:08-0600] [ALPM] upgraded raptor (2.0.15-19 -> 2.0.15-20)
[2022-11-02T14:07:09-0600] [ALPM] upgraded imagemagick (7.1.0.49-1 -> 7.1.0.51-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded gst-plugins-bad (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded gst-plugins-good (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded gst-plugins-ugly (1.20.3-2 -> 1.20.4-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded libkdcraw (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded signon-kwallet-extension (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded libxkbfile (1.1.0-3 -> 1.1.1-1)
[2022-11-02T14:07:09-0600] [ALPM] upgraded minizip (1:1.2.12-2 -> 1:1.2.13-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded qt5-webengine (5.15.10-3 -> 5.15.11-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded kaccounts-integration (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded purpose (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded gwenview (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded harfbuzz-icu (5.2.0-1 -> 5.3.1-3)
[2022-11-02T14:07:10-0600] [ALPM] upgraded hunspell-es_hn (1:2.6-2 -> 1:2.7-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded hyphen-es (1:2.6-2 -> 1:2.7-1)
[2022-11-02T14:07:10-0600] [ALPM] upgraded inxi (3.3.22.1-1 -> 3.3.23.1-1)
[2022-11-02T14:07:11-0600] [ALPM] upgraded jre8-openjdk-headless (8.345.u01-1 -> 8.352.u08-1)
[2022-11-02T14:07:12-0600] [ALPM] upgraded jre8-openjdk (8.345.u01-1 -> 8.352.u08-1)
[2022-11-02T14:07:12-0600] [ALPM] upgraded jdk8-openjdk (8.345.u01-1 -> 8.352.u08-1)
[2022-11-02T14:07:13-0600] [ALPM] upgraded jre-openjdk-headless (18.0.2.1.u0-1 -> 19.0.1.u10-3)
[2022-11-02T14:07:13-0600] [ALPM] upgraded jre-openjdk (18.0.2.1.u0-1 -> 19.0.1.u10-3)
[2022-11-02T14:07:13-0600] [ALPM] upgraded kaccounts-providers (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:13-0600] [ALPM] upgraded kactivities-stats (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:13-0600] [ALPM] upgraded kactivitymanagerd (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:13-0600] [ALPM] upgraded kamera (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:13-0600] [ALPM] upgraded ktexteditor (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kate (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kcalc (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kdesu (5.98.0-3 -> 5.99.0-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kde-cli-tools (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kde-gtk-config (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kdegraphics-mobipocket (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kdegraphics-thumbnailers (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kunitconversion (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kemoticons (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:15-0600] [ALPM] upgraded kdelibs4support (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded samba (4.17.0-1 -> 4.17.2-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded kdenetwork-filesharing (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded knotifyconfig (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded libksysguard (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded ksystemstats (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded libqalculate (4.3.0-1 -> 4.4.0-2)
[2022-11-02T14:07:16-0600] [ALPM] upgraded xorg-xsetroot (1.1.2-3 -> 1.1.3-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded kholidays (1:5.98.0-1 -> 1:5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded plasma-framework (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded threadweaver (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded krunner (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded milou (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded prison (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:16-0600] [ALPM] upgraded layer-shell-qt (5.25.5-2 -> 5.26.2-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded kscreenlocker (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded xcb-util-cursor (0.1.3-4 -> 0.1.4-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded lib32-alsa-lib (1.2.7.2-1 -> 1.2.8-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded kwin (5.25.5-2 -> 5.26.2.1-2)
[2022-11-02T14:07:17-0600] [ALPM] upgraded plasma-integration (5.25.5-2 -> 5.26.2-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded kpeople (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded libkscreen (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:17-0600] [ALPM] installed kpipewire (5.26.2-1)
[2022-11-02T14:07:17-0600] [ALPM] upgraded oxygen-sounds (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:18-0600] [ALPM] upgraded plasma-workspace (5.25.5-4 -> 5.26.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded kdeplasma-addons (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded kdoctools (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded keditbookmarks (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded kfind (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded systemsettings (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded kgamma5 (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded kjs (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded khtml (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded khelpcenter (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded khotkeys (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:19-0600] [ALPM] upgraded kimageformats (5.98.0-2 -> 5.99.0-2)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kinfocenter (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kmenuedit (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded konsole (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kpmcore (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded poppler-glib (22.09.0-1 -> 22.10.0-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded ksanecore (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kscreen (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded ksshaskpass (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded ksystemlog (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kwallet-pam (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kwalletmanager (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kwayland-integration (5.25.5-2 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded kwrited (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-zlib (1.2.12-1 -> 1.2.13-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-curl (7.85.0-1 -> 7.86.0-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-systemd (251.5-1 -> 251.7-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-dbus (1.14.2-1 -> 1.14.4-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-expat (2.4.9-1 -> 2.5.0-2)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-flac (1.4.1-1 -> 1.4.2-1)
