Error 1603 on wine installing .exe
When I’m trying to install a .exe program the installer shows me 1603 error.
I don’t know how to solve this problem.
Please help me.
you are not installing an exe , you are installing ITE9135 driver windows!
better should be
https://www.linuxtv.org/wiki/index.php/ITE_IT9135
for what purpose do you wanna do this ? your tv should already be supported by linux. why using wine for that ? makes no sense for me.
Don’t use Wine to install drivers. Drivers should NEVER be installed through a compatibility layer.
thanks for all of you.
I found out that I made a misstake.
I can’t find that on mhwd.
Is that installed?
If not how can I install that?
open a konsole and post the output of
ls /lib/firmware/ | grep 91
this should show up that the firmware for 9135 is already present.
This is the output:
ar9170-2.fw
carl9170-1.fw
dvb-usb-it9135-01.fw
dvb-usb-it9135-02.fw
i915
rsi_91x.fw
sdd_sagrad_1091_1098.bin
okay the firmware (“driver”) is already present. all you should check now is your search engine and search for “linux smart tv” and other similar search phrases. there are such a lot of solutions that i cannot answer this.
a very popular app is “kodi”. you can search for it and try if it fullfills your needs.
The module for this tuner is called it913x and should be loaded when the tuner is inserted.
lsmod | grep it913
should list it
How can I use that?
… is your question how to use a search engine?
or
how to use kodi?
It’s unlikely to be the first option
and perusing that will give you answers to the second question …
I replied to a very popular app is “kodi” and it means I want to know how can I use that.
I know.
And using a search engine will answer your questions - if you ask it :wink:
you install it like any other program
how to use it is a different question from how to install it
I didn’t ask for how to install that; I asked for how to use that.
I know - but at least I am not a search engine nor will I read the user manual to you and for you.
Happy trails!
ps:
perhaps you could make very clear what your actual objective is:
What are you trying to achieve in the end?
Not how you think you can get there - but what the actual goal is.
It was never explicitly mentioned - just deduced from what you tried to do in your first post.
Perhaps we are talking past each other the whole time.
there are a lot of tutorials. for example check youtube
