Epson L3210 Printer Driver
Hello, I’m a newbie to arch base and I’m looking for Epson L3210 printer driver, upon searching I ended up on AUR (en) - epson-inkjet-printer-202101w but when I do makepkg -si I encountered an error and I’m kinda lost how to fix it, can you guys can help me out? Thanks
makepkg -si     ✔
==> Making package: epson-inkjet-printer-202101w 1.0.1-1 (Sab 23 Set 2023 11:38:29 N.U.)
==> Retrieving sources...
  -> Found epson-inkjet-printer-202101w-1.0.1-1lsb3.2.src.rpm
  -> Found fixbuild.patch
    epson-inkjet-printer-202101w-1.0.1-1lsb3.2.src.rpm ... Passed
    fixbuild.patch ... Passed
==> Extracting sources...
  -> Extracting epson-inkjet-printer-202101w-1.0.1-1lsb3.2.src.rpm with bsdtar
==> Removing existing $pkgdir/ directory...
==> Starting build()...
/home/egayghost/Downloads/epson-inkjet-printer-202101w/PKGBUILD: line 26: patch: command not found
==> ERROR: A failure occurred in build().
    Aborting...
You are missing the prerequisites to use the AUR.
(namely base-devel)
https://wiki.archlinux.org/title/Arch_User_Repository
Hey man, thanks, now I’m able to use my printer.