[2022-11-02T14:07:20-0600] [ALPM] upgraded lib32-libffi (3.4.2-4 -> 3.4.4-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-icu (71.1-1 -> 72.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-libxml2 (2.10.2-2 -> 2.10.3-2)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-mesa (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-freeglut (3.2.2-2 -> 3.4.0-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-glib2 (2.74.0-2 -> 2.74.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-harfbuzz (5.2.0-1 -> 5.3.1-3)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-libva-mesa-driver (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-mesa-vdpau (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-readline (8.1.002-1 -> 8.2.0-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-vulkan-intel (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded lib32-vulkan-radeon (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:21-0600] [ALPM] upgraded libcdr (0.1.7-4 -> 0.1.7-5)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libe-book (0.1.3-11 -> 0.1.3-12)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libebml (1.4.3-1 -> 1.4.4-1)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libksane (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libktorrent (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libmatroska (1.7.0-1 -> 1.7.1-1)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libmspub (0.1.4-12 -> 0.1.4-13)
[2022-11-02T14:07:22-0600] [ALPM] upgraded libnm (1.40.0-1 -> 1.40.2-1)
[2022-11-02T14:07:23-0600] [ALPM] upgraded pacman (6.0.2-1 -> 6.0.2-2)
[2022-11-02T14:07:23-0600] [ALPM] upgraded libpamac (11.3.1-1 -> 11.3.1-3)
[2022-11-02T14:07:23-0600] [ALPM] upgraded ostree (2022.5-4 -> 2022.6-1)
[2022-11-02T14:07:23-0600] [ALPM] upgraded xdg-desktop-portal-kde (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:23-0600] [ALPM] upgraded libpamac-flatpak-plugin (11.3.1-1 -> 11.3.1-3)
[2022-11-02T14:07:25-0600] [ALPM] upgraded libqxp (0.0.2-8 -> 0.0.2-9)
[2022-11-02T14:07:25-0600] [ALPM] upgraded libvisio (0.1.7-7 -> 0.1.7-8)
[2022-11-02T14:07:25-0600] [ALPM] upgraded libzmf (0.0.2-12 -> 0.0.2-13)
[2022-11-02T14:07:25-0600] [ALPM] upgraded xmlsec (1.2.34-2 -> 1.2.36-1)
[2022-11-02T14:07:29-0600] [ALPM] upgraded libreoffice-fresh (7.4.1-3 -> 7.4.2-2)
[2022-11-02T14:07:30-0600] [ALPM] upgraded libreoffice-fresh-es (7.4.1-1 -> 7.4.2-1)
[2022-11-02T14:07:30-0600] [ALPM] upgraded libva-mesa-driver (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:30-0600] [ALPM] upgraded mkinitcpio (31-2.0 -> 32-2)
[2022-11-02T14:07:36-0600] [ALPM] upgraded linux515 (5.15.72-1 -> 5.15.76-1)
[2022-11-02T14:07:36-0600] [ALPM] upgraded lirc (1:0.10.1-12 -> 1:0.10.2-1)
[2022-11-02T14:07:36-0600] [ALPM] upgraded lsof (4.96.3-1 -> 4.96.4-1)
[2022-11-02T14:07:36-0600] [ALPM] upgraded man-db (2.10.2-1 -> 2.11.0-1)
[2022-11-02T14:07:37-0600] [ALPM] upgraded man-pages (5.13-1 -> 6.01-1)
[2022-11-02T14:07:37-0600] [ALPM] upgraded openpmix (4.2.1-1 -> 4.2.2-1)
[2022-11-02T14:07:37-0600] [ALPM] upgraded openmpi (4.1.4-2 -> 4.1.4-4)
[2022-11-02T14:07:37-0600] [ALPM] upgraded manjaro-pulse (20221002-1 -> 20221015-2)
[2022-11-02T14:07:37-0600] [ALPM] upgraded perl-uri (5.12-1 -> 5.16-1)
[2022-11-02T14:07:37-0600] [ALPM] upgraded perl-http-message (6.37-1 -> 6.41-1)
[2022-11-02T14:07:37-0600] [ALPM] upgraded perl-html-parser (3.78-2 -> 3.79-1)
[2022-11-02T14:07:37-0600] [ALPM] upgraded manjaro-settings-manager (0.5.7-10 -> 0.5.7-11)
[2022-11-02T14:07:37-0600] [ALPM] upgraded manjaro-settings-manager-kcm (0.5.7-10 -> 0.5.7-11)
[2022-11-02T14:07:37-0600] [ALPM] upgraded manjaro-settings-manager-knotifier (0.5.7-10 -> 0.5.7-11)
[2022-11-02T14:07:38-0600] [ALPM] upgraded memtest86+ (5.31b-1 -> 6.00-1)
[2022-11-02T14:07:38-0600] [ALPM] upgraded mesa-vdpau (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:38-0600] [ALPM] upgraded mhwd-nvidia (515.76-1 -> 520.56.06-2)
[2022-11-02T14:07:38-0600] [ALPM] upgraded modemmanager (1.18.12-1 -> 1.20.0-1)
[2022-11-02T14:07:38-0600] [ALPM] upgraded modemmanager-qt (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:38-0600] [ALPM] upgraded mpd (0.23.9-3 -> 0.23.10-2)
[2022-11-02T14:07:38-0600] [ALPM] upgraded networkmanager (1.40.0-1 -> 1.40.2-1)
[2022-11-02T14:07:38-0600] [ALPM] upgraded networkmanager-qt (5.98.0-1 -> 5.99.0-1)
[2022-11-02T14:07:39-0600] [ALPM] upgraded okular (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:39-0600] [ALPM] upgraded openssh (9.0p1-1 -> 9.1p1-1)
[2022-11-02T14:07:39-0600] [ALPM] upgraded oxygen (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:41-0600] [ALPM] upgraded oxygen-icons (1:5.98.0-1 -> 1:5.99.0-1)
[2022-11-02T14:07:42-0600] [ALPM] upgraded partitionmanager (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:42-0600] [ALPM] upgraded perl-alien-build (2.71-1 -> 2.72-1)
[2022-11-02T14:07:42-0600] [ALPM] upgraded polkit-kde-agent (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:43-0600] [ALPM] upgraded plasma-desktop (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:43-0600] [ALPM] upgraded plasma-nm (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:43-0600] [ALPM] upgraded plasma-pa (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:43-0600] [ALPM] upgraded plasma-systemmonitor (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:43-0600] [ALPM] upgraded xorg-xwayland (22.1.3-1 -> 22.1.4-3)
[2022-11-02T14:07:43-0600] [ALPM] upgraded plasma-wayland-session (5.25.5-4 -> 5.26.2-1)
[2022-11-02T14:07:44-0600] [ALPM] upgraded plasma-workspace-wallpapers (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:44-0600] [ALPM] upgraded postgresql-libs (14.5-1 -> 14.5-2)
[2022-11-02T14:07:44-0600] [ALPM] upgraded powerdevil (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:44-0600] [ALPM] upgraded print-manager (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:46-0600] [ALPM] upgraded qt6-base (6.4.0-1 -> 6.4.0-2)
[2022-11-02T14:07:46-0600] [ALPM] upgraded qt6-declarative (6.4.0-1 -> 6.4.0-2)
[2022-11-02T14:07:46-0600] [ALPM] upgraded shiboken6 (6.3.2-1 -> 6.4.0.1-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded pyside6 (6.3.2-1 -> 6.4.0.1-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-colorama (0.4.5-1 -> 0.4.6-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-zipp (3.8.1-1 -> 3.10.0-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-importlib-metadata (4.9.0-1 -> 5.0.0-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-typing_extensions (4.3.0-1 -> 4.4.0-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-inflect (6.0.0-1 -> 6.0.2-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-more-itertools (8.13.0-2 -> 9.0.0-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-jaraco.text (3.9.1-1 -> 3.10.0-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-markdown (3.4.1-1 -> 3.4.1-2)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-pillow (9.2.0-1 -> 9.3.0-1)
