Epson ET-3850 scanner
Has anybody got a solution to get the scanner function for the Epson ET-3850 working?
I downloaded the scanner driver (debian) from the Epson driver page, unpacked it and used debtap to convert it. After conversion I did makepkg < packagename> and installed it. On starting the Epson scan software it does not find the network connected scanner (does not see that there is an Epson scanner active on the network). Under Debian the scanner does work. So I’m afraid that, although installation of the software seemed to succeed, it might not matches Manjaro.
I have to try usb yet, but using my laptop I’m not always near to the printer
It should be this driver for the printer part:
AUR (en) - epson-inkjet-printer-escpr2
Look at the (short) list of dependencies.
Optional dependency is
AUR (en) - imagescan
The device also seems to be network capable - which probably means:
no driver needed
Here is one thing my search turned up:
[SOLVED] Network CUPS printer/scanner without Avahi / Newbie Corner / Arch Linux Forums
I don’t have a solution since I don’t own that device and cannot hands on test any of this. :man_shrugging:
pamac build epson-inkjet-printer-escpr2
For this to work, the Arch User Repository (AUR) must be enabled in Pamac;
Epson website has downloads suitable for Debian (.deb) and Fedora (.rpm)
but recommends building from source files for other distributions
https://support.epson.net/linux/Printer/LSB_distribution_pages/en/escpr2.php
If you want to use the driver other than the above distribution,
we recommend that you build from the source file and install it.
If you want to use the source package for x86 CPU, please click here.
Sources:
https://download3.ebz.epson.net/dsc/f/03/00/16/65/08/edc3c65a4f23c3d146ad23a276afe52355cd27d2/epson-inkjet-printer-escpr2-1.2.26-1.tar.gz
AUR (en) - epsonscan2
Sources
https://download3.ebz.epson.net/dsc/f/03/00/16/14/37/7577ee65efdad48ee2d2f38d9eda75418e490552/epsonscan2-6.7.70.0-1.src.tar.gz
AUR (en) - epson-printer-utility
Sources
https://download3.ebz.epson.net/dsc/f/03/00/15/43/23/b85f4cf2956db3dd768468b418b964045c047b2c/epson-printer-utility_1.1.3-1_amd64.deb
pamac-cli does not need AUR support enabled in pamac-manager to build AUR packages
$ grep AUR /etc/pamac.conf
## Allow Pamac to search and install packages from AUR:
#EnableAUR
## Keep built packages from AUR in cache after installation:
## When AUR support is enabled check for updates from AUR:
#CheckAURUpdates
## When check updates from AUR support is enabled check for vcs updates:
#CheckAURVCSUpdates
## AUR build directory:
$ pamac build epson-inkjet-printer-escpr2
Preparing...
Checking epson-inkjet-printer-escpr2 dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  epson-inkjet-printer-escpr2  1.2.26-1    AUR
Building epson-inkjet-printer-escpr2...
==> Making package: epson-inkjet-printer-escpr2 1.2.26-1 (Mon 03 Feb 2025 12:44:50 GMT)
==> Retrieving sources...
  -> Downloading epson-inkjet-printer-escpr2-1.2.26-1.tar.gz...
epson-inkjet-printer-escpr2-1.2.26/ppd/Epson-ET-3850_Series-epson-escpr2-en.ppd
Installing epson-inkjet-printer-escpr2 (1.2.26-1)...                                                               [1/1]
I had an Epson printer with scanner time ago and configuration was easy. Configure it with a fixed ip, be sure you can ping the printer ip. The printer name may be something like “EPSON48980A” (appears in the network status report), be sure you can also ping this name. If not, add name and ip of the printer to your /etc/hosts file. Then add a line in /etc/sane.d/epkowa.conf like this:
net ip_of_your_printer
You can also try with net autodiscovery but having a fixed ip is better the other one.
After that, the scanner should work…
Thank you all for your support. Although not complete, experimenting with the step of each of you did make me succeed that the scanner does work now with Documentscanner application, gscan2pdf and skanlite.
Epson Scan 2 still does not recognize the scanner.
But thanks to you three I’ve made progress.
Steps I’ve done:
  1. Installed imagescan and imagescan-network-plugin from AUR
  2. installed yay and afterwards yay -S epsonscan2
  3. downloaded the epson scan driver and compiled it from source
  4. Configuring via Cups. Cups already knew the printer, but that did not help for scanning
