Well, when i tried to build my l380 drivers an error pops out:
Preparing...
Cloning epson-inkjet-printer-201601w build files...
Checking epson-inkjet-printer-201601w dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building epson-inkjet-printer-201601w...
==> Making package: epson-inkjet-printer-201601w 1.0.0-2 (sex 16 abr 2021 12:54:50)
==> Retrieving sources...
-> Downloading epson-inkjet-printer-201601w-1.0.0-1lsb3.2.src.rpm...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
35 2245k 35 802k 0 0 803k 0 0:00:02 --:--:-- 0:00:02 802k
100 2245k 100 2245k 0 0 1819k 0 0:00:01 0:00:01 --:--:-- 1819k
epson-inkjet-printer-201601w-1.0.0-1lsb3.2.src.rpm ... Passed
==> Extracting sources...
-> Extracting epson-inkjet-printer-201601w-1.0.0-1lsb3.2.src.rpm with bsdtar
==> Starting build()...
libtoolize: putting auxiliary files in '.'.
libtoolize: linking file './ltmain.sh'
libtoolize: Consider adding 'AC_CONFIG_MACRO_DIRS([m4])' to configure.ac,
libtoolize: and rerunning libtoolize and aclocal.
libtoolize: Consider adding '-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether ln -s works... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for dlopen in -ldl... yes
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for unistd.h... (cached) yes
checking for an ANSI C-conforming const... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for vprintf... yes
checking for _doprnt... no
checking for memset... yes
checking for strdup... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/raster/Makefile
config.status: creating src/raster/blendSource/Makefile
config.status: creating src/memory/Makefile
config.status: creating src/pagemanager/Makefile
config.status: creating src/filteropt/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /var/tmp/pamac-build-bruno/epson-inkjet-printer-201601w/src/epson-inkjet-printer-filter-1.0.0/missing --run autoconf
cd . && /bin/sh /var/tmp/pamac-build-bruno/epson-inkjet-printer-201601w/src/epson-inkjet-printer-filter-1.0.0/missing --run automake-1.11 --gnu
/var/tmp/pamac-build-bruno/epson-inkjet-printer-201601w/src/epson-inkjet-printer-filter-1.0.0/missing: line 52: automake-1.11: command not found
WARNING: `automake-1.11' is missing on your system. You should only need it if
you modified `Makefile.am', `acinclude.m4' or `configure.ac'.
You might want to install the `Automake' and `Perl' packages.
Grab them from any GNU archive site.
configure.ac:9: warning: The macro `AC_CONFIG_HEADER' is obsolete.
configure.ac:9: You should run autoupdate.
./lib/autoconf/status.m4:719: AC_CONFIG_HEADER is expanded from...
configure.ac:9: the top level
configure.ac:15: warning: The macro `AC_PROG_LIBTOOL' is obsolete.
configure.ac:15: You should run autoupdate.
aclocal.m4:121: AC_PROG_LIBTOOL is expanded from...
configure.ac:15: the top level
configure.ac:22: warning: The macro `AC_HELP_STRING' is obsolete.
configure.ac:22: You should run autoupdate.
./lib/autoconf/general.m4:204: AC_HELP_STRING is expanded from...
configure.ac:22: the top level
configure.ac:72: warning: The macro `AC_HEADER_STDC' is obsolete.
configure.ac:72: You should run autoupdate.
./lib/autoconf/headers.m4:704: AC_HEADER_STDC is expanded from...
configure.ac:72: the top level
configure.ac:80: warning: The macro `AC_TYPE_SIGNAL' is obsolete.
configure.ac:80: You should run autoupdate.
./lib/autoconf/types.m4:776: AC_TYPE_SIGNAL is expanded from...
configure.ac:80: the top level
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh ./configure LDFLAGS=-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now -Wl,--no-as-needed --prefix=/opt/epson-inkjet-printer-201601w CFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fno-plt CPPFLAGS=-D_FORTIFY_SOURCE=2 --no-create --no-recursion
configure: error: cannot find required auxiliary files: compile
make: *** [Makefile:290: config.status] Error 1
==> ERROR: A failure occurred in build().
Aborting...
Preparing...
==> Making package: epson-inkjet-printer-201601w 1.0.0-2 (sex 16 abr 2021 12:57:43)
-> Found epson-inkjet-printer-201601w-1.0.0-1lsb3.2.src.rpm
==> Removing existing $pkgdir/ directory...
Aborting...
Preparing...
==> Making package: epson-inkjet-printer-201601w 1.0.0-2 (sex 16 abr 2021 13:28:44)
Aborting...
