When I open my lantern app, it shows
error while loading shared libraries: libappindicator3.so.1: cannot open shared object file: No such file or director
How can I deal with it?
Welcome to the forum! ![]()
Your what now? ![]()
Do you have libappindicator-gtk3 installed?
Lantern app
yay -S lantern-bin
I install it using the following command
sudo pacman -S libappindicator-gtk3
then I test is
lantern ✔ 5s
Running installation script...
/usr/lib/lantern/lantern-binary: Success
/home/guoyi/.lantern/bin/lantern: error while loading shared libraries: libpcap.so.0.8: cannot open shared object file: No such file or directory
It’s been reported (was that you?) and the AUR package maintainer wasn’t much help. ![]()
It offers offical deb package, I use it to install, same problem. Could I know how to solve with this similar problems? about xx.so.xx No such file or directory.
I use Ubuntu 20.04 LTS well to use this package on Gnome, first, I thought it is the problem of KDE.
The lantern-bin AUR package uses the .deb as the source. What do you mean you used the .deb to install it?
I use the following commands
debtap -q lantern.deb
ls
sudo pacman -S
Solved
cd /usr/bin
sudo ln -s libpcap.so.1 libpcap.so.0.8
lantern