[2022-11-02T14:07:47-0600] [ALPM] installed python-attrs (22.1.0-1)
[2022-11-02T14:07:47-0600] [ALPM] installed python-wheel (0.37.1-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-pip (22.2.2-2 -> 22.3-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-psutil (5.9.2-1 -> 5.9.3-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-rich (12.6.0-1 -> 12.6.0-2)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-trove-classifiers (2022.9.26-1 -> 2022.10.19-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded python-setuptools (1:63.2.0-1 -> 1:63.4.3-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded qt5-imageformats (5.15.6+kde+r4-1 -> 5.15.6+kde+r5-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded qt5-script (5.15.10-3 -> 5.15.11-1)
[2022-11-02T14:07:47-0600] [ALPM] upgraded qt5-webkit (5.212.0alpha4-16 -> 5.212.0alpha4-17)
[2022-11-02T14:07:47-0600] [ALPM] upgraded rsync (3.2.6-2 -> 3.2.7-1)
[2022-11-02T14:07:48-0600] [ALPM] upgraded rubygems (3.3.21-2 -> 3.3.23-1)
[2022-11-02T14:07:48-0600] [ALPM] upgraded ruby-power_assert (2.0.1-1 -> 2.0.2-1)
[2022-11-02T14:07:48-0600] [ALPM] upgraded ruby-test-unit (3.5.4-1 -> 3.5.5-1)
[2022-11-02T14:07:48-0600] [ALPM] upgraded ruby-cgi (0.3.2-9 -> 0.3.3-1)
[2022-11-02T14:07:48-0600] [ALPM] upgraded ruby-irb (1.4.1-2 -> 1.4.2-1)
[2022-11-02T14:07:48-0600] [ALPM] upgraded ruby-psych (4.0.4-4 -> 4.0.6-1)
[2022-11-02T14:07:49-0600] [ALPM] upgraded ruby-bundler (2.3.22-2 -> 2.3.23-1)
[2022-11-02T14:07:49-0600] [ALPM] upgraded sddm (0.19.0-8 -> 0.19.0-9)
[2022-11-02T14:07:49-0600] [ALPM] upgraded sddm-kcm (5.25.5-1 -> 5.26.2-1)
[2022-11-02T14:07:49-0600] [ALPM] upgraded skanlite (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:49-0600] [ALPM] upgraded spectacle (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:49-0600] [ALPM] upgraded sudo (1.9.11.p3-1 -> 1.9.12-1)
[2022-11-02T14:07:49-0600] [ALPM] upgraded systemd-sysvcompat (251.5-1 -> 251.7-1)
[2022-11-02T14:07:50-0600] [ALPM] upgraded thunderbird (102.3.2-1 -> 102.4.1-1)
[2022-11-02T14:07:50-0600] [ALPM] upgraded vte-common (0.68.0-2 -> 0.70.1-1)
[2022-11-02T14:07:50-0600] [ALPM] upgraded vte3 (0.68.0-2 -> 0.70.1-1)
[2022-11-02T14:07:50-0600] [ALPM] upgraded timeshift (22.06.5-2 -> 22.06.5-3)
[2022-11-02T14:07:51-0600] [ALPM] upgraded unarchiver (1.10.7-6 -> 1.10.7-7)
[2022-11-02T14:07:51-0600] [ALPM] upgraded vi (1:070224-5 -> 1:070224-6)
[2022-11-02T14:07:51-0600] [ALPM] upgraded wayland-protocols (1.26-1 -> 1.27-1)
[2022-11-02T14:07:51-0600] [ALPM] upgraded vlc (3.0.17.4-9 -> 3.0.17.4-10)
[2022-11-02T14:07:52-0600] [ALPM] upgraded vulkan-intel (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:52-0600] [ALPM] upgraded vulkan-radeon (22.1.7-1 -> 22.2.1-1)
[2022-11-02T14:07:53-0600] [ALPM] upgraded webkit2gtk (2.38.0-2 -> 2.38.1-1)
[2022-11-02T14:07:54-0600] [ALPM] upgraded webkit2gtk-4.1 (2.38.0-2 -> 2.38.1-1)
[2022-11-02T14:07:54-0600] [ALPM] upgraded yakuake (22.08.1-1 -> 22.08.2-1)
[2022-11-02T14:07:54-0600] [ALPM] upgraded zensu (0.3-6 -> 0.3-7)
[2022-11-02T14:07:55-0600] [ALPM] transaction completed
[2022-11-02T14:08:01-0600] [ALPM] running '20-systemd-sysusers.hook'...
[2022-11-02T14:08:01-0600] [ALPM] running '30-systemd-catalog.hook'...
[2022-11-02T14:08:01-0600] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-11-02T14:08:02-0600] [ALPM] running '30-systemd-hwdb.hook'...
[2022-11-02T14:08:02-0600] [ALPM] running '30-systemd-sysctl.hook'...
[2022-11-02T14:08:02-0600] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-11-02T14:08:02-0600] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-11-02T14:08:02-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-02T14:08:02-0600] [ALPM] running '30-update-mime-database.hook'...
[2022-11-02T14:08:03-0600] [ALPM] running '40-fontconfig-config.hook'...
[2022-11-02T14:08:03-0600] [ALPM] running '40-update-ca-trust.hook'...
[2022-11-02T14:08:04-0600] [ALPM] running '60-depmod.hook'...
[2022-11-02T14:08:18-0600] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-11-02T14:08:18-0600] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2022-11-02T14:08:18-0600] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2022-11-02T14:08:18-0600] [ALPM-SCRIPTLET] ==> Starting build: 5.15.76-1-MANJARO
[2022-11-02T14:08:18-0600] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-11-02T14:08:18-0600] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-11-02T14:08:19-0600] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2022-11-02T14:08:19-0600] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-11-02T14:08:19-0600] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-11-02T14:08:19-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-11-02T14:08:20-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2022-11-02T14:08:20-0600] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-11-02T14:08:20-0600] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-11-02T14:08:20-0600] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-11-02T14:08:20-0600] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
[2022-11-02T14:08:22-0600] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-11-02T14:08:22-0600] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2022-11-02T14:08:22-0600] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2022-11-02T14:08:22-0600] [ALPM-SCRIPTLET] ==> Starting build: 5.15.76-1-MANJARO
[2022-11-02T14:08:22-0600] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2022-11-02T14:08:22-0600] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2022-11-02T14:08:23-0600] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2022-11-02T14:08:23-0600] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2022-11-02T14:08:24-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-11-02T14:08:24-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-11-02T14:08:25-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-11-02T14:08:25-0600] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-11-02T14:08:27-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2022-11-02T14:08:28-0600] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2022-11-02T14:08:28-0600] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2022-11-02T14:08:30-0600] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2022-11-02T14:08:33-0600] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-11-02T14:08:34-0600] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-11-02T14:08:43-0600] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-11-02T14:08:43-0600] [ALPM] running '90-update-appstream-cache.hook'...
[2022-11-02T14:08:44-0600] [ALPM-SCRIPTLET] ✔ La caché de metadatos se ha actualizado con éxito.
[2022-11-02T14:08:44-0600] [ALPM] running '99-grub.hook'...
[2022-11-02T14:08:45-0600] [ALPM-SCRIPTLET] Generando un fichero de configuración de grub...
