After updating my XFCE Manjaro whenever I open a terminal I get the following error:
File "/home/mehdi/.local/bin/powerline-shell", line 5, in <module>
from powerline_shell import main
ModuleNotFoundError: No module named 'powerline_shell'
cscs
22 August 2023 23:18
2
Is the problem.
Why is that there and how is it configured?
(its not from a repo package)
I would assume also that .bashrc/.zshrc or some other config file is trying to call this broken powerline executable.
cscs:
Is the problem.
I have no idea about this how it configured
How can I solve this?
cscs
23 August 2023 00:07
4
grep powerline ~/*
We want to see whats calling it. Again, likely bashrc or zshrc.
grep powerline ~/*
grep: /home/mehdi/Desktop: Is a directory
grep: /home/mehdi/Documents: Is a directory
grep: /home/mehdi/Downloads: Is a directory
grep: /home/mehdi/Music: Is a directory
grep: /home/mehdi/pgadmin4: Is a directory
grep: /home/mehdi/Pictures: Is a directory
grep: /home/mehdi/Public: Is a directory
grep: /home/mehdi/PycharmProjects: Is a directory
grep: /home/mehdi/snap: Is a directory
grep: /home/mehdi/Templates: Is a directory
grep: /home/mehdi/Videos: Is a directory
cscs
23 August 2023 08:45
8
I dont know why I was thinking that would work well.
grep -s powerline ~/.*
(POSIX does not expand *
to include dotfiles)
/home/mehdi/.bash_history:cd ./usr/lib/python3.9/site-packages/powerline/bindings/bash/
/home/mehdi/.bash_history:cd /usr/lib/python3.9/site-packages/powerline/bindings/bash/
/home/mehdi/.bash_history:find powerline.sh
/home/mehdi/.bash_history:find -name powerline.sh
/home/mehdi/.bash_history:sudo find -name powerline.sh
/home/mehdi/.bash_history:chmod +x powerline.sh
/home/mehdi/.bash_history:sudo chmod +x powerline.sh
/home/mehdi/.bash_history:sudo pacman -S powerline
/home/mehdi/.bashrc:powerline-daemon -q
/home/mehdi/.bashrc:/usr/lib/python3.9/site-packages/powerline/bindings/bash/powerline.sh
/home/mehdi/.zsh_history:: 1638128434:0;pacman -S powerline
/home/mehdi/.zsh_history:: 1638128438:0;sudo pacman -S powerline
/home/mehdi/.zsh_history:: 1638129612:0;powerline
/home/mehdi/.zsh_history:: 1638129619:0;powerline-config
/home/mehdi/.zsh_history:: 1638136135:0;powerline
/home/mehdi/.zsh_history:: 1638136140:0;powerline /?
/home/mehdi/.zsh_history:: 1638136144:0;powerline -h
/home/mehdi/.zsh_history:: 1638309454:0;powerline
/home/mehdi/.zsh_history:: 1638309896:0;pip3 install powerline-shell\
/home/mehdi/.zsh_history:: 1638309901:0;pip install powerline-shell\
/home/mehdi/.zsh_history:: 1638310256:0;pip3 install powerline-shell\
/home/mehdi/.zsh_history:: 1638310267:0;powerline-shell\
/home/mehdi/.zsh_history:: 1638310280:0;powerline\
/home/mehdi/.zsh_history:: 1638310286:0;powerline-config\
/home/mehdi/.zsh_history:: 1638310301:0;powerline-render\
/home/mehdi/.zsh_history:: 1638310670:0;git clone https://github.com/powerline/fonts.git --depth=1\
/home/mehdi/.zsh_history:: 1641373609:0;pip install powerline-shell\
/home/mehdi/.zsh_history:: 1692745165:0;yay -S --rebuild powerline_shell
/home/mehdi/.zsh_history:: 1692745248:0;yay -S powerline_shell
/home/mehdi/.zsh_history:: 1692749294:0;grep powerline ~/*
/home/mehdi/.zsh_history:: 1692782694:0;grep -s powerline ~/.*\
/home/mehdi/.zshrc:function powerline_precmd() {
/home/mehdi/.zshrc: PS1="$(~/.local/bin/powerline-shell --shell zsh $?)"
/home/mehdi/.zshrc:function install_powerline_precmd() {
/home/mehdi/.zshrc: if [ "$s" = "powerline_precmd" ]; then
/home/mehdi/.zshrc: precmd_functions+=(powerline_precmd)
/home/mehdi/.zshrc: install_powerline_precmd
cscs
23 August 2023 20:07
12
You have it in both .bashrc and .zshrc, but given the output it appears you use zsh.
So … you can comment out the linesin your .zshrc file. Example:
#function powerline_precmd() {
# PS1="$(~/.local/bin/powerline-shell --shell zsh $?)"
But, I will also mention … it would appear you probably want to use modern manjaro configs?
If so you may want to make sure you have manjaro-zsh-config
installed … and then go and find the .zshrc file in /etc/skel/
and copy it to your home.
system
Closed
26 August 2023 10:08
13
