Epson ET-3750, Cups and Test printer page
Some days before, i recognized, my Epson ET-3750 is no longer printing test pages and quits with the following error:
“cfFilterChain: pdftopdf (PID nnnnn) stopped with status 1”
Oh, this took me hours, just to find out, that everything gets printed fine except the printer test page.
Tested a few Writer dcouments and even PDF, as the error could mean a problem with PDF to print. In fact, everything of this prints fine.
Just the printer test page does not print.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
inxi --filter --verbosity=8
inxi -zv8
Hi @ruggerio , welcome to the forum. The printer seems to print ok, until you try to print a test page.
This printer is an all-in one as far as I understood from here:
‘Epson ET-3750 | Support | Epson US’
This arch wiki page list all the possible models covered by Arch with Epson printers.
‘CUPS/Printer-specific problems - ArchWiki’
Your printer is not listed, I wonder wheter you be able to share the driver information of the printer with the following command:
 inxi -zv8
Another useful information is the ouput of the following terminal command after printing a test page.
tail -n 100 -f /var/log/cups/error_log
Hope it help, regards
I was going to ask if you read the announcement about the libcupsfilters package regression which has similar symptoms, but the impact should have been much bigger. Still, which libcupsfilters do you have? If you are on the new version with the long name, maybe it is a symptom that the problems in the package are “mostly solved” and that’s what’s left to fix.
My partner’s system had an issue with an Epson BX535WD printer recenly (unable to print multiple copies of a document) that was resolved by switching to testing branch and updating libcupsfilters from 2.2.1-2 to 2.2.1.r28.gce65eb74-1
Unstable branch also has a newer version - libcupsfilters 2.2.1.r32.gd49e9284-1
SOLVED-Changing to testing did lots of updates and this fixed it. (i ASSUME it was ghostscript)
Corrigenda: i got an update from AUR for the epson esc/p2 drivers (.44) - this fixed it.