[2022-11-02T14:08:45-0600] [ALPM-SCRIPTLET] Encontrado tema: /usr/share/grub/themes/manjaro/theme.txt
[2022-11-02T14:08:45-0600] [ALPM-SCRIPTLET] Encontrada imagen de linux: /boot/vmlinuz-5.15-x86_64
[2022-11-02T14:08:45-0600] [ALPM-SCRIPTLET] Encontrada imagen de memoria inicial: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] Aviso: os-prober will be executed to detect other bootable partitions.
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] /usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido.
[2022-11-02T14:08:46-0600] [ALPM-SCRIPTLET] hecho
[2022-11-02T14:08:46-0600] [ALPM] running 'dbus-reload.hook'...
[2022-11-02T14:08:46-0600] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-11-02T14:08:46-0600] [ALPM] running 'firefox-post.hook'...
[2022-11-02T14:08:46-0600] [ALPM] running 'fontconfig.hook'...
[2022-11-02T14:08:46-0600] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2022-11-02T14:08:46-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-11-02T14:08:47-0600] [ALPM] running 'kernel-alive-post.hook'...
[2022-11-02T14:08:48-0600] [ALPM-SCRIPTLET]
[2022-11-02T14:08:48-0600] [ALPM-SCRIPTLET] ==> Warning:
[2022-11-02T14:08:48-0600] [ALPM-SCRIPTLET]      -> Kernel has been updated. Modules of the current kernel
[2022-11-02T14:08:48-0600] [ALPM-SCRIPTLET]      -> have been backed up so you can continue to use your
[2022-11-02T14:08:48-0600] [ALPM-SCRIPTLET]      -> computer. However, the new kernel will only work
[2022-11-02T14:08:48-0600] [ALPM-SCRIPTLET]      -> at next boot.
[2022-11-02T14:08:48-0600] [ALPM] running 'networkmanager-connectivity.hook'...
[2022-11-02T14:08:48-0600] [ALPM] running 'texinfo-install.hook'...
[2022-11-02T14:08:48-0600] [ALPM] running 'thunderbird-post.hook'...
[2022-11-02T14:08:48-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-11-02T14:08:48-0600] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2022-11-02T14:09:57-0600] [ALPM] transaction started
[2022-11-02T14:09:57-0600] [ALPM] upgraded zotero-bin (6.0.15-1 -> 6.0.16-1)
[2022-11-02T14:09:57-0600] [ALPM] upgraded anydesk-bin (6.2.0-2 -> 6.2.1-2)
[2022-11-02T14:09:57-0600] [ALPM] transaction completed
[2022-11-02T14:09:57-0600] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-11-02T14:09:57-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-02T14:09:57-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-11-02T14:09:57-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-11-02T14:22:59-0600] [PAMAC] synchronizing package lists
[2022-11-02T14:23:13-0600] [ALPM] transaction started
[2022-11-02T14:23:14-0600] [ALPM] upgraded glibc (2.36-5 -> 2.36-6)
[2022-11-02T14:23:14-0600] [ALPM-SCRIPTLET] Generating locales...
[2022-11-02T14:23:17-0600] [ALPM-SCRIPTLET]   es_HN.UTF-8... done
[2022-11-02T14:23:17-0600] [ALPM-SCRIPTLET] Generation complete.
[2022-11-02T14:23:17-0600] [ALPM] transaction completed
[2022-11-02T14:23:17-0600] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-11-02T14:23:17-0600] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-11-02T14:23:17-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-02T14:23:17-0600] [ALPM] running '60-glibc-locales.hook'...
[2022-11-02T14:23:19-0600] [ALPM] running '80-cronie.hook'...
[2022-11-02T14:23:19-0600] [ALPM] running 'locale-gen.hook'...
[2022-11-02T14:23:19-0600] [ALPM] running 'texinfo-install.hook'...
[2022-11-05T09:53:30-0600] [PAMAC] synchronizing package lists
[2022-11-05T09:56:41-0600] [ALPM] running 'firefox-pre.hook'...
[2022-11-05T09:56:41-0600] [ALPM] transaction started
[2022-11-05T09:56:42-0600] [ALPM] upgraded firefox (106.0.2-1 -> 106.0.4-1)
[2022-11-05T09:56:42-0600] [ALPM] upgraded firefox-i18n-en-us (106.0.2-1 -> 106.0.4-1)
[2022-11-05T09:56:42-0600] [ALPM] transaction completed
[2022-11-05T09:56:42-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-05T09:56:42-0600] [ALPM] running 'firefox-post.hook'...
[2022-11-05T09:56:42-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-11-05T09:56:42-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-11-10T16:54:55-0600] [PAMAC] synchronizing package lists
[2022-11-10T16:58:00-0600] [ALPM] transaction started
[2022-11-10T16:58:00-0600] [ALPM] upgraded zotero-bin (6.0.16-1 -> 6.0.18-1)
[2022-11-10T16:58:01-0600] [ALPM] upgraded zoom (5.12.2-1 -> 5.12.6-1)
[2022-11-10T16:58:01-0600] [ALPM] transaction completed
[2022-11-10T16:58:01-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-10T16:58:01-0600] [ALPM] running '30-update-mime-database.hook'...
[2022-11-10T16:58:02-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-11-10T16:58:02-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-11-13T09:15:41-0600] [ALPM] transaction started
[2022-11-13T09:15:41-0600] [ALPM] installed libuv (1.44.2-1)
[2022-11-13T09:15:42-0600] [ALPM] installed c-ares (1.18.1-1)
[2022-11-13T09:15:42-0600] [ALPM] installed nodejs (19.0.0-2)
[2022-11-13T09:15:42-0600] [ALPM] installed nodejs-nopt (6.0.0-1)
[2022-11-13T09:15:42-0600] [ALPM] installed semver (7.3.8-1)
[2022-11-13T09:15:42-0600] [ALPM] installed node-gyp (9.3.0-1)
[2022-11-13T09:15:42-0600] [ALPM] installed yarn (1.22.19-1)
[2022-11-13T09:15:42-0600] [ALPM] transaction completed
[2022-11-13T09:15:42-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-13T09:30:51-0600] [ALPM] transaction started
[2022-11-13T09:30:51-0600] [ALPM] installed heroic-games-launcher (2.4.3-1)
[2022-11-13T09:30:51-0600] [ALPM] transaction completed
[2022-11-13T09:30:51-0600] [ALPM] running '30-systemd-update.hook'...
[2022-11-13T09:30:51-0600] [ALPM] running 'update-desktop-database.hook'...
