Environment variables for proper Wayland functionality
This is my /etc/environment for X.Org
# This file is parsed by pam_env module
DIFFPROG=/usr/bin/meld
EDITOR=/usr/bin/vim
SUDO_EDITOR=/usr/bin/vim
# Browser Parameters
GST_PLUGIN_FEATURE_RANK=nvmpegvideodec:MAX,nvmpeg2videodec:MAX,nvmpeg4videodec:MAX,nvh264sldec:MAX,nvh264dec:MAX,nvjpegdec:MAX,nvh265sldec:MAX,nvh265dec:MAX,nvvp9dec:MAX
GST_VAAPI_ALL_DRIVERS=1
LIBVA_DRIVER_NAME=nvidia
MOZ_DISABLE_RDD_SANDBOX=1
##MOZ_ENABLE_WAYLAND=1
MOZ_X11_EGL=1
NVD_BACKEND=direct
OBS_USE_EGL=1
VAAPI_MPEG4_ENABLED=true
VDPAU_DRIVER=nvidia
# Gaming Parameters
__GL_SHADER_CACHE=1
__GL_SHADER_DISK_CACHE=1
__GL_SHADER_DISK_CACHE_SKIP_CLEANUP=1
__GL_ExperimentalPerfStrategy=1
DXVK_ENABLE_NVAPI=1
ENABLE_VKBASALT=0
##PIPEWIRE_LATENCY=1024/44100
PULSE_LATENCY_MSEC=60
# Proton Settings
PROTON_ENABLE_NGX_UPDATER=1
PROTON_ENABLE_NVAPI=1
PROTON_FORCE_LARGE_ADDRESS_AWARE=1
PROTON_HIDE_NVIDIA_GPU=0
STEAM_FORCE_DESKTOPUI_SCALING=1.25
VKD3D_CONFIG=dxr
# Display Environment
##CLUTTER_BACKEND=wayland
CLUTTER_DEFAULT_FPS=60
##GBM_BACKEND=nvidia-drm
GDK_BACKEND=x11
GTK_IM_MODULE=ibus
##KITTY_ENABLE_WAYLAND=1
QT_AUTO_SCREEN_SCALE_FACTOR=0
QT_IM_MODULE=ibus
QT_QPA_PLATFORMTHEME=qt5ct
SDL_VIDEODRIVER=x11
##WLR_NO_HARDWARE_CURSORS=1
XCURSOR_THEME=Adwaita
XCURSOR_SIZE=32
XDG_SESSION_TYPE=x11
XMODIFIERS=@im=ibus
For Wayland, would this below be correct after editing?
I am trying to be meticulous and have a rock-steady setup manually geared for performance.
EDITOR=/usr/bin/vim
##MOZ_X11_EGL=1
NVD_BACKEND=direct
##OBS_USE_EGL=1
VDPAU_DRIVER=nvidia
# Gaming Parameters
__GL_SHADER_CACHE=1
DXVK_ENABLE_NVAPI=1
ENABLE_VKBASALT=0
# Proton Settings
VKD3D_CONFIG=dxr
GDK_BACKEND=wayland
GTK_IM_MODULE=ibus
QT_IM_MODULE=ibus
SDL_VIDEODRIVER=wayland
XCURSOR_SIZE=32
XDG_SESSION_TYPE=wayland
XMODIFIERS=@im=ibus
Primary sources were:
Other sources that I can remember:
Im not sure you should be putting all of this in /etc/environment when they are application-specific variables but
This should be removed
It was a workaround for a bug squashed … a year ago?
On to the stuff … it seems its mainly this
Which seems about right if you are trying to set hw-accel in firefox while switching from X11 to wayland.
Are there some in particular that might cause breakage or problems keeping as global rather than setting per application?
And, are the wayland specific parameters in the second group I posted generally good to keep global ?
Eh. Conceivably yes … probably and in your case … no.
Its more just that its a place ‘for system wide environment variable settings’
I suppose it wont cause an issue as long as they are ‘correct’.
Oh the rest are fine // make sense as globals (things like GDK_**, QT_**).
I dont have an nvidia to be able to say much about the specifics of a lot of them.
In your opinion, is Wayland ready?
Also, MOZ_DISABLE_RDD_SANDBOX=1 was for vaapi configuration specifically. If this is no longer required, I need to open a ticket on the guy’s site
GitHub - elFarto/nvidia-vaapi-driver
See for example this bug which was closed:
Depends on your hardware and use-case. For some … mainly those with newer hardware, non-nvidia non-gamers … sure.
If everything works … it will likely even feel smoother than xorg.
For myself … I still use X11 … and I might tend to think thats still the better option for the majority of users.
FYI, those have been default for awhile now with recent versions of Proton.
I take that back, not a solution.
MOZ_DISABLE_RDD_SANDBOX=1 is still required for VAAPI.
|    0   N/A  N/A      2068    C+G   /usr/lib/firefox/firefox                    256MiB |
It isnt here or according to the bug reports…
Maybe something else is the problem?
