Hi,
Have try to install Epson Perfection V39 but is not working.
First have test : pamac install iscan iscan-data iscan-plugin-gt-s650
But fail (Install OK), after that have try to install : pamac install epsonscan2 epsonscan2-non-free-plugin
Fail again (Install OK)…
Last test was pamac install imagescan
Fail too (Install OK).
My issue is not possible to run a scan but i can detect my scanner.
sane-find-scanner
found USB scanner (vendor=0x04b8 [EPSON], product=0x013d) at libusb:001:004
scanimage -L
device `epkowa:interpreter:001:004' is a Epson (unknown model) flatbed scanner
lsusb -v
Bus 001 Device 004: ID 04b8:013d Seiko Epson Corp. Epson Perfection V39
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 255 Vendor Specific Subclass
bDeviceProtocol 255 Vendor Specific Protocol
bMaxPacketSize0 64
idVendor 0x04b8 Seiko Epson Corp.
idProduct 0x013d
bcdDevice 1.00
iManufacturer 1 EPSON
iProduct 2 Epson Perfection V39
iSerial 3 VCGY147721
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0020
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 255
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 003: ID 19f7:0003 RODE Microphones RODE NT-USB
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 16
idVendor 0x19f7 RODE Microphones
idProduct 0x0003
bcdDevice 1.00
iManufacturer 1 RODE Microphones
iProduct 2 RODE NT-USB
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0109
bNumInterfaces 4
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 0
iInterface 0
AudioControl Interface Descriptor:
bLength 10
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 0x0052
bInCollection 2
baInterfaceNr(0) 1
baInterfaceNr(1) 2
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 2
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 6
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 9
iTerminal 0
bLength 9
bDescriptorType 36
bTerminalID 7
bAssocTerminal 0
bSourceID 8
iTerminal 0
bLength 7
bDescriptorType 36
bDescriptorSubtype 5 (SELECTOR_UNIT)
bUnitID 8
bNrInPins 1
baSourceID(0) 10
iSelector 0
bLength 13
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 9
bSourceID 1
bControlSize 2
bmaControls(0) 0x0001
Mute Control
bmaControls(1) 0x0002
Volume Control
bmaControls(2) 0x0002
Volume Control
iFeature 0
bLength 10
bDescriptorType 36
bUnitID 10
bSourceID 2
bControlSize 1
bmaControls(0) 0x01
Mute Control
bmaControls(1) 0x02
Volume Control
bmaControls(2) 0x02
Volume Control
iFeature 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bDelay 1 frames
wFormatTag 0x0001 PCM
bLength 29
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 2
bSubframeSize 2
bBitResolution 16
bSamFreqType 7 Discrete
tSamFreq[ 0] 8000
tSamFreq[ 1] 11025
tSamFreq[ 2] 16000
tSamFreq[ 3] 22050
tSamFreq[ 4] 32000
tSamFreq[ 5] 44100
tSamFreq[ 6] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 13
Transfer Type Isochronous
Synch Type Synchronous
Usage Type Data
wMaxPacketSize 0x00c8 1x 200 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
AudioStreaming Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 0 Undefined
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 7
bDelay 1 frames
bLength 29
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 8000
tSamFreq[ 1] 11025
tSamFreq[ 2] 16000
tSamFreq[ 3] 22050
tSamFreq[ 4] 32000
tSamFreq[ 5] 44100
tSamFreq[ 6] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 104
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 2
Also have check directly on Epson the drivers :
And the link of driver :
https://download2.ebz.epson.net/epsonscan2/common/deb/x64/epsonscan2-bundle-6.6.42.0.x86_64.deb.tar.gz
https://download2.ebz.epson.net/epsonscan2/common/rpm/x64/epsonscan2-bundle-6.6.42.0.x86_64.rpm.tar.gz
http://support.epson.net/linux/src/scanner/epsonscan2/epsonscan2-6.6.42.0-1.src.tar.gz
I want to use simple-scan with my scanner but that fail.
If you have any idea ?
Best Regards