[2022-11-15T17:09:47-0600] [PAMAC] synchronizing package lists
[2022-11-15T17:10:08-0600] [PAMAC] synchronizing package lists
[2022-11-15T17:10:24-0600] [PAMAC] synchronizing package lists
[2022-11-15T17:11:33-0600] [PAMAC] synchronizing package lists
[2022-11-15T17:33:12-0600] [PAMAC] synchronizing package lists
[2022-11-15T17:35:31-0600] [PAMAC] synchronizing package lists
[2022-11-15T17:40:46-0600] [PACMAN] Running 'pacman -Sy'
[2022-11-15T17:40:46-0600] [PACMAN] synchronizing package lists
[2022-11-15T17:41:25-0600] [PACMAN] Running 'pacman -Su'
[2022-11-15T17:41:34-0600] [PACMAN] starting full system upgrade
[2022-11-15T18:09:57-0600] [PAMAC] synchronizing package lists
[2022-11-15T18:11:03-0600] [PAMAC] synchronizing package lists
[2022-11-15T18:11:15-0600] [PAMAC] synchronizing package lists
[2022-11-15T18:11:31-0600] [PAMAC] synchronizing package lists
[2022-11-15T18:14:55-0600] [PAMAC] synchronizing package lists
[2022-11-16T15:57:49-0600] [PAMAC] synchronizing package lists
[2022-11-16T15:58:04-0600] [PAMAC] synchronizing package lists
[2022-11-17T15:12:58-0600] [PAMAC] synchronizing package lists
[2022-11-17T15:13:38-0600] [PAMAC] synchronizing package lists
[2022-11-17T15:15:04-0600] [PAMAC] synchronizing package lists
[2022-11-17T15:16:52-0600] [PAMAC] synchronizing package lists
[2022-11-17T15:18:17-0600] [PACMAN] Running 'pacman -Su'
[2022-11-17T15:18:22-0600] [PACMAN] starting full system upgrade
[2022-11-17T15:27:10-0600] [PACMAN] Running 'pacman -S archilinux-keyring manjaro-keyring'
[2022-11-17T15:27:35-0600] [PACMAN] Running 'pacman -Syu'
[2022-11-17T15:27:35-0600] [PACMAN] synchronizing package lists
[2022-11-17T15:27:42-0600] [PACMAN] starting full system upgrade
[2022-11-17T15:31:39-0600] [PAMAC] synchronizing package lists
[2022-11-17T15:43:42-0600] [PAMAC] synchronizing package lists
Pues por lo que se ve no aparece ningún error. Se puede intentar actualizar cambiando antes de repositorio por uno que esté totalmente actualizado (se pueden ver en repo.manjaro.org). Los de Austria lo están así que ponemos estos dos comandos:
sudo pacman-mirrors -c Austria
sudo pacman -Syyu
Estoy viendo el pacman.log que enviabas y aparece esto:
[2022-11-17T15:27:10-0600] [PACMAN] Running ‘pacman -S archilinux-keyring manjaro-keyring’
[2022-11-17T15:27:35-0600] [PACMAN] Running ‘pacman -Syu’
Me parece raro, el paquete con las firmas no es archilinux-keyring sino archlinux-keyring, a ver si va a ser ese el problema. Puedes probar a instalarlos manualmente:
sudo pacman -S archlinux-keyring manjaro-keyring
sudo pacman -Syu
Y si aún así no va, entonces debe haber alguna clave GPG inválida. ¿Da algún error alguno de los comandos anteriores? La forma de listar las claves GPG es esta:
sudo pacman-key --list-sigs
Habiendo cambiando el repositorio me sale el mismo problema.
He intentando actualizar el paquete de firmas con el comando que mencionas y tambien he tenido problemas. Este es el resultado de los comandos:
error: archlinux-keyring: se desconoce el nivel de confianza de la firma de «Christian Hesse <eworm@archlinux.org>»
:: El archivo /var/cache/pacman/pkg/archlinux-keyring-20221110-1-any.pkg.tar.zst está dañado (paquete no válido o dañado (firma PGP)).
¿Quiere eliminarlo? [S/n] n
error: manjaro-keyring: se desconoce el nivel de confianza de la firma de «Philip Müller (Called Little) <philm@manjaro.org>»
:: El archivo /var/cache/pacman/pkg/manjaro-keyring-20221028-4-any.pkg.tar.xz está dañado (paquete no válido o dañado (firma PGP)).
error: no se pudo realizar la operación (paquete no válido o dañado (firma PGP))
Ocurrieron errores, por lo que no se actualizarán los paquetes
    ~  sudo pacman-key --list-sigs         1 ✘  14s 
/etc/pacman.d/gnupg/pubring.kbx
pub   rsa4096 2022-11-17 [SC]
      4CDC33E7EF2F00315280874A26EAE2BB791DD812
uid        [  absoluta ] Pacman Keyring Master Key <pacman@localhost>
sig 3        26EAE2BB791DD812 2022-11-17  Pacman Keyring Master Key <pacman@localhost>
pub   rsa2048 2011-08-12 [SC]
      02FD1C7A934E614545849F19A6234074498E9CEE
sig    R     A6234074498E9CEE 2013-02-04  Christian Hesse <eworm@archlinux.org>
sig    R     A6234074498E9CEE 2013-01-14  Christian Hesse <eworm@archlinux.org>
uid        [desconocida] Christian Hesse <eworm@archlinux.org>
sig 3        A6234074498E9CEE 2020-02-04  Christian Hesse <eworm@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-10  [ID de usuario no encontrado]
sig          A88E23E377514E00 2022-02-06  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2022-01-22  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2022-01-12  [ID de usuario no encontrado]
sig          4DC95B6D7BE9892E 2021-10-28  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2020-08-18  [ID de usuario no encontrado]
sub   rsa2048 2011-08-12 [E]
sig      N   A6234074498E9CEE 2022-07-09  Christian Hesse <eworm@archlinux.org>
sub   ed25519 2019-08-29 [S]
sig          A6234074498E9CEE 2019-08-29  Christian Hesse <eworm@archlinux.org>
sub   cv25519 2019-08-29 [E]
pub   rsa2048 2011-10-08 [SC]
      E499C79F53C96A54E572FEE1C06086337C50773E
uid        [desconocida] Jelle van der Waa <jelle@archlinux.org>
sig 3    N   C06086337C50773E 2022-07-31  Jelle van der Waa <jelle@archlinux.org>
sig          4DC95B6D7BE9892E 2021-10-22  [ID de usuario no encontrado]
sig 3        786C63F330D7CB92 2019-10-06  Felix Yan <felixonmars@archlinux.org>
sig          7258734B41C31549 2019-10-05  David Runge <dvzrv@archlinux.org>
sig          FE763A64F5E54FD6 2019-06-09  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2018-12-17  [ID de usuario no encontrado]
