Hi,
First, some context. On can use either mkinitcpio or systemd to fsck the root file system at boot time.
(see fsck - ArchWiki)
When using systemd, fsck.repair can be set to have systemd-fsck performs repairs and/or optimizations.
(see systemd-fsck@.service(8) — Arch manual pages)
With fsck.repair=preen, the performed action is e2fsck -p.
(see e2fsck(8) — Arch manual pages)
With fsck.repair=yes, the performed action is e2fsck -y.
However, fsck.repair is only for systemd.
(see Fsck systemd console fehler - #2 by megavolt)
From the previous link, translated with Google Translate, as the source is not in English:
For security reasons, some repairs are not performed automatically. But to force them (ONLY WITH SYSTEMD), use the following kernel parameters:
fsck.mode=force
fsck.repair=yes
The Arch Wiki is ambiguous on the subject as both mkinitcpio and systemd are mentioned in the parent section (section 1. in the next link) but only a solution mentioning systemd (ie. fsck.repair) is provided (without an equivalent when using mkinitcpio).
Then, my question is the following:
How to do e2fsck -p or e2fsck -y for fsck run at boot time when using mkinitcpio instead of systemd?
Of note, an Arch user seems to have either the same question (fsck.repair is only for systemd, not mkinitcpio) or a related issue (fsck.repair does not perform optimizations with either preen or yes). Either option is possible as the thread is unfinished.
(see fsck.repair doesn't repair all problems / System Administration / Arch Linux Forums)
NB: Links are not clickable because as a new user I cannot have so many links…
Thanks