sig          9B729B06A680C281 2018-11-13  [ID de usuario no encontrado]
sig          A88E23E377514E00 2015-12-23  [ID de usuario no encontrado]
sub   rsa2048 2011-10-08 [E]
sig      N   C06086337C50773E 2022-07-31  Jelle van der Waa <jelle@archlinux.org>
pub   rsa4096 2012-01-20 [SC]
      B5971F2C5C10A9A08C60030F786C63F330D7CB92
uid        [desconocida] Felix Yan <felixonmars@archlinux.org>
sig 3    N   786C63F330D7CB92 2022-07-09  Felix Yan <felixonmars@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-17  [ID de usuario no encontrado]
sig          4DC95B6D7BE9892E 2021-10-11  [ID de usuario no encontrado]
sig          9C02FF419FECBE16 2019-11-16  Morten Linderud <foxboron@archlinux.org>
sig          C91A9911192C187A 2019-11-14  [ID de usuario no encontrado]
sig          7F2D434B9741E8AC 2019-10-15  Pierre Schmitz <pierre@archlinux.de>
sig 3        8DBD63B82072D77A 2019-10-13  Sébastien Luttringer <seblu@seblu.net>
sig          89AA27231C530226 2019-10-10  [ID de usuario no encontrado]
sig          12C87A28FEAC6B20 2019-10-07  [ID de usuario no encontrado]
sig          6E80CA1446879D04 2019-10-07  [ID de usuario no encontrado]
sig          39E4B877E62EB915 2019-10-06  Sven-Hendrik Haase <sh@lutzhaase.com>
sig          06096A6AD1CEDDAC 2019-10-06  Laurent Carlier <lordheavym@archlinux.org>
sig          46F633CBB0EB4BF2 2019-10-06  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2018-12-09  [ID de usuario no encontrado]
sig          9B729B06A680C281 2017-05-25  [ID de usuario no encontrado]
sig          7EFD567D4C7EA887 2015-02-07  [ID de usuario no encontrado]
sig          5184252D824B18E8 2014-09-09  [ID de usuario no encontrado]
sig          A04F9397CDFD6BB0 2014-09-01  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2014-09-01  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2014-08-31  [ID de usuario no encontrado]
sub   rsa4096 2012-01-20 [E]
sig      N   786C63F330D7CB92 2022-07-09  Felix Yan <felixonmars@archlinux.org>
pub   ed25519 2020-05-11 [SC]
      A2FF3A36AAA56654109064AB19802F8B0D70FC30
uid        [desconocida] Jan Alexander Steffens (heftig) <heftig@archlinux.org>
sig 3        19802F8B0D70FC30 2020-05-11  Jan Alexander Steffens (heftig) <heftig@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-16  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2020-06-20  [ID de usuario no encontrado]
sig          9B729B06A680C281 2020-05-29  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2020-05-22  [ID de usuario no encontrado]
sig          A88E23E377514E00 2020-05-21  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2020-05-17  [ID de usuario no encontrado]
sig 3        A5E9288C4FA415FA 2020-05-13  [ID de usuario no encontrado]
sub   ed25519 2020-05-11 [A]
sig          19802F8B0D70FC30 2020-05-11  Jan Alexander Steffens (heftig) <heftig@archlinux.org>
sub   ed25519 2020-05-11 [S]
sub   cv25519 2020-05-11 [E]
pub   rsa2048 2011-05-14 [SC]
      ADC8A1FCC15E01D45310419E94657AB20F2A092B
uid        [desconocida] Andreas Radke <andyrtr@archlinux.org>
sig 3    N   94657AB20F2A092B 2022-07-10  Andreas Radke <andyrtr@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-12  [ID de usuario no encontrado]
sig          9B729B06A680C281 2017-07-13  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2011-12-17  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2011-11-20  [ID de usuario no encontrado]
sub   rsa2048 2011-05-14 [E]
sig      N   94657AB20F2A092B 2022-07-10  Andreas Radke <andyrtr@archlinux.org>
pub   rsa4096 2014-10-21 [SC]
      9D74DF6F91B7BDABD5815CA84AC5588F941C2A25
uid        [desconocida] Antonio Rojas <arojas@archlinux.org>
sig 3    N   4AC5588F941C2A25 2022-07-09  Antonio Rojas <arojas@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-13  [ID de usuario no encontrado]
sig          4DC95B6D7BE9892E 2021-10-24  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2014-12-18  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2014-11-18  [ID de usuario no encontrado]
sub   rsa2048 2014-11-07 [S]
sig      N   4AC5588F941C2A25 2022-07-09  Antonio Rojas <arojas@archlinux.org>
sub   rsa2048 2014-11-07 [E]
pub   rsa2048 2011-04-10 [SC]
      4AA4767BBC9C4B1D18AE28B77F2D434B9741E8AC
uid        [desconocida] Pierre Schmitz <pierre@archlinux.de>
sig          A5E9288C4FA415FA 2012-02-05  [ID de usuario no encontrado]
sig          F2DBB4931985A992 2012-02-05  [ID de usuario no encontrado]
sig 3        7F2D434B9741E8AC 2011-04-10  Pierre Schmitz <pierre@archlinux.de>
sig          3348882F6AC6A4C2 2011-11-18  [ID de usuario no encontrado]
sig          5184252D824B18E8 2011-11-19  [ID de usuario no encontrado]
sig          7EFD567D4C7EA887 2011-11-25  [ID de usuario no encontrado]
sig          A04F9397CDFD6BB0 2011-12-01  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2011-12-05  [ID de usuario no encontrado]
sig          C8880A6406361833 2012-02-05  [ID de usuario no encontrado]
sig          284FC34C8E4B1A25 2011-11-13  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2019-09-29  [ID de usuario no encontrado]
sig 3        7F2D434B9741E8AC 2021-10-31  Pierre Schmitz <pierre@archlinux.de>
sub   rsa2048 2011-04-10 [E]
sig          7F2D434B9741E8AC 2011-04-10  Pierre Schmitz <pierre@archlinux.de>
pub   rsa2048 2010-11-12 [SC]
      86CFFCA918CF3AF47147588051E8B148A9999C34
uid        [desconocida] Evangelos Foutras <foutrelis@archlinux.org>
sig 3    N   51E8B148A9999C34 2022-07-09  Evangelos Foutras <foutrelis@archlinux.org>
sig          4DC95B6D7BE9892E 2021-10-23  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2018-12-10  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2011-12-01  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2011-11-21  [ID de usuario no encontrado]
sub   rsa2048 2010-11-12 [E]
sig      N   51E8B148A9999C34 2022-07-09  Evangelos Foutras <foutrelis@archlinux.org>
pub   rsa2048 2012-05-05 [SC]
      E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E
sig          EAA03C5C938B0F01 2019-06-28  [ID de usuario no encontrado]
sig          EAA03C5C938B0F01 2019-10-06  [ID de usuario no encontrado]
sig          DC1BB1D87343C23D 2019-11-29  [ID de usuario no encontrado]
sig          EAA03C5C938B0F01 2019-12-01  [ID de usuario no encontrado]
uid        [desconocida] Philip Müller (Called Little) <philm@manjaro.org>
sig 3        CAA6A59611C7F07E 2012-05-05  Philip Müller (Called Little) <philm@manjaro.org>
sub   rsa2048 2012-05-05 [E]
sig          CAA6A59611C7F07E 2012-05-05  Philip Müller (Called Little) <philm@manjaro.org>
pub   rsa2048 2011-07-18 [SC]
      5B7E3FB71B7F10329A1C03AB771DF6627EDF681F
uid        [desconocida] Tobias Powalowski <tpowa@archlinux.org>
sig 3    N   771DF6627EDF681F 2022-07-09  Tobias Powalowski <tpowa@archlinux.org>
sig          4DC95B6D7BE9892E 2021-10-25  [ID de usuario no encontrado]
sub   rsa2048 2011-07-18 [E]
sig      N   771DF6627EDF681F 2022-07-09  Tobias Powalowski <tpowa@archlinux.org>
pub   rsa4096 2014-02-04 [SC] [caduca: 2026-10-25]
      8E1992167465DB5FB045557CB02854ED753E0F1F
uid        [desconocida] Anatol Pomozov (Arch Linux developer account) <anatolik@archlinux.org>
sig 3        B02854ED753E0F1F 2021-10-26  Anatol Pomozov (Arch Linux developer account) <anatolik@archlinux.org>
uid        [desconocida] Anatol Pomozov <anatol.pomozov@gmail.com>
sub   rsa4096 2014-02-04 [E] [caduca: 2026-10-25]
sig          B02854ED753E0F1F 2021-10-26  Anatol Pomozov (Arch Linux developer account) <anatolik@archlinux.org>
pub   rsa2048 2020-04-20 [SC]
      688E8F82879D0E25CE541426150C200743ED46D8
uid        [desconocida] Mark Wagie <mark@manjaro.org>
sig 3        150C200743ED46D8 2022-04-20  Mark Wagie <mark@manjaro.org>
sig          CAA6A59611C7F07E 2020-04-20  Philip Müller (Called Little) <philm@manjaro.org>
sub   rsa2048 2020-04-20 [E]
sig          150C200743ED46D8 2022-04-20  Mark Wagie <mark@manjaro.org>
pub   rsa2048 2011-10-30 [SC]
      535F8C0339450F054A4D282706096A6AD1CEDDAC
uid        [desconocida] Laurent Carlier <lordheavym@archlinux.org>
sig 3        06096A6AD1CEDDAC 2021-10-29  Laurent Carlier <lordheavym@archlinux.org>
sig          4DC95B6D7BE9892E 2021-10-29  [ID de usuario no encontrado]
sub   rsa2048 2011-10-30 [E]
sig      N   06096A6AD1CEDDAC 2022-07-09  Laurent Carlier <lordheavym@archlinux.org>
pub   rsa4096 2011-11-11 [SC]
      B81B051F2D7FC867AAFF35A58DBD63B82072D77A
uid        [desconocida] Sébastien Luttringer <seblu@seblu.net>
sig 3        8DBD63B82072D77A 2013-01-05  Sébastien Luttringer <seblu@seblu.net>
sub   rsa4096 2013-03-30 [E]
sig          8DBD63B82072D77A 2013-03-30  Sébastien Luttringer <seblu@seblu.net>
sub   rsa4096 2013-03-30 [S]
sub   rsa4064 2012-12-12 [S]
sig          8DBD63B82072D77A 2012-12-12  Sébastien Luttringer <seblu@seblu.net>
sub   rsa4096 2011-11-11 [E]
sig          8DBD63B82072D77A 2011-11-11  Sébastien Luttringer <seblu@seblu.net>
sub   rsa4032 2014-03-30 [S]
sig          8DBD63B82072D77A 2014-03-30  Sébastien Luttringer <seblu@seblu.net>
sub   rsa4032 2014-03-30 [E]
sub   rsa4032 2017-07-07 [E]
sig          8DBD63B82072D77A 2017-07-07  Sébastien Luttringer <seblu@seblu.net>
sub   rsa4032 2017-07-07 [S]
sub   ed25519 2019-10-10 [S]
sig          8DBD63B82072D77A 2019-10-10  Sébastien Luttringer <seblu@seblu.net>
sub   cv25519 2019-10-10 [E]
pub   rsa4096 2011-09-10 [SC]
      8FC15A064950A99DD1BD14DD39E4B877E62EB915
uid        [desconocida] Sven-Hendrik Haase <sh@lutzhaase.com>
sig 3    N   39E4B877E62EB915 2022-07-09  Sven-Hendrik Haase <sh@lutzhaase.com>
uid        [desconocida] Sven-Hendrik Haase <svenstaro@archlinux.org>
sig 3        39E4B877E62EB915 2021-06-24  Sven-Hendrik Haase <sh@lutzhaase.com>
uid        [desconocida] Sven-Hendrik Haase <svenstaro@gmail.com>
sig 3        39E4B877E62EB915 2016-06-15  Sven-Hendrik Haase <sh@lutzhaase.com>
sub   rsa4096 2022-07-10 [A]
sig          39E4B877E62EB915 2022-07-10  Sven-Hendrik Haase <sh@lutzhaase.com>
sub   rsa4096 2011-09-10 [E]
sig      N   39E4B877E62EB915 2022-07-09  Sven-Hendrik Haase <sh@lutzhaase.com>
pub   ed25519 2022-05-10 [SC] [caduca: 2026-05-09]
      991F6E3F0765CF6295888586139B09DA5BF0D338
uid        [desconocida] David Runge <dvzrv@archlinux.org>
sig 3        139B09DA5BF0D338 2022-05-10  David Runge <dvzrv@archlinux.org>
sig          D6D055F927843F1C 2022-08-02  [ID de usuario no encontrado]
sig          B1B73B02CC52A02A 2022-07-09  [ID de usuario no encontrado]
sig          A88E23E377514E00 2022-06-05  [ID de usuario no encontrado]
sig          4DC95B6D7BE9892E 2022-05-19  [ID de usuario no encontrado]
sig 3        7258734B41C31549 2022-05-10  David Runge <dvzrv@archlinux.org>
sub   ed25519 2022-05-10 [A] [caduca: 2026-05-09]
sig          139B09DA5BF0D338 2022-05-10  David Runge <dvzrv@archlinux.org>
sub   cv25519 2022-05-10 [E] [caduca: 2026-05-09]
pub   ed25519 2019-10-01 [SC] [caduca: 2023-09-30]
      C7E7849466FE2358343588377258734B41C31549
sig 3        7258734B41C31549 2019-10-01  David Runge <dvzrv@archlinux.org>
sig          4DC95B6D7BE9892E 2021-06-05  [ID de usuario no encontrado]
sig          6BC26A17B9B7018A 2019-10-18  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2019-10-17  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2019-10-17  [ID de usuario no encontrado]
sig          8DBD63B82072D77A 2019-10-12  Sébastien Luttringer <seblu@seblu.net>
sig          9B729B06A680C281 2019-10-11  [ID de usuario no encontrado]
sig          BA1DFB64FFF979E7 2019-10-10  [ID de usuario no encontrado]
sig          54C28F4FF5A1A949 2019-10-10  [ID de usuario no encontrado]
sig          A88E23E377514E00 2019-10-06  [ID de usuario no encontrado]
sig          94657AB20F2A092B 2019-10-05  Andreas Radke <andyrtr@archlinux.org>
sig 3        786C63F330D7CB92 2019-10-05  Felix Yan <felixonmars@archlinux.org>
sig          46F633CBB0EB4BF2 2019-10-05  [ID de usuario no encontrado]
sig          06096A6AD1CEDDAC 2019-10-05  Laurent Carlier <lordheavym@archlinux.org>
sub   cv25519 2019-10-01 [E] [caduca: 2023-09-30]
sig          7258734B41C31549 2019-10-01  David Runge <dvzrv@archlinux.org>
pub   rsa4096 2022-01-30 [SC]
      95220BE99CE6FF778AE0DC670F65C7D881506130
uid        [desconocida] Maxime Gauduin <alucryd@archlinux.org>
sig 3        0F65C7D881506130 2022-01-30  Maxime Gauduin <alucryd@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-25  [ID de usuario no encontrado]
sig          D6D055F927843F1C 2022-04-25  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2022-04-24  [ID de usuario no encontrado]
sig          A88E23E377514E00 2022-03-06  [ID de usuario no encontrado]
sig          4DC95B6D7BE9892E 2022-02-24  [ID de usuario no encontrado]
sig          AFF5D95098BC6FF5 2022-01-30  Maxime Gauduin <alucryd@archlinux.org>
sub   rsa4096 2022-01-30 [E]
sig          0F65C7D881506130 2022-01-30  Maxime Gauduin <alucryd@archlinux.org>
sub   rsa4096 2022-01-30 [A]
pub   rsa2048 2013-01-21 [SC]
      9437DD3815A7A9169E3D3946AFF5D95098BC6FF5
sig 3        AFF5D95098BC6FF5 2014-09-24  Maxime Gauduin <alucryd@archlinux.org>
sig          EEEEE2EEEE2EEEEE 2017-10-22  [ID de usuario no encontrado]
sub   rsa2048 2013-01-21 [E]
sig          AFF5D95098BC6FF5 2013-01-21  Maxime Gauduin <alucryd@archlinux.org>
pub   ed25519 2018-10-31 [SCA] [caduca: 2023-12-01]
      05C7775A9E8B977407FE08E69D4C5AA15426DA0A
uid        [desconocida] Frederik Schwan <freswa@archlinux.org>
sig 3        9D4C5AA15426DA0A 2022-11-03  Frederik Schwan <freswa@archlinux.org>
sig          BA1DFB64FFF979E7 2020-08-17  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2020-07-27  [ID de usuario no encontrado]
sig          9B729B06A680C281 2020-06-22  [ID de usuario no encontrado]
sig          A88E23E377514E00 2020-06-12  [ID de usuario no encontrado]
sub   ed25519 2020-04-18 [A] [caduca: 2023-12-01]
sig          9D4C5AA15426DA0A 2022-11-03  Frederik Schwan <freswa@archlinux.org>
sub   cv25519 2018-10-31 [E] [caduca: 2023-12-01]
pub   rsa4096 2014-09-05 [SC]
      C100346676634E80C940FB9E9C02FF419FECBE16
uid        [desconocida] Morten Linderud <foxboron@archlinux.org>
sig 3        9C02FF419FECBE16 2022-07-09  Morten Linderud <foxboron@archlinux.org>
sig          B1B73B02CC52A02A 2022-07-11  [ID de usuario no encontrado]
sig          3348882F6AC6A4C2 2018-10-03  [ID de usuario no encontrado]
sub   rsa4096 2018-11-26 [A]
sig          9C02FF419FECBE16 2018-11-26  Morten Linderud <foxboron@archlinux.org>
sub   rsa4096 2014-09-05 [E]
sig          9C02FF419FECBE16 2022-07-09  Morten Linderud <foxboron@archlinux.org>
sub   rsa4096 2018-11-13 [S]
sig          9C02FF419FECBE16 2018-11-13  Morten Linderud <foxboron@archlinux.org>
pub   rsa4096 2008-08-01 [SCA]
      CFA6AF15E5C74149FC1D8C086D1655C14CE1C13E
uid        [desconocida] Florian Pritz <bluewind@xinu.at>
sig 3    N   6D1655C14CE1C13E 2022-07-17  Florian Pritz <bluewind@xinu.at>
uid        [desconocida] Florian Pritz <flo@xinu.at>
uid        [desconocida] Florian Pritz <bluewind@archlinux.org>
sig 3        6D1655C14CE1C13E 2016-07-25  Florian Pritz <bluewind@xinu.at>
sub   rsa4096 2008-08-01 [E]
sig      N   6D1655C14CE1C13E 2022-07-17  Florian Pritz <bluewind@xinu.at>
pub   rsa3072 2020-10-28 [SC]
      3B794DE6D4320FCE594F4171279E7CF5D8D56EC8
uid        [desconocida] Manjaro Build Server <build@manjaro.org>
sig 3        279E7CF5D8D56EC8 2022-10-28  Manjaro Build Server <build@manjaro.org>
sig          CAA6A59611C7F07E 2020-10-29  Philip Müller (Called Little) <philm@manjaro.org>
sub   rsa3072 2020-10-28 [E]
sig          279E7CF5D8D56EC8 2022-10-28  Manjaro Build Server <build@manjaro.org>
Parece que debe haber algún problema con el archivo de firmas porque hay más personas a los que les pasa:
Y tampoco es la primera vez que sucede:
En este segundo hilo dan una solución que le funcionó a la persona con problemas y un enlace a la wiki de Manjaro donde explican paso por paso cómo intentar solucionarlo.
O bien esperar a ver si Manjaro saca alguna actualización corrigiendo el error, o bien probar alguna de estas soluciones a ver si funcionan. :+1:
Ya he intentado ambas soluciones brindadas, pero no he logrado resolver. Tocara esperar a que Manjaro saque una actualización que lo corrija
También hay otra opción, saltarse el keyring cómo indica el usuario @brahma en este enlace, actualizar y a continuación volver a dejar el pacman.conf como estaba antes…
Con este he logrado actualizar sin problemas. Y ya he devuelto el archivo a su configuración original. Gracias! Espero no tener problemas en proximas actualizaciones.
Aunque esto no me permite desinstalar programas o instalar nuevos ya que sigo con el mismo error de las firmas PGP, mientras tanto esperare a que en una nueva actualizacion se resuelva.
